跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
使用本指南从MacBook Pro中取出内置粘合电池, 最好使用iFixit电池更换套件完成。套件中的液体粘胶去除剂将溶解固定电池的粘胶,从而轻松拆卸电池。
iFixit粘胶去除剂是高度易燃的。在通风良好的地方进行工作。 在此过程中,请不要吸烟或是在明火附近工作。
为了降低危险,在开始工作之前请先对MacBook Pro的电池放电。如果意外刺穿充电的锂离子电池可能会造成危险和无法控制的火灾。如果电池鼓包,请采取额外措施
注意事项:用于溶解电池胶的溶剂与MacBook Pro的塑料扬声器外壳接触可能会损坏扬声器。 这份指南指导你在拆解电池之前卸下扬声器。
[ … ] 如果你正在使用旧式的iFixit胶水去除套装,即分开的瓶子和注射头(不再售卖),点击这里查看不同的教程。
  1. 将固定 MacBook Pro 后盖的 P5 五角螺丝拆掉:
    • 将固定 MacBook Pro 后盖的 P5 五角螺丝拆掉:
    • 8颗 3.0mm 螺丝
    • 2颗 2.3mm 螺丝
    To remove the back panel there are two different pentalobe screws 2.3mm and 3mm however on the tools list there is only one screwdriver. Will I be able to remove both screws with the same screwdriver?
    lantzero - 回复
    In my case it worked. Don't know if it was a 2,3 or 3 mm screwdriver
    Christian Mohr -
    The 2.0 and 2.3 mm measurements are screw lengths, the screw heads are the same sized P5 pentalobe heads. We include the screw lengths so you don't put the wrong screws in the wrong places and end up with screw heads poking out of your device. Hope that clears up some confusion =)
    Sam Goldheart -
    Yes the same screwdriver will remove both screws, the difference in screws I believe is the length and width but the head is the same.
    Mike -
    Just be careful to store the 2 shorter screws in a seperate space then the other 3mm screws.
    The first time I opened up my Macbook, I put the screws in the wrong order.
    Shahzad Arif -
    will this unit work with the Mid 2012 Macbook Pro Retina's as well?
    drscottgreenwell - 回复
    Same question...anyone know? Damaged my 2012 board and if possible would like to upgrade to this unit
    cloughenough -
    This works for rMBP 2012 late
    iyeori -
    Woohoo, much easier than I thought... Just got confused with the bottom case screw driver but after figure out it was P5 then everything went smooth.... One thing I wanted to upgrade was the wifi to ac and got one on ebay!
    didierma - 回复
    If you have 54 Bit Driver kit, please use Star 5 driver to remove screw for rMBP 2012 Late
    iyeori - 回复
    Where can I find the driver for the MacBook Pro Retina Display 15'4 i7 on your website iFixit please.
    Epifanio - 回复
    It took about 40 minutes due to an extreme measure of caution but I did it! The only real difficulty was reattaching the screen to the base (yes you have to pry the hinges open) and re-connecting the camera wires. After a few tries the camera wires finally came together. I'm hating Apple for all it's frailty and magical screws but I love ifixit!
    floyd - 回复
    Simple guide, but it solved my problem. Was wondering why the top two screws weren't going all the way down. Hadn't realized they were 0.7mm shorter.
    Emilio Mejia - 回复
    I have BootCamp running Win7 on my MBPwRetina15" 2013'Late. I run Visual Studio to build and run my Company's Application which is very CPU & NVidia (specific) intensive. So much so that during a build & run of app I was averaging about 85~95+Celcius!!! And every so often would reach 100Celcius!!! I could not take it anymore so I decided to delve into and re-apply Thermal Paste on the CPU/GPU. I ended up going with CooLaboratory Liquid Pro instead of the traditonal AS5. The original Thermal Paste was pure garbage,,, part of the CPU seemed like it was missing TP. I was scared to do this but it turned out easier than I had imagined. I am currently building the same application and can already observe that the temps average about 75~85 and once in a while will reach 90Celcius. So I am seeing about a 10~15 degree drop in Temps and that makes me very happy!
    Alvaro Suarez - 回复
    Nice to hear that, i was looking for that kind of information. I have a MBPwRetina 15 Mid 2012 and looking to obtain the best performance!
    Jose David Valle -
    Woa! Thanks dude! And you follow some guides here for the thermal paste? My mac 15’’ early 2013 heats up a lot but I’m a bit worried about touching anything
    Bert0ld0 -
    Good to list the bit needed to open the case: P6
    brian2burnett - 回复
    Much easier than expected. Sounds like several people had trouble with the backlight. It is possible that they damaged something by not first making sure to power down the computer completely with the “Shut Down” command. This should be step 1 before removing the back cover screws. Also as noted all the back cover screws are Apple Pentelope #5 bit, but 2 of the screws are shorter than the others. This bit is is hard to find in most stores. Buy it on line along with the Tork #5 and #8. 11/21/2017
    Walt Goede - 回复
    Replaced my Magsafe 2 yesterday and it works perfectly on my MBP 15” ea13. However, when I plugged in the charger I heard the startup sound twice and then I got to the login page where I realized the keyboard didn’t respond.
    So I thought I should restart the computer so I clicked ”shut down”. But the keyboard is dead. I can’t start it. I haven’t tried to use a USB-keyboard yet..
    Any ideas what may have caused this to happen and what component ”handles” the keyboard? Thanks
    /JD
    Jakob Dahlin - 回复
    Not sure if this has been listed.
    PRO TIPS from a non-pro:
    1 - Keep screws separated and labeled by step # and size.
    2 - Be very careful to get screws in properly threaded, its VERY easy to strip the ccrew holes and screws. Especially the case. Not that it happened to me…
    3 - It was impossible for me to get all the adhesive off the case from under battery, it left a lot on w/o issue (yet).
    4 - Make sure you have Aluminium Foil before starting!
    5 - Upgrade the SSD or HDD while your in there!
    erin - 回复
    Hi there, about advice no.4 Why should I bring Aluminium Foil? What is the purpose of using Aluminium Foil. Thank you.
    RR J -
    Do we remove the logic board purely to get the speaker enclosures out and away from the acetone? Or does it physically block getting the batteries out? Ie. if I wanted to risk the damage to the speakers, could I jump straight to step 34?
    Obviously I don’t want to melt the speakers, but I’m kinda weighing that risk against losing a screw or breaking a connector…
    Michael Ferenduros - 回复
    So I did take the risk and swapped out the battery without doing the logic-board + speaker removal.
    Before applying the acetone I put tape on the exposed sides of the speaker-enclosures as best I could - I wrapped the tape, sticky side out, around a card, slid it into the gap, and pressed it onto the speakers. And when applying the acetone, I squirted it as gently as possible onto the side of the battery and let it run down the side, which seemed to help avoid getting too much on the speakers.
    The speaker’s plastic turned white in the spots where the acetone touched it, but it looked like surface damage only. Otherwise it was a nice and smooth procedure.
    Your milage may vary, obviously.
    I changed the battery pack as well without removing the logic board etc. It helped, that the batteries already were swollen, thus access to the glue stripes was easier. It works, if you give a little tension, pulling a pack upwards, and then work with a small blade or knife, and cut the glue stripes. It may take a while, but much less time than dismantling the whole macbook. If you don’t hurry, and don’t apply too much force, you will not damage anything. Beside the 10 cover screws you only have to loose 2 screws for the battery connector. After removing the old pack I used Methanol to remove the glue. I prefer this solvent to Acetone, because it’s less or not harmful to plastic (however, no warranty, just my personal experience). I was able to finish the work in 40 minutes, although it was the first time I opened my Macbook. Well, I am an engineer, that helps, but with dismantling all boards it definitely would have taken double the time. And more risks to break a plug or make a mistake while reassembling.
    Heinrich Jung -
    Success. I needed to replace the right speaker. I thought I was ready at step 22 (you are able to replace the left speaker at this point… but but the right) To replace the right I continued thru step 29 but didn’t completely remove the motherboard. I just lifted it enough to remove and replace the right speaker cable.
    Read all of the comments and solved many problems. Thanks to I-fixit, Walter Galen and all who posted comments.
    Will Brecht - 03/02/2019
    Will Brecht - 回复
    1/2
    If you're taking the shortcut (nylon, wire…and no adhesive for battery removal (you'll def need to remove the adhesive once the battery pack is removed) things to note:
    1 The adhesive may still be pretty strong. Mine was and I broke several wires trying to do the cheese cutter move down the back of the middle two batteries
    2 if you're cheese cutting through the adhesive, when you get to the base, don't go too far. I did and severed the battery cell connector… disconcerting puff of smoke.
    Ruairi Kennedy - 回复
    2/2
    3 the you tube video dude was lucky not to have his two Central batteries adhered . Mine were stuck fast.
    4 don't forget about the two small T 5 screws to the left and right of the battery head board, just below the main battery connector.
    5 the Track Pad sits behind the two central batteries. The batteries are adhered to a flat plate that protects the Track Pad which is pretty resilient. You can do the cheese wire trick without cutting through anything you shouldn't. However be careful if you're using a spudger or other tool between the two centre batteries at the top of the T. This is where the Track Pad connector (its very flat and exposed) to the motherboard.
    6 seems obvious when it's written , but you will need the adhesive remover if you are interested in removing the adhesive. It's a work out.
    Ruairi Kennedy - 回复
    I just completed this successfully. The guide was great, and I recommend reading each of the steps’ comments, too. It is possible to cut out a majority of the steps outlined here if you’d rather not dismantle most of your laptop. As I’m a novice and this was the first difficult fix I’d ever tried, the idea of taking so many things apart — including removing the logic board — was a little scary. Everyone calculates risk and reward differently, but for me, the risk of removing the logic board for the reward of being able to remove the battery packs with adhesive remover was too great, so I opted to only do steps 1–4, 42–53 and removed the battery with one of the cards from iFixit’s kit. If you go this route, expect it to be a little frustrating & slow going — it took me around 20–30 minutes of slowly chipping away at the adhesive with only the card. There are other techniques out there (wire, fishing line, etc.) and I’d advise looking into them. Keep track of screws: tape, draw out diagrams, label them, etc.
    Jake Thornberry - 回复
    Hi. I got your beautiful guide and I got a toolkit, unfortunately not the ifix it and everything is ready to start the operation. But the P5 seems to be too big for the screws of my late 2013 a1398. Are there more than one types/ sizes of P5?
    Chrysovalantis Lamprianidis - 回复
    I only removed the 10 screws and the back panel, the 5 speaker’s screws (without removing the speakers), and the two battery screws, and managed to remove the battery package without undoing anything else. I used a member card (credit card type) to loosen the adhesives under the batteries.
    To remove the rest of the glue, I soaked it with something called Label Off from Biltema (Nordic). Finally, I used methylated spirit (rødsprit) to clean it all up and let it dry for 5 minutes before assembling the new battery pack.
    Andreas H. Parlow - 回复
    WAIT!.. STOP.
    iFixit has had a slew of defective batteries that they will require you take out and return (after gluing them in). Search on: "Battery percentage suddenly drops" here on this site. This process is 50 steps to get the new battery in, and another 50 to put all the parts back. For $199, Apple will do the whole repair, warranty it, and also replace the trackpad and the keyboard (because it's easier for THEM to do).
    Ifixit WILL NOT stand behind defective batteries unless you spend another 4-6 hours swapping in a new one. NOT. WORTH. IT. See posts here (Battery percentage suddenly drops from ~60% to 7%) on frustrated customer’s multiple attempts and class-action lawsuits.
    MFMauceri - 回复
    Hi,
    Do you have to mail in your laptop to get the battery replaced for $199?
    Thanks,
    RB
    Roshanda B -
    Alternative part suggestion(s) that worked for me:
    * Sintech NGFF M.2 nVME SSD Adapter Card for Upgrade 2013-2015 Year Macs(Not Fit Early 2013 MacBook Pro - https://www.amazon.ca/dp/B01CWWAENG
    * Samsung 970 EVO 1TB NVMe M.2 Internal SSD (MZ-V7E1T0BW - https://www.amazon.ca/gp/product/B07BN21...
    The adapter supports many common drives (though not all) and a few minor drawbacks, but otherwise has worked flawlessy for over a year.
    Harvey Thompson - 回复
    I have now replaced the battery and the dc-in board, and I still can’t get the battery to charge. I also bought a new magsafe power adapter. It appears all cables are connected, and the computer runs fine on the battery (until it runs out of juice, then I will be at a complete loss). No clue what to try next. Any suggestions? Thanks!
    matt rogers - 回复
  2. 从后盖盖和主机壳夹扣处抬起,从 MacBook Pro上取下后盖。
    • 从后盖盖和主机壳夹扣处抬起,从 MacBook Pro上取下后盖。
    • 将取下的后盖放到一边。
    Does anyone noticed that the bottom cover and the bottom case is actually linked with the black plastic near the battery?! After the first time you open the cover, it will be impossible to put it back to the original place. Does the critical?! Thanks a lot for informing
    jamiegan835 - 回复
    I was able to simply push and click those clips back into place before I did the screwing.
    Tim Peat -
    I truly believe this is placebo and the 10*C difference is because in the process the dust was removed from the fan/heat sink rather then the thermal "magic" paste.
    This is a "PC" habit.
    On the other hand, all the cases and protections out there have a bad effect on cooling (not sleeves or pouches) because the whole aluminum body helps dissipate heat.
    I've never had any problems with any mac regarding heat (they do get hot, but it is OK).
    Whenever you feel heat from electronic device means the heat radiates away from it.. which means the cooling is doing a good job :).
    crus - 回复
    Hey,
    Writing about dust and dirt, do you know any cleaning products for the interior of the mac. i mean how do you clean your laptop, pc, etc..
    Regards
    Jose David Valle -
    This is untrue. Over time thermal paste will dry up and crack and not provide good coverage between the device and the cooler. The paste massively improves the thermal transfer between the chip and the heatsink. If you do not believe in the magic paste then you should wipe it all off and apply just a little bit or none at all and then compare temperatures. You will see the paste is responsible for a big reduction in temperature.
    Andrew Fox -
    I was able to remove all screws but lower case is not comming off easly. Is it glued to somthing?
    Thanks for help.
    c4rlosv8 - 回复
    There are two clips in the centre which simply unclip with a little force.
    Tim Peat -
    If you are following this how-to because liquid/coffee splashed in through the back vents, WAIT UNTIL THE END to clean any liquid spills on the bottom panel. Use them as your map for cleaning and QA guide for checking until you are finished with your cleanup of logic board and other items.
    auntialias - 回复
  3. 揭开盖住电池接口的警告标签。
    • 揭开盖住电池接口的警告标签。
    For rMBP 2012 Late, you don't need to remove this sticker.
    iyeori - 回复
    Have laptop charging issues after this. When fully charged and i plug in magsafe it starts with green, then turns red and stays red (like if it was charging). Status bar says NOT charging. If i use battery a little bit (down to 69%) magsafe does the same (green then stay red). Status bar says battery 69% NOT charging. and it seems to be true. Any suggestions?
    g000phy - 回复
    Double check the connection from the battery to the logic board and the logic board socket itself... Might have damaged by disconnect/reconnect.
    max damage -
    Why is this step necessary?
    67b5ebab - 回复
    67b5ebab Good question !
    Why is this necessary ?
    bigb19791979 - 回复
    This step is necessary to prevent any discharging, arcing, friction/static charges from damaging any of the extremely delicate and intricate parts of this (or most any) electrical system. In practice, you should even be wearing an anti-static band or be working on an anti-static bench even with the battery disconnected so your body doesn't create any unintentional charges.
    One of the first things you should learn in electronics repair and and electrical in general is to cut the power source whenever possible before performing any work. Some systems have schedulers/triggers set that will wake the system up (even when closed) to perform updates and other maintenance tasks as to not eat up CPU and RAM during 'peak hours'. The last thing you need is to have your $2,000 laptop turn on while pulling an SSD (which, correct me if wrong, isn't a plug-and-play based device) which could do some serious corruption and/or damage; when all you had to do was peel a sticker and plug.
    Hope that helps!!
    ~the more you know~
    Colin Devenney - 回复
    I did not peel back the sticker. It is probably there to help unplug the battery. You can apply a gentle constant pull while you use spudger to lift the battery connector out of the socket as per the next step. It made this very easy.
    Achilles - 回复
    There is another connector here on mine, just to the left and up above the text on the battery sticker. It is an empty ZIPF socket on all these photos.
    Richard C - 回复
    Let me stop you guys here. You can skip steps 5-35.
    That’s what I did without a problem.
    Go directly to step 35 after the next step. 5-35 is only so you have more room to pry the old battery off.
    If you are not keeping the old battery, then just pry it off with a flathead screwdriver.
    This is not a difficult fix.
    Chris - 回复
  4. 使用撬棒平头的那端,轻轻地将电池接口直接从逻辑板上的插座中撬出。 弯曲电池电缆,确保电池接口不会意外接触逻辑板。
    • 使用撬棒平头的那端,轻轻地将电池接口直接从逻辑板上的插座中撬出。
    • 弯曲电池电缆,确保电池接口不会意外接触逻辑板。
    I ordered the whole kit, but seeing how much tedious effort it was to take out so many parts so they wouldn't be damaged by the solvent, I skipped from here to step 34 and only used the supplied cards (credit-card sized) with patience and persistence to free the battery sections from the backing. Success! Then I used a q-tip to apply the solvent to remove the remnants of the adhesive from the aluminum case. My battery was very swollen, so it was like removing little pillows. I think the swelling may have helped to give me additional access with the cards to free it. Success! My MBP is back up and running, and now the trackpad clicks again and it sits flat on a table!
    Joel Replogle - 回复
    So no need basically to unscrew all the mac
    Bert0ld0 -
    Joel - the purpose of all of the trouble in removing the logic board is to make sure that you don’t damage anything when you start pull out the battery. After this step - it’s true, you have about 12 connectors and dozens of screws to unplug, but I didn’t have any major problems.
    REASSEMBLY - I had to use alot of force to get the official IFIXIT battery connect to push into place to actually connect. I was worried that one of the wires would stress and break. It worked, but it was not super easy this part.
    Jer - 回复
    I also skipped down to step 50. I stuck a piece of 1/2 inch weather stripping across the middle of the top cover of the laptop to maintain a pitch on the unit so the adhesive remover stayed away from the other components. I applied the remover and used a piece of string to cut through the adhesive strips. I owed the plastic tool from the kit to position the string behind the top of each cell and cut through one ata a time. The battery came out in about 15 minutes. The directions were very informative and useful but I thought the risks associated with dismantling the laptop and reassembling it again were greater. I could not have done it without the details presented. Thank you.
    Thomas Horan - 回复
    Having broken a connector on a logic board in the past, I worried about all the steps. But I understand the disaster that can occur if cleaning fluid contacts the logic board. Weighing costs and benefits, I also did not remove the logic board. I loosened up the speakers (since only two screws could be removed) to give me space to slide the cards under the battery cells. Using the two cards, sometimes sliding one over the other, I was able to remove the battery in 15- 20 minutes. Removing the remaining adhesive was VERY tedious. Eventually I settled on CAREFULLY applying small amounts of remover with the syringe and using the spudger (both pointy and broad ends) to scrape the remainders off. I cleaned the residual with Q-tips dipped in remover (buy a big box of Q-tips), refastened the speakers, installed the new battery, closed the case and voila.
    James Suojanen - 回复
    Question, on the first image above you can read a serial and other information ... The creator of the guide could you confirm if it corresponds exactly to the Apple serial on the box? I wonder why I had the laptop in assistance to replace the GPU, and other problems were born once I returned ... to which removed the cover I saw this sticker and I immediately had doubts about it.
    Antonino Auteri - 回复
    I too found the need to completely teardown the laptop onerous and risky. I’m not certified in anything hardware but I’ve been doing my own repairs for a while. I watched the video referenced above and read the comments there. With some changes, here is what I did, which worked perfectly and minimized the risk, for a whole additional $3 in parts, just myself and in under an hour:
    1. Go to hardware store and get 2 4” bolts ($1 each) and a coil of 20 gauage galvanized wire.
    2. Wrap one end of the wire a few times around one bolt, then tie it off with a knot. Do the same with the other bolt, leaving about 10” of wire between the two.
    3. Follow steps 1-4 in this guide
    4. Slip the wire under one of the outer batteries (use a card or spudger to help get the wire underneath
    5. Grip both bolts with one hand and rock them back and forth, pulling the wire under the battery, using your other hand to hold the case. This should take about 2 seconds (seriously). Repeat for other outer batteries
    (continued)
    steve - 回复
    6. Pull the plastic frames away from the left and right sides of the center batteries.
    7. Repeat steps 4 and 5 for the two center batteries.
    8. Jump to step 55, then reassemble.
    Note: when installing the new battery, ensure the part closest to you is UNDER the two plastic tabs.
    Worked perfectly.
    Link to video: https://www.youtube.com/watch?v=fupkPz55...
    Note: using the nylon thread with that much effort is crazy. Use the wire or fishing line.
    steve - 回复
    cool.
    removed everything and have now 88% after 2 times calibrating and smc reset
    wouldn’t have liked to do everything again, but this seems like a possible solution :)
    Dennis Britsch -
    i just got my Kit and started the procedure, i decided to try if i can get the bulged batteries out with a fishing line, which worked fine. No need to use any solvent and even not too much force was needed to get the line under the batteries. I was able to remove the batteries in about 5min, used another 10min to clean the case from the residue, and put in the new battery. All togehter about 20min of work. I´m very happy with the result, Macbook stays now back on its feet, closes correctly and trackpad works as expected.
    manu - 回复
    Also departed from procedure immediately after STEP # 4 as per JOEL’s recommendation …used a small chunk of fishing line and it worked sans solvent…easily ! Spudger worked quite well to initially position the string /line & the ifixit ( ‘credit’ ) cards were nice for final dislodging of each battery segment from the last bits of residual gooey adhesive , AFTER working the fishing line back & forth down the length of the battery as much as possible. With the old battery out of the way, I used a razor blade to clean out the remaining bits of adhesive gunk. ( Decided NOT to use solvent here, either.) Took me every bit of 1-hour.
    One thing that helped ,too, was a cheap pair of cotton gloves coated on the palm side w/ latex. This kept my fingers comfortable from the pressure of the fishing line & allowed more of a range of force …since I wasn’t wincing from saw-cutting myself !
    John Joslin - 回复
    I skipped steps 5-33. These steps are completely unnecessary. I used the back of a flat tweezers to separate the battery from the case.
    support64 - 回复
    so the only reason they are taking all the stuff off before the battery is because of the solvent?
    I used cards and dental floss and just took the battery out … It was a pain in the butt but i got it out with out using the solvent remover solution.
    GR Verner - 回复
    I skipped steps from 5 to 33 and directlychanged the battery (before disassembling all). Worked fine.
    derdietrich - 回复
    I also skipped all the additional disassembly. I used cards and wire to cut through the adhesive quite easily. I also did not apply any tape on the new battery. The Mid-2014 laptop seems slim and tight enough to keep the cells from moving and the two screws at the power connector area seem to stabilize the connection and battery as a whole. Such STRONG tape seems unwarranted for the amount of squirm room in such a tight compartment.
    P.S. Remember, while you have it open, clean, clean, clean!!!
    jyee - 回复
    Thanks guys for all the tips. I followed the pragmatic way of cutting short and really taking battery out only. Thanks to the cards it worked well and none of the liquid made it to any other part of the computer. Put some efforts in to properly clean the remaining glue after battery was out - but looked good and this message comes from the old mid 2012 15” Retina modell - but with the new battery in - and all is fine. I am happy - thanks to the short cut encouragement.
    Jochen Färber - 回复
    Also skipped steps from 5 to 32. I used the supplied cards and a piece of string, i.e. braided nylon twine, (thickness 24). and used supplied acetone sparingly, mostly to the middle section. It took one and a half hours and another half hour or so for removing the leftover goo. It was demanding but not challenging, just take it slow and steady.
    jkobli - 回复
    Learnt a lot from former comments. Also skipped steps from 5 to 54. Used fishing line to cut through adjective by myself easily, but needed to put on glove to protect hands. I didnt order full package, so used nail polish remover and eraser to clean the base. Looks good and all is fine! Thanks to the short cut method!
    Gerry GU - 回复
  5. 使用撬棒尖端来将三条AirPort天线线缆从 AirPort 板上的插座中径直翘起。
    • 使用撬棒尖端来将三条AirPort天线线缆从 AirPort 板上的插座中径直翘起。
    • 此线缆的连接插口很脆弱。请注意分离位置是在连接器上方链接部分而不是在底插或线缆处。
    • 重新插回时可以在小心的对准插口位置后利用撬棒较宽的平面部分水平发力下按。
    will this procedure remove my warranty? I have applecare for another 2 years, Laptop was dropped on the side, there is a very small dent on the side of I/O.
    Oleg Babko - 回复
    Yes, this voids your warranty.
    max damage -
    If I am facing the MacBook like I'm surfing or typing, this I/O board is referring to which side of the MacBook? Left or right side? How about replacing the other side of I/O board? The other side I/O port are part of LogicBoard? If I want to replace it, need to replace the whole LogicBoard? TQ.
    Delta - 回复
    These are notoriously difficult to remove. I actually damaged 2/3 of the connector pins during the process. Thankfully i was still able to fit them in place. This step should not be underestimated.
    Alvin Chua - 回复
    If you are not replacing the display case assembly, you can opt to leave all 3 connectors attached and remove the Airport card with them connected. You will need to carefully manage the card and attached cables so as not to damage them(masking tape) as you proceed with disassembly/reassembly. Step 6 will need to be done carefully (camera cable connector). I did it after step 8. I took a picture of routed cables as well before I removed them from channel.
    lamajr -
    I damaged 1/3 of these litte guys, how did you get them back together?!
    is there a way to replace the antenna?
    Fabian Schweinfurth - 回复
    unless you have really tiny fingers, a tweezer helps, just be careful not to damage the wires or the board as your holding each cable in place. Oh and take your time - this is like the most frustrating step in the process, imo.
    Arn Custodio - 回复
    The order of the cables doesn't seem to matter when re-attaching. It also might be helpful to unscrew and eject the airport card. Having it free can give you a better angle.
    joey - 回复
    Definitely the hardest step (when putting it back together). The three pins were on progressively longer plugs, so I put the shortest one on the left and so on. This helps with getting the right angle. I used my fingers and the spudger to guide them back in. It took me easily 10-15 minutes to do this. The pattern that worked eventually was to first adjust the angle of the pin head so that it's x/y/z axes would line up perfectly with the connection if you are able to bring it together just so. If you're off on any of these while you try to bring it together, you won't be able to just click it down at the end. Good luck!
    Thomas Kunjappu - 回复
    Agreed, for some reason, the middle one was stubborn — and I was worried the amount of force I applied to push it back on was going to break something - but it did pop back on.
    Jer -
    I would never remove those tiny plugs unless I absolutely have to. And we do not have to remove them, just the card itself…
    Jurgen -
    After reading so many reviews on ifixit and other sites regarding the difficulty of replacing my MacBook Pro retina screen assembly, I was a bit nervous. Using this walk through made it super easy. Thank you so much for taking the time to create it!
    cabcpa - 回复
    Removing these 3 tiny cables is completely unnecessary. I removed my fan last week to clean and it slips by these cables. For some dumb reason i wanted to follow this "correct" procedure and now one of the gold connections detached from the wire like it was nothing. Seriously, dont do this. I used a spunger and was very delicate putting it back on... And look what happened. SKIP!
    travismlive - 回复
    Yeah, I agree, just leave the airport card attached to the pins and remove the card itself. Then you won’t have to fuss with these connectors.
    Jer -
    @tmm Your right on! Just finished replacing my right fan and your tip saved me from messing with these tiny cables. I totally understand your frustration as I was too just about to stick to the procedure, but if it’s any comfort your tip helped someone… so don’t be surprised being rewarded by some good karma :)
    IT’S UNNECESSARY TO DETACH THE 3 TINY CABLES FROM THE CARD, JUST DETACH THE AIRPORT CARD WITH IT’S CABLES ATTACHED BY GRABING IT FROM BOTH SIDES USING TWO FINGERS AND GENTLY SHAKE IT UNTIL IT DETACHES. THEN MOVE THE WHOLE THING A BIT ASIDE.
    THIS STEP IS ONLY NECESSARY TO MAKE WAY TO THE FAN CONNECTOR UNDERNEATH.
    There is one thing though I find missing which concerns:
    1)The rubber heat sink cover
    2 The AirPort/Camera cables
    3)The IO board cable
    All these are “glued” to the fan and you need to peel them off gently using the spudger, now while I noticed that some glue remains on each cable so they will kinda stick again, I wonder what kind of glue is this and where one can buy it?
    Itai -
    These individual instructions are re-used across multiple tutorials. If you are replacing the battery, you probably won’t need to remove the three connections from the Airport card; if you are replacing the display, you definitely need to replace them, because they are connected to the display. I just replaced the battery and the display in a single activity, so I pretty much had to remove everything. Also agree with a previous commentor that it’s easier to reconnect the cables before the card is reconnected to the system board.
    ChrisMBP -
    travismlive is right, you do not need to remove these cables or the airport card. Just remove the I/O board cable, undo the screws, and detach the antenna cables from the fan where they are glued with a spudger. Unlock the ZIF-socket and the you can wriggle the fan out. Probably saved my airport card, thanks travismlive!
    Jasper - 回复
    I only successfully reattached 1 of the 3 AirPort cables, I just taped the other two. But the AirPort seems to work fine. Do these also have anything to do with Bluetooth though? I do seem to have trouble with Bluetooth after this operation. In any case, it was worth it... I replaced the screen with a new Apple screen for less than 1/2 the Apple Store wanted! Thanks!
    Douglas Johnston - 回复
    Would soldering them back in place be better than taping? I certainly don't want spare solder on my motherboard, so I figure that'd be a last resort only if I lose AirPort connectivity.
    Assembly is a nightmare. If rightmost cable is not connected, BT will not work.
    Radoslaw Przybyl - 回复
    the hardest step is reconnecting the airport antenna cables. just have patience< and use tweezers, spluger and a q-tip.
    Frederick Rae - 回复
    The three cables have different lengths. The longest should to the farthest pin, medium to middle, short to nearest.
    Sam Jomaa - 回复
    Also, having the right tools will make the job really easy. I used a spudger similar to the one recommended on this web site. But i had ordered a complete kit from amazon.com. I did not have any problem removing or re-attaching the pins.
    Sam Jomaa - 回复
    tweezers to hold the cable and the flat part of the spudger to push down on the connectors is the easiest way to re-assemble
    Jon Ocampo - 回复
    Replacing these were the most difficult step I encountered. I finally determined that it took slight back and forth twisting of the cable (from left to right as viewed from above) to cause the connector on the cable to twist into position so it could be pressed down.
    chuck60 - 回复
    I read your step and you are 100% correct. This helped me tremendously. Thanks!
    Achilles -
    Use leverage with tip of a spudger, it’s not that difficult to pry the cables.
    When you reassemble, use a tweezers to put the connector on the right position and push it down with a finger on the other hand.
    Grab the neck of the cable when using a tweezers.
    eskoo - 回复
    Several of the people above mentioned not disconnecting these three wires. You must remove and replace these if you are replacing the entire display which is what these instructions are about. This is the most difficult step as others have noted. Just be careful and make sure you have the cable level before you start pushing down.
    Walt Goede - 回复
    lamajr - 回复
    Reassembling: What makes this so hard? From all appearances I’m just pressing a squat sleeve-and-pin connector down onto the female counterpart. It appears to be circular and therefore not needing to be oriented radially in any particular angle. It doesn’t look hard at all! Does anyone understand what the subtlety is that causes everyone so much grief?
    Chapman Harrison - 回复
    Reassembling: as so many as commented, this is incredibly hard - and inexplicably so. From all appearances I’m just pressing a squat sleeve-and-pin connector down onto the female counterpart. It doesn’t look hard at all! But I couldn’t do it.
    Here’s what seems to have worked for me: with my left fingertip on the cable holding the connector directly above the female, I used the spudger to press down the flat back of the connector, initially at the top and then sliding along toward the neck. I used normal pressure, and voila, when I lifted the spudger away the wretched wire didn’t spring up again. It was like it wanted to be rocked, or stroked, once, from top to neck, rather than pressed straight down.
    I skipped to step 34. Just pushed up the speakers so that they don’t touch the body.
    Sascha Gl Richy - 回复
    I totally agree, this step is not tagged contrarely to others while it is the most dedicate !!! 1/ A warning should be added (the 31 comments should have done it…) 2/True it is possible to skip this step. Result for me : 1/3 damaged (the left one). Luckily, everything seems to work airport, bluetooth (so far, I haven’t tried Airdrop yet). Really disappointed by this guide is way below the iFixit’s standard…
    Antochny - 回复
    Can anyone help me? I would like to replace my speakers. Which steps can i skip?
    Manzil Monabber - 回复
    I have completed replacing my speakers and this step was not needed at all.
    I just completed the full screen assembly replacement with 90% success I guess. Like many others noted, this was the hardest step, and one them (leftmost) was extra hard, but I eventually got them all back in. However, I don’t have 5G wifi anymore. 2.4 g works fine, bluetooth works fine, and the screen, camera, and mic are all perfectly functioning. I just can’t connect to 5G wifi. Is there a fix for this?
    Aaron C - 回复
    Absolutely no need to take apart the whole thing, get some strong fishing line and slowly saw the adhesive away. Once the battery is out, (if you are prone to be clumsy just cover/ shield the rest of the computer, than use GOO GONE or the like waiting a couple minutes to scrape out the old adhesive. The only reason they make your take everything out is that they assume you are lazy and will be using the adhesive remover which could damage the rest of the computer if allowed to splatter etc. Just save your self some time and stress, get strong braided fishing line ( works way better than floss or string as it is of a smaller diameter and isn’t smooth and helps the sawing action), and work your way around each cell. This is still way shorter than removing the entire computer and much less likely hood of damaging sensitive connectors.
    Pia Paeh - 回复
    Putting these 3 cables back was a lot of work. I bent the outer side of the middle cable, but was able to fix it with fine tweezers from the repair kit.
    olegpsh - 回复
    I did a screen replacement recently using this guide and the disassembly/assembly was fine - very good instructions. But when I turned on the machine there was a very fine flickering, snow-like interference, especially noticeable on black backgrounds. I assumed it was a faulty replacement screen and continued to use it. Recently, I had to change out the battery so I dissasembled the screen again to see if reconnecting it would fix the problem. Now it is perfect. I think the problem was that the left-most (shortest) airport cable connector was touching the black screw next to it on the board and shorting out. Be careful to position this connector well away from that screw.
    rumblefish - 回复
    I found placing the spunger under the part of the connectors AWAY FROM THE WIRE (top and/or side depending on which of the three you’re finessing), and then rocking them gently from side to side pops them out gently.
    MFMauceri - 回复
    I read the note above and managed to fold the card out of the way. I’d put it in a paper envelope to stop it touching anything as it flaps around. The bag also stops static build up and reminds you it’s there ! The wires on mine were held down with two strips of tape, the pointed spudger? pushed along the length of the wires widened the tape loop when I pushed firmly but carefully. Once widened, tweezers can open it fully .
    Simon Anthony - 回复
    I skipped the step of removing the airport antenna cables and removed the airport card with the cables since so many users said it was extremely hard to get the airport cables back on properly. By skipping the airport cable removal I save a lot of potential headaches and performing this task was not any more difficult to do.
    Timothy McDaniel - 回复
  6. 使用撬棒的尖端来推动相机线缆位于逻辑板插座上的链接头。
    • 使用撬棒的尖端来推动相机线缆位于逻辑板插座上的链接头。
    • 确保推动方向与逻辑板相平行,先推动一侧,然后让链接头从插座中“走”出来。如果强行将其撬起则会有损坏部件的可能。
    I've broken camera connection socket, is it repairable?
    Sergey - 回复
    Same for me too just take the socket from your broken screen and cut it off and solder it onto the new screen. It was really hard because it's so small but I did it.
    bhayes9614 -
    This is much easier if you do step 7 first so you can pull lightly on the cable and take the tension off the connection caused by the stiff cable.
    mayer - 回复
    This tip worked for me.
    eskoo -
    If you are removing the right fan it is not necessary to unplug the camera cable. You can slip the fan out underneath the cable.
    noahtfu - 回复
    Hi! Camera flex cable is from MBP Retina Mid 2012 & Early 2013. Not Late 2013 :) Edit it please.
    kramerigor - 回复
    the tip of the middle 3 wire was broken on the replacement screen. I didn't connect it and everything seems to work fine, mac hardware test says everything is fine... Is it possible?
    micheleroger - 回复
    Yes. They are wifi antenna cables. Missing one antenna won't affect much, and won't show up in any hardware test.
    Jason Amri -
    Push on the little wings, from right to left.
    Julian Wood - 回复
    This is the hardest part of disassembly! Arguable hardest part of re-assembly too, other than the airport cables
    Jon Ocampo - 回复
    The instruction is not clear to me at all. Frankly the comments mentioning things make me uneasy about proceeding further.
    Ben Moore - 回复
    This came off for me - now my computer’s fan is running high constantly, and “Kernel_task” is using 500% of the CPU even though nothing else is running - what can I do?
    Ryan Brown - 回复
    Did you ever get the fan to stop? how?
    Cyd Trice -
    It is very important to note here that you are NOT pushing up. You are pulling the cable back toward the fan. Doing step 7 first makes that easier. I misunderstood the instruction here (as others seem to have as well) and broke this part. I’m fine with not having a camera on this computer so I’ll leave it or ask my son to help me solder it later.
    Jen Wells - 回复
    can you give guidance on the soldering? Im new to it and dont want to burn anything / especially the wrong thing!
    Cyd Trice -
    The wing closed to the edge of the chassis is completely stuck. I’ve worked on it for an hour. The other wing moves freely. I’m not sure what to do now.
    Charles Lindauer - 回复
    The connector is very tight - I couldn’t even see the join between cable end and the socket and couldn’t see the “ears” on the end of the socket. And, of course, pulling didn’t help. I eventually used tweezers to start things off, gripping on the metal of the socket right where the invisible join was. What a delight to have the join open enough to see! After that, it was easy.
    jerryl - 回复
    Thank You Jerryl - The tweezers did the trick. They want to pop out so you can use your other hand to apply slight downward pressure to keep them in place. Work both ends of the tweezers gently back and forth and you should start to see the gap get bigger.
    Chuck Barton - 回复
    I used tweezers and the spudger. Take the point of the spudger and push on one side of the “dog ear” while supporting the other side with the closed tweezers on the cable side of the dog ear. (Could use a second spudger) work one side the move to the other repeatedly until the connection disconnects.
    This is allows You to push and support simultaneously and minimize the chance damaging the connector.
    Jonathan Dowling - 回复
    Removed cover (Step 7). Released adhesive. Pulled directly out of socket to the left.
    Pushing out of this connector is ill advised, as no mechanical ledge to push.
    Joseph Gorse - 回复
    The late 2013 Macbook connector is slightly different to the picture, I used tweezers to loosen up first and when the joint appeared used the flat edge of the spludger to push the connector using the gap. Don't rush push this from each side gently till it comes out.
    Lanre O - 回复
    I found this step to be difficult due to the picture and instructions being incorrect for MacBook Late 2013. Unfortunately, I damaged the pins during this step and my camera no longer works. :^( Please update this step.
    Cristina Stoll - 回复
    @xtstoll I looked at two separate Late 2013 units today, and both are indistinguishable from what’s shown in the instructions. Are you sure you’re working on the right model? A photo of what this cable looks like on your laptop would be helpful.
    Jeff Suovanen - 回复
    A MAGNIFYING GLASS really helps on this. The cable’s sheathing may need to be pushed back a tad to find a place to get leverace to work the pin out.
    MFMauceri - 回复
    DO FIRST
    STEP 7 : Untight the rubber heat sink cover on the right fan.
    Lift the cover and flip it back so that you can access the cables underneath.
    STEP 8 : Carefully de-route the cables from the plastic cable guide.
    So you can easily disconnect the connector.
    KRIS - 回复
    Tweezers saved me on this one! Take your time and keep trying (gently) if you're still struggling
    Elizabeth Jolly - 回复
  7. 在右侧散热风扇橡胶垫下方插入撬棒扁平的一端。 在下方滑动,来分离粘合剂。 抬起翻开,你就可以靠近下方的线缆了。
    • 在右侧散热风扇橡胶垫下方插入撬棒扁平的一端。
    • 在下方滑动,来分离粘合剂。
    • 抬起翻开,你就可以靠近下方的线缆了。
    Back (case) side of rubber attachment is flimsy-ish, so need to be delicate when peeling rubber back.
    cahcadden - 回复
    True @cahcadden.
    Worst case you could accidentally tear it off
    (thank god, that didn’t happen to me, but belive me —> it was a close call)
    Shahzad Arif - 回复
  8. 使用手指来将 AirPort和摄像头线缆从风扇上剥离。 线缆粘附于风扇上,所以请小心剥离以免损伤。 小心地将电缆从塑料电缆导轨上卸下。
    • 使用手指来将 AirPort和摄像头线缆从风扇上剥离。
    • 线缆粘附于风扇上,所以请小心剥离以免损伤。
    • 小心地将电缆从塑料电缆导轨上卸下。
    It's a bit tricky to re-route the cables when you're installing the new display, so pay close attention to how they're originally routed, to make sure you don't pinch them or torque them.
    PriorityMail - 回复
    Do we need to use some adhesive to paste them back?
    Aniket Suryavanshi - 回复
    I used scotch tape to temporarily hold the cables in place until I was ready to reinstall the bottom cover, but I removed the tape at that last step (didn’t want it coming loose later, and possibly obstructing a fan).
    ChrisMBP - 回复
  9. 使用撬棒的扁平的一端,将I/O板链接插头径直从逻辑板上的插座中翘起。在重新组装时,首先连接这个端点,因为它不会弯曲。 以类似的方式,将I / O板连接插头从I / O板上的插座中取出。 从MacBook Pro中取出I / O板电缆。
    • 使用撬棒的扁平的一端,将I/O板链接插头径直从逻辑板上的插座中翘起。在重新组装时,首先连接这个端点,因为它不会弯曲。
    • 以类似的方式,将I / O板连接插头从I / O板上的插座中取出。
    • 从MacBook Pro中取出I / O板电缆。
    Note that the Mac has been rotated 180º between steps 8 & 9
    peteyx - 回复
    When reinstalling the io board cable make sure it is the correct way round as in the photo, it fits the wrong way round as well, which results in the MacBook not starting at all.
    bitmat23 - 回复
    ABSOLUTELY ! I found out the hard way. I took a break, came back to me dead computer and wondered - if - this cable would fit the other way round - and voila ! I wish I had read this note first :-)
    Simon Anthony -
    i did exactly the same mistake! Same procedure as well: keep calm, and start again the tutorial.
    every thing work find now
    Guigui -
    Sockets are ZIF with releasing levers on the top. If you pull up on the top padding, you will reveal silver lever handels facing the rear of the machine. Pry up on the LEVER to release the pressure, then pull the lever straight up to release the connector from the socket. DO NOT pry under the edge of the connector to remove these or you may damage the ZIF socket. They may have changed these connectors between models, otherwise I don’t know how this was overlooked in the guide.
    hybrid - 回复
    Confirming, these are indeed zifs for me too. My padding has notches indicating location of lever needing to be raised. Obviously lever is tiny, look closely. If your padding is a clean rectangle as shown in guide, you may not have zif sockets here
    hamiltont -
    Confirmed; if the foam pieces are not perfectly rectangular, you should be able to pry back the side of the foam with the cut-away. It folds in half. You can see the lever under the foam. Lift the handle with the spudger, then when it’s pointing straight up (it flips up), you can lift up on the lever (straight up). This should be done for both ends.
    Patryk -
    I just did this and there are no silver lever handles. The connectors just pop off when you pry on them.
    edc - 回复
    After freeing each end of the I/O cable, it can be left stuck to the right speaker, and then remove them both together in step 14.
    Paul Clarke - 回复
    leave the cable stuck to the fan
    AES - 回复
  10. 移除一颗将AirPort板与逻辑板相固定的2.9mm T5 梅花螺丝(有些时候可能是T6)。
    • 移除一颗将AirPort板与逻辑板相固定的2.9mm T5 梅花螺丝(有些时候可能是T6)。
  11. 抓住AirPort板的短边然后朝着与逻辑板相平行的方向拉出,从MacBook Pro上移除AirPort板。 抓住AirPort板的短边然后朝着与逻辑板相平行的方向拉出,从MacBook Pro上移除AirPort板。
    • 抓住AirPort板的短边然后朝着与逻辑板相平行的方向拉出,从MacBook Pro上移除AirPort板。
    As others have mentioned, it's not necessary to remove the Airport antenna cables. Leave the cables attached and remove the Airport card.
    Swing the card and the attached cables across the fan.
    stvn chng - 回复
    You may lift a little like few degrees then pull parallel when removing.
    eskoo - 回复
    There might be a touch of adhesive, lift first – a gentle touch with the spudger helps.
    Tristan Harward - 回复
    Yes, lift about 5-10 degrees first, then pull out. If you do not release the adhesive, it may be stuck in place and you could damage the card trying to pull it out.
    hybrid - 回复
    I will add to what others have said about lifting the card lightly using a spudger to get the adhesive to let go of the board. Otherwise the card may get damaged.
    jeiboussa - 回复
    Yes. LIFT up slightly on one end to clear retaining pin before tugging.
    MFMauceri - 回复
  12. 使用撬棒的尖端来将右风扇的排线ZIF插座解锁。 请确保您在撬动插座铰链而不是插座本身。
    • 使用撬棒的尖端来将右风扇的排线ZIF插座解锁。
    • 请确保您在撬动插座铰链而不是插座本身。
    • 从电缆顶部开始,在右侧风扇电缆下面滑动塑料打开工具,将其从逻辑板上取出。
    • 取出电缆时要小心谨慎,因为它牢固地固定在逻辑板上。
    I was able to flip the retaining flap while removing the damaged fan but accidentally dislodged after installing the replacement fan. Again, be very careful at this stage. Thankfully my new fan appears to function normally.
    Alvin Chua - 回复
    Easier to do while removing fan.
    mayer - 回复
    The second picture and illustration are not clear enough. The text should say "pry underneath the cable" as I almost broke the fan cable following instruction.
    Kitipong Mork - 回复
    ZIF = Ziero Insertion Force. Once the tiny retaining flap is up, it should slide out easily toward the back. There was no adhesive on my machine, so the cable slid out easily. But be careful if yours is glued down.
    Don Steele - 回复
    I don’t know why, but I could pull the connector out & in without flipping up the flap. And fans are working flawlessly.
    eskoo - 回复
    The pictures were confusing to me so let me add some more context. There is a ZIF socket (Zero insertion force) being addressed in the first picture. This socket has a black top that is currently closed down on the socket. Using your tool you need to lift this flap up to release the wire underneath (This release happens in the second step). Hence only pull up on the black flap enough to make it go from horizontal to vertical (Swing flap). Neither picture shows it in the up position. Step 2, Picture 2, Then gliding your flat spudger, you goal is to lift the wire that was in the ZIF socket out by lightly lifting up on both the wire and the rubber cushion on top of it. Make sure you lift both. You are successful when both are lifted up and out and facing vertical instead of horizontal.
    Frank D - 回复
    Great clarification, thank you.
    Hunter Gallagher -
    Can anyone advise what to do if the ZIF socket pulls up from the logic board? I was gentle with it, but it pulled up anyway. The fan and ribbon are fine, but I’m worried this will require an expensive logic board repair.
    Jaysmi - 回复
    To really see which part of the ZIF socket has to be lifted up you should compare the pictures of step 10 and of step 12, preferably in its original size.
    Then you can see that the inner part of the ZIF has to be moved up, away from the batteries.
    Stephan Yaraghchi - 回复
    I managed to broke the side, thought this was pulling on sides mechanism to release, not just upwards. Luckily I managed to attach it and the fan is working.
    Josip Ricov - 回复
    Here is video how to open the ZIF socket. https://youtu.be/MQbqpWkCz94?t=360
    Ketut Sandiarsa - 回复
    Many thanks Ketut, that vid clip really helped!
    Paul Clarke -
    Incredibly poor instructions!!! Thanks to the incorrect wording, I have just ruined the fan connector. There is NO lever. The cable gently slid out, after I borked it. I’m done with IFIXIT and the $@$*!& information. How about a little video clip inserted here. You guys can do better!
    Lorne Shantz - 回复
  13. 拧下固定右侧风扇到逻辑板的三颗螺丝如下:
    • 拧下固定右侧风扇到逻辑板的三颗螺丝如下:
    • 一颗 4.4mm T5 梅花 螺丝
    • 一颗 3.9mm T5 宽头梅花 螺丝
    • 一颗 5.0mm T5 梅花螺丝 带有一个2mm套管。
    With most parts, its easier to leave the screws in the holes parts they come off with, and have small containers or a layout to do this with so each major part does not get mixed up - too many similar but different screws!
    AES - 回复
    What I did to separate the different screws, is to take the top of the ifixit essentials-kit (which has lots of small spaces to hold screws) and picked a row of these spaces, which I marked for the cooling-fan screws. So basically I just sort them by lenth: The 5 mm on the top space, underneath it the 4,4mm, and at last the 3,9mm. That way I didn’t loose track, because I was working in tandem with this instruction.
    Shahzad Arif - 回复
    Just a heads up in case anyone else gets confused - in this photo, the cable from the previous step (12) is still connected. It should be free from the board so that fan can actually be removed.
    In my case, the 3.9mm screw was connected to a spacer that sat flush to the motherboard. I misplaced this spacer and had to take the computer apart twice to find it… Make sure not to lose it if you have one!
    Daniel Kirk - 回复
  14. 从MacBook Pro中提起移走右风扇。
    • 从MacBook Pro中提起移走右风扇。
    • 装回风扇时,比较简单的方法是先连接风扇电缆,而不是先安装三个风扇螺钉。
    Do I need to use thermal paste when installing new fan?
    1 0 - 回复
  15. 使用撬棒的扁平一端来翘起左侧风扇上的橡胶导热槽。
    • 使用撬棒的扁平一端来翘起左侧风扇上的橡胶导热槽。
    This came of super easy as the glue seemed to have dried up or something of that nature; anyone know if this is an issue?
    Also it seemed like there are clips on sides of the rubber heat sink which I couldn't work out how to clip it back on, so I placed it back where it was after and it seems to be ok; maybe it isn't meant to clip on hard and rather just to be a security measure. Anyone else had this?
    RT0 - 回复
    I had the same experience as you this was super easy to remove as well.
    spearson - 回复
    Glue was long gone. It just flops over by itself.
    Jer - 回复
    I have this feeling that my “noisi fan” was actually the loose end of this rubber cover. So verify that you insert rubber clips back to its slots on under the edge of the sink.
    Albert Stein - 回复
  16. 移除下列三颗将左风扇固定在逻辑板上的螺丝。
    • 移除下列三颗将左风扇固定在逻辑板上的螺丝。
    • 一颗 4.4mm T5 梅花螺丝。
    • 一颗 5.0mm T5 梅花螺丝, 包含一个2mm套管。
    • 一颗 3.9mm T5 宽头梅花螺丝。
    check if screw marking here is right
    Oleg - 回复
    One 3.9 mm T5 Wide Head Torx screw
    what exactly do you mean by wide head torx screw? Is that another torx screw i should buy?
    best regards,
    Seth
    sethroot - 回复
    “Wide Head” just refers to the head of the screw being a bit wider than the others. It shouldn’t affect the size of the tool needed. That said, I also was unable to remove this screw with a T5. The screw on mine looked corroded. I ended up using Vampliers (great tool).
    maccentric -
    seems like T5 is the wrong screwdriver for the "3.9 mm T5 Wide Head Torx screw"
    ryanbraganza - 回复
    T4 seems to have worked for me
    jonathaniscarroll - 回复
    i tried unscrewing the screw with a yellow circle around it but it is not unscrewing i think it is stripped
    Habib Sy - 回复
  17. 使用撬棒尖端来将风扇排线从ZIF插座上解锁下来。 请确保您在撬动铰链部分而不是插座本身。 从线缆顶部开始,在线缆底部滑入一个塑料打开工具来将线缆从逻辑板上卸下。
    • 使用撬棒尖端来将风扇排线从ZIF插座上解锁下来。
    • 请确保您在撬动铰链部分而不是插座本身。
    • 从线缆顶部开始,在线缆底部滑入一个塑料打开工具来将线缆从逻辑板上卸下。
    • 卸下电缆时要小心谨慎,因为它牢固地固定在逻辑板上。 如有必要,请使用iOpener或吹风机加热电缆,以便软化粘合剂并使其更易于清除。
    • 从设备上取出左风扇。
    a question out of curiosity is it possible to remove that left fan completely and use and external fan instead of it?
    and what is that fan for? is it for CPU or VGA? i noticed someone was referring to that fan as vga's fan.
    Albert Einstein - 回复
    I can't imagine any scenario why one might want to do that Einstein. An external fan on a laptop? Seriously?
    maccentric - 回复
    I would say that my cable was permanently adhered, or at least requires chemistry to remove the adhesive. Definitely check if fan parts are in stock before attempting to remove the cable that doesn't seem to be coming loose from the motherboard.
    orders - 回复
    Couldn’t manage to “flip up the retaining flap on the left fan ribbon cable ZIF socket.”, in fact think I may may broken a piece off. In the end just pulled out the cable by sliding it down and out (maybe I did manage to loosen it after all). Cable didn’t appear to be glued down thankfully.
    Chris McKay - 回复
    Holes on the new fan did not exactly match up and ribbon cable has more tension as a result -
    I had to cut the loop on the mount for the 4.4 mm T5 Torx screw. Not ideal.
    Scott Evans - 回复
    So, what do I do if I break the connector on the board? Serious question, yes I did it. Now, how do I get the replacement part?
    Amin Shah Gilani - 回复
    The retaining flat is super fragile. And I doubt there’s any practical way to replace it. Don’t know if the connector still works ok without the flap.
    Steven DeRose - 回复
    After I exchanged the fan it‘s super noisy. I ordered at the ifixit shop and it seems it works but it‘s just super noisy. Does anyone know why?
    Thanks
    Karsten Hullebeck - 回复
    I have the same issue with my newly replaced fan…sounds worse than the broken one - will need to check with the ifixit team…
    Markus Meßerschmidt -
    reported this to the support team and got a replacement within one day. The new part works fine - no noise at all, old one is on the way back. Thank you iFixit!
  18. 拧下把SSD固态硬盘固定到主板的 3.1 mm T5 Torx 螺丝。
    • 拧下把SSD固态硬盘固定到主板的 3.1 mm T5 Torx 螺丝。
    When I got to this step I realized the screw was stripped. I'm unsure if it was stripped by my efforts -- I used the prescribed P5 screwdriver that was also used for the other screws, and the screwdriver still works when putting the lid back on.
    So to extract the stripped screw in Step 5 I've ordered iFixit's Precision Screw Extractor Set.
    Now I'm wondering if I also need to find a replacement screw since I probably won't be able to use the stripped one again after it's been extracted? The screw is called: 3.1 mm T5 Torx screw as per this guide .. the best I can find on eBay are screws called: 1,4 X 3,1 mm Torx T5 or 1,5 X 3,1 mm Torx T5 ... will one of these work? Would I be able to just go to a hardware store and find the proper screw or is it a specialty item?
    Lorte Messenger - 回复
    I'm sure you've long since figured it out, but for the benefit of anyone else reading this, a P5 is not a T5. It's a different screwdriver. The driver for the screws on the outside of the case will not work on the screw holding the SSD. I'm not sure why they left it off in the list of tools at the top.
    Dave Miller -
    The screws on the outside of the case are Pentalobe.
    The screw for the SSD is Torx.
    Both drivers are (now) on the list of required tools.
    (However, my devices both have a T6 head, not T5. May have been after-market.)
    jkgarrett17 -
    For the Macbook Pro Retina 15" Late 2013 models, I've heard the SSD is soldered to the logic board. This guide is for that model, but it doesn't address the soldering issue. Have I just been misinformed on this issue? Has anyone tried it with the late 2013 model yet?
    Elaine - 回复
    The SSD is not soldered to the board. You maybe thinking of the RAM which is soldered. (thank you apple) *dripping sarcasm*
    Ryan Tucker -
    I was needing to send my mid 2014 15" MacBook Pro in for a keyboard repair, and my company IT department shipped me a loaner of the same model except that it had a smaller SSD in it than mine, and said I should swap the SSDs between the two and then send mine back with the smaller drive in it to get fixed. I've been unable to swap the drives because neither mine nor the loaner (which are both the same model) appear to have a T5 screw holding the SSD in place. Both of them appear to have a T4, not a T5 (whatever it is is smaller than a T5 anyway, so I'm guessing it's a T4). So now I'm on hold until I can find a T4 screwdriver.
    Dave Miller - 回复
    OK, got the new tool set, and yes, it really is actually a T5 screw, you just need a really sharp driver. My existing T5 driver was getting a little dull on the tip. So make sure you have a really new/precision T5 driver/bit to use (and again I'll point out that ifixit failed to list this tool in the list of needed tools at the top).
    Dave Miller -
    It's definitely a T5, just takes more control vs only strength. I went left and right in small increments while pushing down to let the screwdriver dig in before slowly being able to loosen it up.
    Toan Tran - 回复
    Both of my A1398 computers (Mid-2012 Retina 15” and Late 2013 Retina 15”) have a screw that my T6 bit fits perfectly. If using a T5 screwdriver/bit makes your screw seem stripped, try the T6.
    (The 2012 was purchased second-hand, and the 2013 was purchased from a dealer known for unauthorized upgrades; it is possible my screws were swapped.)
    jkgarrett17 - 回复
    I’m pretty certain this screw is a tiny bit larger diameter than the others — I mixed it up and tried to use it elsewhere, and it wouldn’t fit, so IO swapped in another and set this one aside. Later when I got to this point, other screws were too small and wouldn’t grab. So I tried the one I had set aside earlier, and it fit perfectly. That might explain why this one seemed “stripped” to another commentator.
    Steven DeRose - 回复
  19. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  20. 轻轻提起最右边 SSD 固态硬盘,把它从主板的槽里直接滑出来。 轻轻提起最右边 SSD 固态硬盘,把它从主板的槽里直接滑出来。
    • 轻轻提起最右边 SSD 固态硬盘,把它从主板的槽里直接滑出来。
  21. 使用撬棒尖端将I / O板数据电缆锁向上翻,并将其向计算机的电池侧旋转。 使用撬棒的扁平端将I / O板数据电缆从逻辑板上的插槽中滑出。
    • 使用撬棒尖端将I / O板数据电缆锁向上翻,并将其向计算机的电池侧旋转。
    • 使用撬棒的扁平端将I / O板数据电缆从逻辑板上的插槽中滑出。
    • 请勿抬起I / O板数据电缆,因为其插口非常脆弱。 将电缆平行于逻辑板的表面拉动。
    This is a difficult step. A few images for the removal of the cable would be good/better
    Robert Jan Lebbink - 回复
    Yes, a few more detailed pics here would help. Indeed, general pics explaining HOW ALL the plugs and sockets fit would be VERY handy :-)
    Simon Anthony -
    I helped me to use the pliers both to get underneath the canble lock and then push on the wings of the cable.
    Calvin Truong - 回复
    Used fingers on the cable lock.
    Joseph Gorse - 回复
  22. 移除两颗固定I/O板的3.1mm T5 梅花螺丝。 小心地提起I/O板,并将其从底壳中移除。
    • 移除两颗固定I/O板的3.1mm T5 梅花螺丝。
    • 小心地提起I/O板,并将其从底壳中移除。
    This did not want to come out. The bottom was really wedged in there good. I had to pry up the bottom part with a screw driver. The funny thing was it was really easy to put back in. *shrug*
    Jer - 回复
    it actually has an extra screw that needs to be removed.
    Reid Rankin - 回复
    Thank you. Removing the screw by the heat sink really helped get this board removed.
    Christopher Hofmann -
    It helped me to push the IO board further into the casing and then lifting.
    Calvin Truong - 回复
    i/o cable was much easier to remove after freeing the i/o board & slightly lifting it. SK
    Stefan Kirchanski - 回复
    I believe, the IO Board can stay where it is, for logic board replacement..?
    smirgle - 回复
    On a 2014.5 design, these instructions should be revised on this process. The heat pipe needs to be removed first if one were to remove the I/O CCA, Reason being, the CCA is installed first into the case and then the heat pipe contact tab lays atop the CCA under the plastic injection molded part. This injection molded piece part secures the tab to the CCA to ensure optimal contact thus, ensuring heat is wicked away from the CCA.
    So when I see comments regarding how it is easier to install than remove, that is an indicator that the user was unaware of how to correctly assemble this component thus, the CCA top side substrate is sitting below the heat pipe tab vs. the other way around.
    This will induce a thermal issue on the I/O CCA and also, possibly short out the board when the conformal coating and painted surface of the heat pipe wears off due to vibration when cables are connected.
    While I like these instructions, I would overhaul them and revise them.
    Christopher McKenna - 回复
  23. 使用撬棒扁平一端来从逻辑板上翘起耳机孔链接插头。
    • 使用撬棒扁平一端来从逻辑板上翘起耳机孔链接插头。
    After connect the cable aux is not working
    deepak selvanathan - 回复
    Mine is not working as well after reconnecting, what to do now?
    Guillermo Pichardo -
    Strange, I'm working on the same model, and it doesn't have a flex here. It's soldered.
    Ross Karnes - 回复
    Same as Ross. No cable to pry. It’s soldered. But looks like I can continue on anyway
    Cameron Melvin - 回复
    Mine not soldered.
    Paul Clarke - 回复
  24. 使用撬棒扁平一端翘起连接到逻辑板上的左扬声器插头。 使用撬棒的尖端来翘起连接到逻辑板上的右扬声器插头。
    • 使用撬棒扁平一端翘起连接到逻辑板上的左扬声器插头。
    • 使用撬棒的尖端来翘起连接到逻辑板上的右扬声器插头。
    • 请确保撬动线缆头,而不是插座本身。 撬动插座将会导致其与逻辑板分离。
    This step could use an image showing the cable lock in the "up" position, releasing the connector. It is hard to see how it works in the "down" position. I think this is the actual connector - there are images in the PDF linked here:
    http://www.ddknet.co.jp/English/products...
    My MBP has an intermittent connection in this keyboard cable. It would be good to know where to buy a replacement!
    Rich - 回复
    Pry the speaker connectors *up and out*. Doing it from the cable's sides, next to connectors, is easier.
    Kitipong Mork - 回复
    Not sure what happened, but when I put it back together, i barely had enough room to plug this back in. It’s like the cable shrunk. I had to really yank on it to get it to fit.
    Jer - 回复
    Adhesive under the left cable made it hard for me to remove it. The right one came out very easy.
    Calvin Truong - 回复
    i broke off all the connectors to the logic board any fix for this ?
    Steven Rai - 回复
    be gentle - lever under each edge of the connector - you may have to do one side then the other , but the connectors come out easily enough
    AES - 回复
  25. 使用撬棒扁平一端来将键盘链接排线的ZIF插座解锁。 请确保您在撬动铰链,而不是插座本身。
    • 使用撬棒扁平一端来将键盘链接排线的ZIF插座解锁。
    • 请确保您在撬动铰链,而不是插座本身。
    • 使用撬棒扁平一端来将键盘线缆从插座中取出。
    On Re-assembly, I found this to be the hardest part. I resorted to using the provided tweezers and taking turns left and right, working it back into its ZIF socket. If someone knows a better way, please share.
    Fred Anderson - 回复
    I just got done with this and my plus/equal, tilde/apostraphe, brackets/braces and volume up keys are not working. Wondering is this isn't seated correctly or if i damaged something. :-(
    sturmjonny - 回复
    This is one of the fussier flex cables to reconnect. I'd say it's worth opening it back up and reseating it. Only takes a few minutes—just disconnect the battery and then come straight to this step. Make sure the cable contacts are clean (wipe them with a little isopropyl alcohol and a lint-free cloth), and that the connector is clear of any dirt/debris (give it a good blast or two with some compressed air). Make sure the cable is inserted perfectly flat and straight into the connector (this is the hardest part, just takes patience and a little dexterity). Good luck!
    Jeff Suovanen -
    This is really a pain to pull out. You sorta have to lift it up and out - I was worried I was going to flex the cable and break it too much.
    Jer - 回复
    Use the retaining flap to pull the ribbon cable back into the socket.
    Andrew Dunning - 回复
    This keyboard ribbon is so thin. It is like thinner than X-ray film. I was afraid to remove the ribbon from the socket. So, I skipped this step and follow other steps till ‘Step 30’. I didn't remove the logic board as shown in Step 31 and 32. Instead, I removed DC board screws and then DC board from the hole. The cable from the DC board connected at bottom corner of the logic board. I hold the MacBook Pro vertically and lift the logic board slightly and removed the DC board ‘plug’ from the socket. Next, I plugged in the new DC board and followed this procedure in reverse order ( from Step 30 to Step 1). Everything went fine. Important Note: When lifting logic board, please do it carefully and very slowly. Don’t be hurry and don’t break anything. Use magnifying glass and Magnifier in your iPhone to see the tiny parts big and clearly, before removing them.
    Jay Rajamanickam - 回复
  26. 使用撬棒扁平一端来从逻辑板上的插座中翘起触摸板链接插头。
    • 使用撬棒扁平一端来从逻辑板上的插座中翘起触摸板链接插头。
  27. 使用撬棒扁平一端来从逻辑板上的插座中翘起键盘背光灯连接插头。
    • 使用撬棒扁平一端来从逻辑板上的插座中翘起键盘背光灯连接插头。
    Where do I get a replacement cable?
    Where does this ribbon attach to?
    mmx2000 - 回复
  28. 使用撬棒或者您的支架来将麦克风排线从ZIF插座上解锁。
    • 使用撬棒或者您的支架来将麦克风排线从ZIF插座上解锁。
    • 将麦克风排线从插座中拉出。
    A small elastic popped out when removing the cable. Glad I wore the protective glasses.
    Louie - 回复
    Meaning, pull the ribbon cable out horizontally. And be aware that the copper wiring is on the underside of the cable and the topside is just black plastic, so don’t freak out and think you ripped something pulling it out.
    This cable is quite stiff and felt very resistant to being pulled out - I gently shaped a small bread tag piece of plastic in to a hook that would gently and evenly pull the cable back without tilting it to one side or the other. It is also a pain getting it back in when replacing the logic board - very stiff. Be patient.
    AES - 回复
    I just used tweezers.
    curtis phan - 回复
    Looks like it had a sticky patch fixing it near the edge of the board - this would make it unwilling to come out of the socket. The patch looks to be the width of the cable and square, so probably pushing a thin something (plastic) under the cable up to the edge of the board would unstick it.
    Christopher - 回复
  29. 使用撬棒的尖端来的撬动数显示据电线锁,并将其向计算机的电源接口侧旋转。 将显示数据线直接从逻辑板上的插座中拔出。
    • 使用撬棒的尖端来的撬动数显示据电线锁,并将其向计算机的电源接口侧旋转。
    • 将显示数据线直接从逻辑板上的插座中拔出。
    • 请勿抬起显示器的数据线,因为其插口非常脆弱。 将电缆平行于逻辑板的表面拉。
    I'd recommend using the pliers.
    Calvin Truong - 回复
  30. 使用撬棒扁平一端来小心地撬动靠近MagSafe 2连接器的凸起螺钉头上的橡胶螺帽。
    • 使用撬棒扁平一端来小心地撬动靠近MagSafe 2连接器的凸起螺钉头上的橡胶螺帽。
  31. 移除下列六颗将逻辑板与底壳固定的螺丝。
    • 移除下列六颗将逻辑板与底壳固定的螺丝。
    • 1颗 2.6mm T5 梅花螺丝
    • 2颗 5.8mm T5 梅花螺丝
    • 1颗 3.8mm T5梅花螺丝
    • 1颗 5.2mm 突头 T5 梅花螺丝
    • 1颗 3.5mm 银 T5 梅花螺丝
    While you're doing this, unplug the right speaker before you lift the logic board. That is the only step missing in the guide.
    anthony - 回复
    anthony: Unplugging the right speaker connector was done in step 23.
    Kitipong Mork - 回复
    No, you are mistaken . Step 23 was for the LEFT speaker. Anthony is correct stating that right speaker disconnect is missing from this guide. NOW is the time to disconnect the right speaker from the LB!
    lamajr -
    when following on the contrary, its good to check all the ribbons and cables to make sure some are not stuck under board prior to screwing down.
    Robert Gregory - 回复
    green indicator: raised head screw is the one you removed the rubber cap from in prior step. (I removed – and then replaced — a different screw in this step. Revisited it with more daylight and saw my error.)
    auntialias - 回复
  32. 从靠近电池一侧朝着MacBook Pro提起逻辑板。 使用撬棒扁平一端,小心地将MagSafe2 链接头从逻辑板中的插座中推出。 重新安装逻辑板时,请检查标记位置的电缆,确保它们不被固定在逻辑板下面。
    • 从靠近电池一侧朝着MacBook Pro提起逻辑板。
    • 使用撬棒扁平一端,小心地将MagSafe2 链接头从逻辑板中的插座中推出。
    • 重新安装逻辑板时,请检查标记位置的电缆,确保它们不被固定在逻辑板下面。
    • 从顶部顺时针方向:键盘,触控板,电池,右扬声器,键盘背光,显示器,麦克风,耳机插孔,左扬声器。
    In bullet #1 I lifted logic board from left side (nearest battery), tilted toward right side (port side) and pulled to to the left a bit to get ports out of chassis cutouts.
    Then I followed bullet #2.
    Kitipong Mork - 回复
    Going revese order, remember about mic connector and backlit connector. Those nasty small tails are easy to omit. Then you will have to repeat disassembly to get them from under mainboard.
    Agreed with Radoslaw's comment. It might even be nice to have a list of small cables to watch for during logic board reassembly.
    talarohk - 回复
    @radioerewan @talarohk - I think that's a good idea. I went ahead and added a photo showing all the cable locations to check—hopefully it will save someone some trouble! Thanks for your comments.
    Jeff Suovanen - 回复
    This was the single most important pic of the reassembly.
    Mike Jeffries -
    Yes heed everyone’s warning. I had to remove the entire logic board TWICE because i forgot to pull out the antennae and the backlit keyboard plug.
    Jer - 回复
    Yes, be very careful before screwing things down. I also forgot the backlight and the display cables. Had the cover for the display cable out, but not the actual cable. I was able to use tweezers to fish the cables out after removing the screws but without removing the whole board.
    E Carlton Hays Jr - 回复
    My logic board was stuck under the battery PCB, on the top right side of the battery PCB, when viewed like in the first picture.
    I suggest removing the two screws from step 35 holding the PCB down for a little more wiggle room before attempting to remove the logic board.
    Tom - 回复
    I had to go back cause I couldn’t figure out where the logic board connector into (under the board). Funny enough i assembled it and it worked though the night and didn’t come on again. Had to go through the whole process b4 i figured it out. Definitely a good idea to at least breeze through all the images
    Yemi Dalley - 回复
    In link MacBook Pro 15‘’Retina显示器2015年中期主板交换 step 34 the second picture exit the procedure install ZIP
    raul - 回复
    reassembly: so far the hardest step. After getting all the connectors above board, I still couldn’t quite line up the screw holes. It finally turned out that the board was being prevented from being in its full leftward position because the edge of a flange at the top of the USB port was directly positioned against the edge of a flange on the case. I used my thumbnail to press down on the port’s flange so that it slid under the case flange, allowing the board to shift left another half-millimeter and make everything finally line up.
    I Just removed the whole power connector with the main board, seemed a little easier. But that’s just me. Good manual thou.
    Timothy de Wal - 回复
    Had a lot of trouble getting the power cable out. Would definitly recomend this.
    Calvin Truong -
    100% take the power connector out. This guide is amazing but that is something I would change in it. Also I would do step 35 before attempting to remove the logic board. Unsure if there are other implications of this approach.
    kevinhayes656 -
    Am I completely stupid? ...! When I wanted to remove the mainboard, it was still connected to a plug. I searched, but found no indication about this plug. So I had to try to figure out how this plug works. I started trying, which finally tore the console off the board: -o ...: .- ( It is a small plug to the right of the power supply - Pic. #3 top right!!. Comes below the battery. Note, this must be pushed backwards, but may have a lock. What can I do now? If someone has a tip that I do not have to change my motherboard, I am very, very grateful!
    privat - 回复
    I had the same issue where that cable was still connected. I noticed that it was the same type as another one where it needed to be lifted vertically so I did that using the tweesers.
    Jonathan McCaffrey -
    Definitely unscrew and remove the two screws that hold the MagSafe 2 connector then remove the connector with the board.
    The connector that’s not mentioned in the dissasembly manual is the right hand loudspeaker connector. It pulls up, just the same way as the left hand loudspeaker connector does. No locking tab.
    Other than that it’s a brilliant dissasembly instruction manual, well done.
    I took the logic board out, re-soldered U8900 (well known issue with these boards) and put it back together following the manual in reveres. All works fine now.
    One thing that I did which helped. I printed the manual off, then stuck the screws in every case to the page next to where each screw was described using cellotape. So every screw went back exactly where it came from.
    Steve Hills - 回复
    For me, this step was the most hard part when reassemble. Because it is easy to forget or hard to reconnect MagSafe 2 connector properly. I had to give in to professionals just to find out i couldn’t plug this MagSafe 2 connector properly. because of it’s limited angle and i only have 2 hands to do the job while board is lifted.
    kmg125 - 回复
    Instead of disconnecting the magsafe socket, I unscrewed the two screws holding it to the case. Then, when the logic board is removed, the connector will slide out with the logic board. Also useful to if theres a bunch of magnetic junk stuck to the adapter as it becomes easy to clean.
    max - 回复
    Unscrewing the 2 magsafe screws should be put as a step in the manual. I had a hard time disconnecting the cable and a hard time trying to connect it back when reassembling because there is not enough room to do it and i couldn’t figure out that there is a small clip that holds the connector back in place safely. I had to repeat the role proccess of assemble/disassemble twice in order to fix the magsafe not charging issue. I thought i had lost the connector or damaged the board.
    Jean masaoka -
    unscrewing the mag safe as max suggests is a great suggestion. Easier and you can clean the connector.
    klloyd - 回复
    It is not necessary to remove the logic board for this. I did this process without removing the logic board and the 30 steps required to disconnect, remove and reconnect it. It was much easier. Not sure why iFixit insists on removing the logic board: its presence does not block removal of the battery.
    Ben Doherty - 回复
  33. 从MacBook Pro 中移出逻辑板组件。
    • 从MacBook Pro 中移出逻辑板组件。
  34. 移除下列3颗将左侧扬声器与顶壳相固定的螺丝。 1颗 5.6mm T5 梅花螺丝
    • 移除下列3颗将左侧扬声器与顶壳相固定的螺丝。
    • 1颗 5.6mm T5 梅花螺丝
    • 1颗 6.9mm T5 梅花螺丝
    • 1颗 2.6mm T5 梅花螺丝
    • 将扬声器从顶壳中取出,将其放在一旁。
    On my MBP there was an adhesive holding the speakers down. So, "lifting" was not exactly accurate.
    Fred Anderson - 回复
    Yeah there’s a tiny smidgen of glue around the speaker itself. I just slowly put force on it and it ripped off quite easily.
    Jer - 回复
    I have A1398 15 inch , need to replace or fixed left speaker but i can’t find One 2.6 mm T5 Torx screw(yellow one), any idea what to do here?
    Biswajit Patra - 回复
    can you get too the speaker without taking the logic board first
    gianguyen1991 - 回复
    How it possible to get speaker out if system without taking the logic board first?
    Biswajit Patra -
    I only removed the 10 screws and the back panel, the 5 speaker’s screws (without removing the speakers), and the two battery screws, and managed to remove the battery package without undoing anything else. I used a member card (credit card type) to loosen the adhesives under the batteries.
    To remove the rest of the glue, I soaked it with something called Label Off from Biltema (Nordic). Finally, I used methylated spirit (rødsprit) to clean it all up and let it dry for 5 minutes before assembling the new battery pack.
    Andreas H. Parlow - 回复
    Yeah, it seems that all this complexity is just about protecting the speakers from the acetone… a different solvent might have saved me a LOT of work, and damage to my speaker connection.
    Peter Kaczkowski - 回复
  35. 移除下列将右侧扬声器固定在顶壳上的三颗螺丝。 1颗 5.6mm T5 梅花螺丝
    • 移除下列将右侧扬声器固定在顶壳上的三颗螺丝。
    • 1颗 5.6mm T5 梅花螺丝
    • 1颗 6.9mm T5 梅花螺丝
    • 1颗 2.6mm T5 梅花螺丝
    • 从MacBook Pro中移出右扬声器。
    My speaker wire was wedged under the edge of the battery. I proceeded to step 35 and removed the two battery screws. This freed up the cable.
    Fred Anderson - 回复
    Mine was stuck too, and I did what Fred did and waited to step 35 to try and remove the cable. It turned out not to be wedged under anything, but just glued in place.
    I used the flat spudger to loosing the glue underneath the speaker to remove it.
    KC89 - 回复
    My left Speaker makes ugly noise. do I really have to do all the steps or is it possible to just remove the speaker… I guess, it’s necessary.
    Gerd Herzog - 回复
    The speaker has quite a lot of plastic that goes under the board at the top end. There is no option but to remove the covering parts. The notes show which steps can be skipped.
    Simon Anthony -
  36. 卸下电池固定板上的两个3.9毫米T5星型螺丝
    • 卸下电池固定板上的两个3.9毫米T5星型螺丝
    When rebuilding, be sure not to pin the square trackpad ribbon cable connector under the wide keyboard ribbon cable. It should be over the keyboard ribbon.
    I did this step before step 32. Loosening these screws helped me remove the logic board, which was trapped under this thing.
    max - 回复
  37. 工具包里提供的液态粘胶去除剂会影响Macbook Pro屏幕上的抗反射涂层
    • 工具包里提供的液态粘胶去除剂会影响Macbook Pro屏幕上的抗反射涂层
    • 为了保护屏幕,当你拆解时在屏幕和键盘之间放一张铝箔
    I was wondering how it could leak. I suppose you could spill it, or flood the battery space with it and it leaks through the trackpad.
    Jer - 回复
    You’re correct. On most models, it’s unlikely to leak unless you use way too much. The foil is a “better-safe-than-sorry” precaution.
    Jeff Suovanen -
    At this point removing the screen is a matter of minutes so to be safe I just removed the display assembly all together.
    Tom - 回复
    In my case it leaked through the trackpad…. I had a transparent film (instead of aluminium) and it did not damage the screen.
    derdietrich - 回复
  38. 将Macbook Pro的前边正对着你,使用坚固的泡沫块或者一本书把电脑的右边垫起一个小角度 在接下来的步骤里,你需要对电池的右边(外部)使用液态粘胶去除剂。保持Macbook Pro的右侧被抬高可以使粘胶去除剂顺利的流到电池底部去
    • 将Macbook Pro的前边正对着你,使用坚固的泡沫块或者一本书把电脑的右边垫起一个小角度
    • 在接下来的步骤里,你需要对电池的右边(外部)使用液态粘胶去除剂。保持Macbook Pro的右侧被抬高可以使粘胶去除剂顺利的流到电池底部去
  39. 现在你的Macbook Pro已经完全准备好了,是时候给自己做一点准备了。 iFixit粘胶去除剂含有丙酮,对皮肤和眼睛有轻微刺激性。
    • 现在你的Macbook Pro已经完全准备好了,是时候给自己做一点准备了。
    • iFixit粘胶去除剂含有丙酮,对皮肤和眼睛有轻微刺激性。
    • 当你使用粘胶去除剂时请佩戴护目镜。(护目镜在你的工具包里有。)
    • 没有护目镜时不要使用隐形眼镜替代。
    • 防护手套也在你的工具包里有。如果你在意可能会造成皮肤刺激,现在就戴上手套。
    Acetone is not the greatest thing but it’s in common solvents. For example, it’s in nail polish remover. It’s a good idea to do this in a well ventilated area.
    I like how iFixit decides to dye the acetone blue….. it's normally clear.
    Jer - 回复
  40. 打开装有粘胶去除剂的瓶子 在切开涂抹器尖端之前,拧开以松开或取下瓶盖。 这会打开瓶子并在切割涂抹器尖端之前使压力均衡。如果跳过此步骤,粘合剂去除器可能会在切割尖端时意外喷出。
    • 打开装有粘胶去除剂的瓶子
    • 在切开涂抹器尖端之前,拧开以松开或取下瓶盖。
    • 这会打开瓶子并在切割涂抹器尖端之前使压力均衡。如果跳过此步骤,粘合剂去除器可能会在切割尖端时意外喷出。
    • 使用工具包里的注射器吸取少量的(大概1-2毫升)粘胶去除剂
    • 使用注射器吸取粘胶去除剂时一次最好不要超过1-2毫升,避免使用时不小心用得太多
    • 在你继续之前,拧紧屏盖。
  41. 在被抬高一侧的电池的右侧外部均匀地使用少量粘胶去除剂(大约1毫升) 你不需要用很多去除剂。那一小管里的去除剂足够把所有电池取下来两次。
    • 在被抬高一侧的电池的右侧外部均匀地使用少量粘胶去除剂(大约1毫升)
    • 你不需要用很多去除剂。那一小管里的去除剂足够把所有电池取下来两次。
    • 在你进行下一步之前,等待2-3分钟让液态粘胶去除剂渗入到电池下面去
    You don’t need more than 1mil. It will use capillary action and go along the entire side.
    IMHO, you can start wedging about 20 seconds. The acetone dissolves the adhesive almost immediately, and acetone dries up really fast.
    Jer - 回复
  42. 将塑料卡片的一个角滑入电池外缘的底部。 轻微扭转卡片可能会对在电池和上壳之间打开一个小缝隙有帮助 将卡片滑到电池下方更深入的部分,把电池与固定电池在MacBook Pro上壳的粘胶分离开。
    • 将塑料卡片的一个角滑入电池外缘的底部。
    • 轻微扭转卡片可能会对在电池和上壳之间打开一个小缝隙有帮助
    • 将卡片滑到电池下方更深入的部分,把电池与固定电池在MacBook Pro上壳的粘胶分离开。
  43. 抬起电池将其从Macbook Pro的上壳分离,但不要完全分离开。 把塑料卡片放在电池下方避免再次粘合,以便你进行接下来的步骤
    • 抬起电池将其从Macbook Pro的上壳分离,但不要完全分离开。
    • 把塑料卡片放在电池下方避免再次粘合,以便你进行接下来的步骤
  44. 沿着下一个电池的边缘均匀滴上几滴除胶剂(如图所示)。 在进行下一步之前,等待2-3分钟让除胶剂渗入到电池下方。
    • 沿着下一个电池的边缘均匀滴上几滴除胶剂(如图所示)。
    • 在进行下一步之前,等待2-3分钟让除胶剂渗入到电池下方。
    You don’t really need to wait 2 to 3 minutes. It starts dissolving right away. In fact if you wait too long, it will dry up again.
    Jer - 回复
  45. 将塑料卡片的一角划入第二个电池的底部 将卡片插入到第二个电池板下,并将其划到电池另一侧以分离粘胶。 将塑料卡片放在两个电池的底部(或者把电池翻转过来)防止再次粘合,以便你进行下一步
    • 将塑料卡片的一角划入第二个电池的底部
    • 将卡片插入到第二个电池板下,并将其划到电池另一侧以分离粘胶。
    • 将塑料卡片放在两个电池的底部(或者把电池翻转过来)防止再次粘合,以便你进行下一步
  46. 是时候换到另一边了。把书本或者是泡沫块垫到Macbook Pro的另一边 重复之前的步骤把这一侧的两个电池分离 在抬高一侧的电池外缘使用粘胶去除剂,并且等待2-3分钟让其渗透
    • 是时候换到另一边了。把书本或者是泡沫块垫到Macbook Pro的另一边
    • 重复之前的步骤把这一侧的两个电池分离
    • 在抬高一侧的电池外缘使用粘胶去除剂,并且等待2-3分钟让其渗透
    • 使用塑料卡片的一角划入电池底部将电池完全分离
    • 对相邻电池采取同样措施
    • 将塑料卡片放在电池底部或者将电池翻转避免再次粘合,以便进行接下来的步骤
  47. 把书本或者泡沫块垫到Macbook Pro的后侧,靠近铰链的部分 把书本或者泡沫块垫到Macbook Pro的后侧,靠近铰链的部分
    • 把书本或者泡沫块垫到Macbook Pro的后侧,靠近铰链的部分
  48. 抓住电池连接器或者塑料电池框的上边轻轻抬起,把中间两块电池的上边缘暴露出来 抓住电池连接器或者塑料电池框的上边轻轻抬起,把中间两块电池的上边缘暴露出来
    • 抓住电池连接器或者塑料电池框的上边轻轻抬起,把中间两块电池的上边缘暴露出来
  49. 当提起塑料电池框架时,在两个剩余电池的顶部边缘下涂上少量(约1-2毫升)的粘胶去除剂。 在继续之前,等待2-3分钟让除胶剂渗透。
    • 当提起塑料电池框架时,在两个剩余电池的顶部边缘下涂上少量(约1-2毫升)的粘胶去除剂。
    • 在继续之前,等待2-3分钟让除胶剂渗透。
    Instead of this, I just went and got safety wire I have, cut about 2ft, and then tucked it under a batter cell and went back and forth, about 5 times, and it cut through the adhesive. Did that for each cell and battery came right out. I didn’t bother removing the old adhesive, no point imo and saved from any liquids in the computer.
    Rick Hulun - 回复
    I put the laptop at about 45º on its edge so the solvent could flow down, and then when doing the separation it was much easier to get the card between the metal plate and the batteries with the laptop case completely vertical. The double sided mounting tape on the battery is really aggressive and the rubberised compound quite annoying to remove the last traces off the metal plate. You will need a generous amount of solvent on a cleaning cloth or paper to remove the last of the adhesive.
    AES - 回复
    One thng that I have never seen mentioned is that when you remove the two cenre cells it is quite easy to lift the metal plate that sits between the trackpad and the battery. My plate ame right off and was attached to the battery. Luckily I didn’t bend it very much but it would have been nice to know that this was a distinct possibility. The adhesive between this trackpad cover plate (thin stainless steeland the battery is a !&&* of a lot stronger that the adhesive between the plate and the body of the Macbook. It amazes me that I have never seen this mentioned in any written or video guide so be careful
    Peter Newman - 回复
