跳转到主内容
2012-2018 Nissan Versa Note Headlight Bulb Replacement
你所需要的
  1. 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: 步骤 1 中的图像 1,2 2012-2018 Nissan Versa Note Headlight Bulb Replacement, Headlight Bulb: 步骤 1 中的图像 2,2
    • Pull the hood lever.
  2. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 步骤 2 中的图像 1,1
    • Push the lever underneath the hood to the left.
    • The lever is located in the center underneath the hood.
  3. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 步骤 3 中的图像 1,1
    • Pull up the hood.
  4. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 步骤 4 中的图像 1,1
    • Insert the support rod into the slot.
    • The stent is located to the right of the hood.
    • The slot is located in the underside of the hood to the right.
  5. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 步骤 5 中的图像 1,2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 步骤 5 中的图像 2,2
    • Pull out the connector from the bulb.
    • Depending on the make of your vehicle, you may have push the tab on the connector that reads "push" before pulling out the connector.
  6. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 步骤 6 中的图像 1,1
    • Twist the plastic ring out from the bulb.
  7. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 步骤 7 中的图像 1,2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 步骤 7 中的图像 2,2
    • Pull out the old bulb.
    • High pressure halogen gas is sealed inside the halogen bulb. The bulb may break if the glass envelope is scratched or the bulb is dropped.
    • When handling the bulb, do not touch the glass envelope.
  8. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 步骤 8 中的图像 1,2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 步骤 8 中的图像 2,2
    • Insert the replacement bulb.
  9. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 步骤 9 中的图像 1,1
    • Twist the plastic ring back onto the bulb.
  10. 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 步骤 10 中的图像 1,2 2012-2018 Nissan Versa Note Headlight Bulb Replacement: 步骤 10 中的图像 2,2
    • Insert the connector into the bulb.
终点
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 12
过去 7 天: 61
过去 30 天: 253
总计 9,312
