跳转到主内容
2012-2015 Honda Civic Taillight Turn Signal Replacement
你所需要的
  1. 2012-2015 Honda Civic Taillight Turn Signal Replacement, Taillight Turn Signal: 步骤 1 中的图像 1,2 2012-2015 Honda Civic Taillight Turn Signal Replacement, Taillight Turn Signal: 步骤 1 中的图像 2,2
    • Ensure your car is turned off by checking that the key is in the off (O) position and that the engine is not running.
    • Open the trunk by pulling the latch on the floor of the driver's side.
  2. 2012-2015 Honda Civic Taillight Turn Signal Replacement: 步骤 2 中的图像 1,2 2012-2015 Honda Civic Taillight Turn Signal Replacement: 步骤 2 中的图像 2,2
    • In the trunk, remove these fasteners by prying the center piece out with the screwdriver.
    • Expose the bulbs by pulling the trunk lining away from the walls of the trunk.
  3. 2012-2015 Honda Civic Taillight Turn Signal Replacement: 步骤 3 中的图像 1,2 2012-2015 Honda Civic Taillight Turn Signal Replacement: 步骤 3 中的图像 2,2
    • Rotate the turn signal socket ¼ turn counterclockwise. The turn signal socket is located below the main taillight bulb and closer to the middle of the car.
    • You will be able to pull the socket out of its housing and expose the blown bulb.
  4. 2012-2015 Honda Civic Taillight Turn Signal Replacement: 步骤 4 中的图像 1,2 2012-2015 Honda Civic Taillight Turn Signal Replacement: 步骤 4 中的图像 2,2
    • Remove just the blown bulb from the socket. A bit of force might be required to get it separated, but once it is, just the bulb and its rectangular, flat base should remain.
    • Put the new bulb in.
结论
The fasteners are easiest to reinstall when the center piece is pulled as far out as possible when reinserting. Once they are back in place, press the center piece down to lock them in.
Keaton Gilbert
于03/31/20注册
109 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 17
过去 30 天: 114
总计 2,931
