简介
If the seat hinges on your 2014 Toyota Corolla become loose or unattached from the seat, it may be caused by a loose bolt or even a broken hinge.
This guide details how to properly remove the rear-outside seat hinges, but can also be applied to the removal of the rear-inside seat hinges, as the removal process is almost identical. Although this repair is made on a 2014 Toyota Corolla, it also applies to all 2012-2017 models of the Toyota Corolla as they are in the same generation.
你所需要的
Unlock the latch on top of the rear seats and pull both seats down.
Lift the trunk's carpeting up to reveal the circular hooks attached to the seats' carpeting. Unhook the seats' carpeting from the circular hooks in the trunk, revealing the hinges.
Insert the seat(s) back into car, making sure that the middle seat belt is not trapped on the backside of the seat(s).
Slide the hinges back over the seat(s), making sure to line up the bolt hole on the seat(s) with the bolt hole on the hinges. Press the seat down to hook the hinges back into the seat.
Congratulations, you’re finished!
另外一个人完成了本指南。
