跳转到主内容
2012-2016 Honda CR-V Oil and Oil Filter Replacement
你所需要的
  1. 2012-2016 Honda CR-V Oil and Oil Filter Replacement, Oil and Oil Filter: 步骤 1 中的图像 1,2 2012-2016 Honda CR-V Oil and Oil Filter Replacement, Oil and Oil Filter: 步骤 1 中的图像 2,2
    • Open the hood by pulling the hood latch.
    • Oil may be hot if the engine has not cooled.
    • Keep vehicle in park and off unless otherwise noted.
    • Chock both back wheels with blocks of wood to prevent car from rolling.
  2. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 2 中的图像 1,2 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 2 中的图像 2,2
    • Let the vehicle cool for 15 minutes if needed. Clean the area around the oil cap. Remove the oil cap.
  3. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 3 中的图像 1,3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 3 中的图像 2,3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 3 中的图像 3,3
    • Locate the dipstick and check oil level.
  4. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 4 中的图像 1,1
    • Place the drain pain under the chassis and align with the drain bolt.
  5. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 5 中的图像 1,1
    • Locate the drain bolt.
  6. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 6 中的图像 1,3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 6 中的图像 2,3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 6 中的图像 3,3
    • Remove the drain bolt with a 17mm socket wrench, and completely drain the oil.
  7. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 7 中的图像 1,1
    • Remove the oil filter with a 45mm oil filter socket.
  8. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 8 中的图像 1,3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 8 中的图像 2,3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 8 中的图像 3,3
    • Replace the drain bolt with a new drain bolt gasket (crush washer); Honda Washer, Drain Plug (14MM) 94109-14000. Use the 17mm socket wrench to tighten.
  9. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 9 中的图像 1,2 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 9 中的图像 2,2
    • Install the new filter in place of the old filter. Hand tighten instead of using the oil filter wrench.
  10. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 10 中的图像 1,2 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 10 中的图像 2,2
    • Place the medium funnel and add new 0W-20 full synthetic engine oil. Add 4.2 quarts of oil.
  11. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 11 中的图像 1,1
    • Replace the oil cap.
  12. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 12 中的图像 1,1
    • Start the vehicle, and check for any leaks around the oil filter and oil drain plug.
    • Stop the vehicle and let the engine rest for 5 minutes.
  13. 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 13 中的图像 1,3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 13 中的图像 2,3 2012-2016 Honda CR-V Oil and Oil Filter Replacement: 步骤 13 中的图像 3,3
    • Use the dip stick to double check oil level and add more if needed.
    • Make sure the oil level is in between the low and high marks on the dip stick. Replace the dip stick and close the hood.
    • Reset the oil life in the maintenance section of the vehicle computer.
结论
6等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 31
过去 7 天: 139
过去 30 天: 683
总计 20,234
