跳转到主内容
2012-2015 Honda Civic Air Filter Replacement
  1. 2012-2015 Honda Civic Air Filter Replacement, Air Filter: 步骤 1 中的图像 1,3 2012-2015 Honda Civic Air Filter Replacement, Air Filter: 步骤 1 中的图像 2,3 2012-2015 Honda Civic Air Filter Replacement, Air Filter: 步骤 1 中的图像 3,3
    • Locate the "hood open" lever on the driver's side of the inside of the car, below the dashboard. Pull lever toward you. You will hear a "click." Go to the front of the car. The hood should be "popped" slightly. Reach under the hood, find a lever, and move the lever to the left. This will completely release the hood latch.
  2. 2012-2015 Honda Civic Air Filter Replacement: 步骤 2 中的图像 1,3 2012-2015 Honda Civic Air Filter Replacement: 步骤 2 中的图像 2,3 2012-2015 Honda Civic Air Filter Replacement: 步骤 2 中的图像 3,3
    • Find the anchor to hold up the hood of your car. This anchor should be laying along the ledge in front of the radiator. Lift the anchor and insert the end into the hole on the lower side of the hood.
  3. 2012-2015 Honda Civic Air Filter Replacement: 步骤 3 中的图像 1,2 2012-2015 Honda Civic Air Filter Replacement: 步骤 3 中的图像 2,2
    • As you are facing the Civic, the air filter will be inside the black plastic box to the right of the valve cover.
  4. 2012-2015 Honda Civic Air Filter Replacement: 步骤 4 中的图像 1,3 2012-2015 Honda Civic Air Filter Replacement: 步骤 4 中的图像 2,3 2012-2015 Honda Civic Air Filter Replacement: 步骤 4 中的图像 3,3
    • There will be four clips on the air filter box - two on the front, one on the right and one on the right back. Release the clips from the box by pushing them away from the box.
  5. 2012-2015 Honda Civic Air Filter Replacement: 步骤 5 中的图像 1,3 2012-2015 Honda Civic Air Filter Replacement: 步骤 5 中的图像 2,3 2012-2015 Honda Civic Air Filter Replacement: 步骤 5 中的图像 3,3
    • Gently lift the cover of the box from the lower part of the box. Remove the old air filter from the box and set it aside. Place the new air filter in the box. Replace the cover and place the four clips back on the box.
结论
6等其他人完成本指南。
rayyan
于03/27/15注册
221 声望
撰写一个指南
团队
Baylor, Team 5-7, Williams Spring 2015 Baylor, Team 5-7, Williams Spring 2015 的会员
BU-WILLIAMS-S15S5G7
4 名成员
创作了9篇指南
一条评论
Haha this is not moderately or even remotely hard to do, I made a 1 minute diy video that shows how simple it is.
https://youtu.be/Hw_TppaPzp8
lukedavidjohnson - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 45
过去 30 天: 260
总计 16,058
