跳转到主内容
2012年中 15寸 MacBook Pro 一体化机 RAM 更换
你所需要的
  1. 2012年中 15寸 MacBook  Pro 一体化机 RAM 更换, 底壳: 步骤 1 中的图像 1,1
    • 拆除以下十颗固定在机壳上的螺丝
    • 三颗13.5mm(14.1 mm) 菲利普斯十字螺丝 。
    • 七颗3 mm 菲利普斯十字螺丝。
    • 卸下这些螺丝时,请注意它们如何以很小的角度伸出。必须以相同的方式重新安装它们。
    Step 1 (technically step 9 - replacing the base plate) Apparently one of my screws was a micron or two smaller than the others. This screw belongs to the hole above the optical drive, which is also apparently a couple of microns smaller than the others. It took seven attempts to figure which screw had originally been in that hole; all the other screws were too large, but fitted perfectly everywhere else.
    Bizarre much?
    Will - 回复
    It might be a matter of how the screws are driven in, and not that they're slightly different sizes. When I reassembled my MacBook, a couple of the screws, including the one over the optical drive you mention, were hard to drive in and jutted up a little bit instead of sitting entirely flush. Swapping screws didn't help. The solution was to unscrew them and drive them in at a bit of an angle - perpendicular to the slightly curved surface of the back plate where the screw holes were, instead of fully vertical with respect to the ground the Macbook is sitting on. Doing it that way, the screws were easier to drive in and they all ended up flush in their holes. Didn't matter which screws they were. (I swapped a few around just to check after reading this.)
    Andrew Janke -
    I had no such screw issues. Either there are differences in manufacturing lots or I just got incredibly lucky during reassembly!
    xtophr -
    I discovered a great way of organizing the screws. I used an ice cube tray and added the screws in order, keeping the different kinds together. So when it came to reversing the steps, the screw order was an added control step to returning everything in its place.
    leonie - 回复
    Great advise! Love it! :)
    Ririds -
    I used to do that and that worked really great until I bumped it by accident and the entire tray went on the rug! I spent the next day sorting things out.
    Now I use these:
    http://www.sciplus.com/p/50-114-CLEAR-PL...
    The lower ones 50 to a package. I mark them w/ blue tape. Often if it's part like the fans, or the optical drive I'll tape the screws into/near the holes where they belong. I did this a lot especially w/ the bottom screws from MBPs until I'd done so many I knew exactly where the longer ones went.
    Richard Sato -
    I wrapped the screws in a piece of blue masking tape and wrote the number on the little pouch I made. Then I stuck the blue tape pouches on the underside of the case bottom in order.
    Roscoe -
    I take double-sided tape, put that on a piece of paper, stick the crews to that, and label them.
    jelimoore -
    Best I've found is a bead sorting tray. They're like $5 at Wal-Mart and they have a lid that seals up and won't let them jump between containers.
    maccentric -
    I take a sheet of paper, pierce the screws through the paper, take a pen and box the screws and write out what step they belong to.
    Nils -
    @Will, in my case I had the same result as you did. As a reminder to myself the next time I need to open the computer, I put a dot of white paint on those two screw's head and a very, very thin ring of white on the very edge of each hole, that way I'll know they go into those two holes.
    Roger - 回复
    Actually the four screws on the bottom were not threaded all the way up. I didn't check to see if the thread gauge was the same on them, but it wasn't until I had about four screws out (I didn't take them out in the order that the bottom all came out first) that I noticed a difference. I then took out the rest of the bottom ones to see if they matched the two that were already out that weren't threaded to the top. They did. So I went under the assumption that those were all bottom screws and when I put it back together everything went fine with no resistance.
    So there are three types of screws: Four for the bottom, three long ones as indicated and three others that might be slightly smaller than the bottom ones.
    wresnick - 回复
    Hi,
    Although its more than a year since your contribution, I thought you might be amused to know that it is not just that the screws go in more easily when at an angle, Apple actually drilled and tapped the holes at a 15% angle. I too had tried to drive them in straight. An Apple "genius" - I was in for something else - clarified the design for me. It was done so that the screws lay flush on the angled part of the lower case. Nice design, but since Apple encourages DIY memory and drive changes, they could have mentioned this little ... trap.
    H Stahl -
    MacBookPro8,2
    Intel Core i7, 2,2 GHz, RAM 16 GB
    Mountain Lion
    May someone help me?
    I have installed the second drive with ssd 840 evo, but when I try to copy the file from the new drive to the main hd this in not allowed (errore -36)
    Piero - 回复
    To my knowledge you can't transfer a single file more than 4gb. I advise compressing to a bunch of rars to split the file size and moving them individually
    1982sketcher -
    Hey everyone, here's the very best way to PERFECTLY organize your screws AND keep track of the order of the procedure: Get a piece of plain corrugated cardboard and a pen (I like using a Sharpie). For EACH step of the disassembly, draw a simple diagram of the layout of the computer on the piece of cardboard, with dots or Xs where the screws are located. Right after you remove each screw from the computer, poke a hole in the cardboard in its corresponding diagram position with your screwdriver and place the screw in that hole. If there are other non-screw related parts to be removed, you can add notes below each step diagram to remind you of where they go or how they should be placed. This cardboard method is great not only because your screws will not go flying or get mixed up by accident if bumped, but each screw goes EXACTLY back where it came from and you can keep the cardboard as a template for future use if necessary!
    - zerø K
    zeroK - 回复
    These instructions worked great for me. I ordered a replacement battery from Key Power (on Amazon) for my 15" Macbook Pro (mid-2010). Cost was $74 shipped.
    Battery came with 3 different screwdrivers to help with installation. I just needed the one size though, since my 2010 seemed to use all the same size screws.
    Thanks!
    Marcos - 回复
    During re-assembling (put the screws back in), it is important to note that the 3mm threaded holes are not completely vertical, but bent a little bit such that the hole direction is rectangular to the tapered surface. The force of the screwdriver must point towards the direction of the hole. Otherwise the screw gets jammed
    kusi - 回复
    There is a FOOLPROOF WAY TO ORGANIZE ALL SCREWS and other parts removed.
    Print the repair guide.
    Yes, the actual photo of the bottom of the laptop with the circles around the screws.
    When you remove the screw, tape it to the photograph.
    You will tape the screw to the exact location that you just removed it from.
    Same thing with any part you remove.
    splashzoneent - 回复
    Thanks Splash!!! I used your suggested method, and it was perfect: kept all my screws, and i was able to, very easily, put them back in their correct place. I greatly appreciated your feedback. Thank you for sharing!!
    Tommy Kedar -
    Thank you!!! This worked fabulously - even the I.T. people at my workplace were excited as they never thought to do that before. Replacing the battery took about 10 minutes!
    nclarke36 -
    Worked like a charm! Took less than 20 minutes.
    It's Oct. 2015, and the fan cost me about $10. it was the same brand/model...
    SUNON MG62090V1-Q020-S99 .
    SOME TRICKS -
    1- no T6 screwdriver- was careful using needle nose players to loosen 2 screws protruding up, then use a small phillips to push real hard into the T6 slots, SLOWLY turn , also used a small flat head screwdriver (for eye glass repair) was able to grab thread on T6's, made a small mark with screw driver across the top so I could see when it started to turn.
    2- no spudger -made one; cut a little strip 1/2" x 1 1/2" of plastic. couldn't get it to slide under plug, there's an edge where plug fits. so lifted old fan out, pulled upward on the plug it popped right out with very little effort. I used my home made spudger to push the new plug into place.
    3- download free "Macs Fan Control" This is how I was alerted to the fan not working in the first place. Program shows temperature of all key components in the computer.
    cheers- Durango CO!
    Dgodrummer - 回复
    Watch the video first, read the entire tutorial and all the comments before you start, and spread a white towel on the floor so you can find screws when you drop them. Watch this first -- http://www.youtube.com/watch?v=qiBxhA29e...
    kevicoll409 - 回复
    The link above is no longer available.
    Kristina Graham -
    I will be buying a battery from you and using your instructions. I just installed a new CD/DVD using your instructions and 1) I feel like I owe you something and 2) Although more expensive, I have the confidence your battery will work. My current battery is the original with 1399 cycles in 7.2 yrs. A tech buddy had bought me a replacement and I installed it. I had just installed a new OS and the kernel_task went going nuts, using 90% of the CPU. Hours on the phone with Apple did not resolve the issue. On a whim, I put the old battery back in and Voila! But I cannot risk my battery swelling and going south on me. I am also going to buy your installation tools. Yeah, I already have them. But you can never have enough tools…or beer. And you don’t sell beer.
    Pete Banks - 回复
    The instructions say that I am removing PH00 screws. I found that my MBP, mid ‘12, Retina has pentalobe screws instead!
    jsandersonq - 回复
    This laptop definitely originally shipped with Phillips screws—but, Apple has been known to replace Phillips screws with pentalobes when one of their devices is brought in for service. Sorry for the rude surprise! Fortunately the correct driver is easy to find nowadays. [Blatant self-promotion alert!] If you support free repair manuals, consider picking one up from iFixit. Good luck!
    Jeff Suovanen -
    Me, too, and it’s plausible that this machine has been serviced by Apple in the past, replacing the screws as Jeff Suovanen suggests.
    iFixit shipped a pentalobe bit with the kit, but it’s too large for the actual screws, so it looks like I now need to get another bit. But what size?
    Jeff’s link is to a driver with a P5 bit, and that page links to a P2 screwdriver, but since I don’t know what size I actually need (and I don’t have a micrometer to hand) I’m reluctant to buy two on spec.
    Norman Gray -
    (The bit in the kit appears to be a P6, so I’m inclined to order a P5 and see what happens)
    Norman Gray -
    You’re using the wrong repair guide. This guide is for the 2012 NON-Retina MBP. You have a Retina MBP. The stock case screws in the 2012 NON-Retina are all Phillips, just as the guide says.
    Steven Wymor -
    To keep track of screws, I used the suggestions above by taping a photo of the lower case to a piece of corrugated cardboard and inserting/taping the screws in place. Also, as some have noted, the screws go back in at a slight angle; they are angled toward the center of the unit.
    Kristina Graham - 回复
    If your vision, like mine, is getting too fuzzy to be able to distinguish between a tiny Phillips screwdriver and a tiny Tri screwdriver, there’s an easy way. With a Phillips (or a Pozidrive) you can get two opposite wings to reflect the light from a lamp or window straight towards your eye at the same time. With a Tri (or Penta) you can only get one wing to reflect at a time, however much you twiddle it.
    Alan Waller - 回复
    There’s a very easy way to avoid cross-threading a screw thread, any size.
    Put the screw into its hole and start by turning it gently, slowly BACKWARDS. When you hear a little “Click!” sound, the male thread has just passed the opening in the female thread and is in exactly the right position to enter into it correctly when you start to turn in the correct forward direction.
    Remember, all drivers except hex (Allen key) and TorX need pressure to avoid slipping out and damaging the head. So even when you want to turn it in with LOW moment/torque, keep the CONTACT PRESSURE high.
    Alan Waller - 回复
    The keep the pressure on is on point. In my case once I loosened my first screw I thought I could relief my initial pressure. It was a mistake. I was doing the whole thing very slowly as a precaution. That helped me notice that the Phillips screw driver was sliding up out of the screw head. Not being sure why, I put pressure back on the screw driver until almost all the screw was out of the hole. Once out, I examined closely to find out that the threads have some sort of coating. It looks to me like some kind of locktite. Then I understood the importance of keeping the pressure on all the way through. It made me uneasy having to keep so much pressure on such tiny screws, but I found it was the only way to prevent damage to the “slots” on the heads. Anyway, all of them suffered some degree of damage, but I was able to successfully remove them and reinstall all of them back in their original holes.
    Martin Mejia -
    After reading this page on iFixit several times, I just could not face all the work of replacing the Logic Boards on two MacBookPro 2011s even if I was prepared to pay approx 400 USD (which I wasn’t). Then I read the reviews of a couple of folks who’d stripped down their machines and put their logic boards in the oven and, it worked! I wondered, if I just used my new Steinel Hot Air Tool (heat gun in my language) recently delivered from iFixit, on the logic board in-situ, without removing it? So I removed the battery, hard drive, and RAM and unplugged all the leads I could see WITHOUT removing anything else physically. Then using the 500 degrees set on the gun (setting 2) I ‘played’ the gun over the logic board for about 60 seconds on machine one with the restart problem (plus latterly, not completing start-up). Long story short… it worked! I spent a long time getting the s/w to load, but the commentary is too short to let me relate that part… ping me if I can help you do the same! blackaye@gmail.com
    Ian Black - 回复
  2. 2012年中 15寸 MacBook  Pro 一体化机 RAM 更换: 步骤 2 中的图像 1,1
    • 使用双手在后壳接近风扇处提起固定后壳的两个卡扣。
    • 将后壳放置在一边。
    What is the maximum amount of RAM that can be installed in this MacBook?
    michael - 回复
    16 GB is the max
    Bradon Kelley -
    I can’t get the back panel off !! Removed all 10 screws but the panel is still on. Not a quick easy lift like in the picture of videos on youtube what going on…are the hidden screws locking tabs?
    Tachyon - 回复
    Solved the tabs were hard to get off to the point I thought I was going to bend the back case off before it would let go.
    Tachyon - 回复
  3. 2012年中 15寸 MacBook  Pro 一体化机 RAM 更换, 电池排线: 步骤 3 中的图像 1,2 2012年中 15寸 MacBook  Pro 一体化机 RAM 更换, 电池排线: 步骤 3 中的图像 2,2
    • 对于某些维修(例如硬盘),不需要断开电池连接器,但断开连接器可防止主板上电子设备的意外短路。 如果不断开电池连接器,请小心,因为主板的部件可能会通电造成短路或其他伤害。
    • 使用撬棒的边缘从逻辑板上的插座向上撬开电池连接器。
    • 在连接器的两个短边上分别向上撬起插座是十分有效的手段。
    nails work pretty well as well...
    Sibe Jan Kramer - 回复
    At first sight I was confused when I read the description at this step, 'cause it seemed that disconnecting the battery connector was optional, in order to eliminate static discharge. While it's a helpful advice in other circumstances (as mentioned as an example changing hard drives), when changing the battery it is not an option - you have to disconnect the battery connector.
    It would have been better to mention the optional disconnecting recommendation in a side-note.
    Other than that, an excellent guide!
    Damienn - 回复
    the fact that this step is optional can not be stressed enough. i tried disconnecting the battery and in the process it short circuited which now leaves me with an even more expensive problem than i had before when i just wanted to change hard drives (at least the new hard drive works fine..)
    the hard drive changing worked though.
    nina - 回复
    Any tool used to pry on the battery connector must be non metallic, to prevent unintentional short circuit between the connector pins. In my case, my index finger nails were strong enough.
    Martin Mejia -
    Excellent guide, it was as easy as a breeze to replace my battery. I can't believe I nearly followed Apple in their saying that this part was not user replaceable. Great job for this description, and many thanks. iFixIt is THE reference for Mac owners.
    Patrick.
    Patrick Demaret - 回复
    So - I have a weird comment about this. I wanted to make sure that I was getting the right model - so I opened up my laptop and then thought "well, why not just remove the battery while i'm in here, it's shot anyway". Though, I forgot about the stupid screws (Apple really did us over on that one!). Though I disconnected the battery connector and didn't bother to re-connect it when I was finished and just put the cover back on.
    Here's the weird part - when I went to turn my laptop back on...MY BATTERY WAS RECOGNIZED...AND WORKING! I was under the impression that the connector "connects" the battery's charge to the laptop, but this just doesn't make sense! Plus, now my very dead battery is in "normal" condition according to the system report. I haven't worked for apple, but have about 5 years of IT experience and am baffled by this! I'm starting to think i've experience a miracle! Has this happened to anyone else?
    Shelly - 回复
    Possibly disconnecting the battery caused the System Management Controller to reset. That might have been your problem rather than the battery itself. See http://osxdaily.com/2010/03/24/when-and-...
    Duke Briscoe -
    I'd just like an advise of where to dispose the old battery. Thanks
    Jaime Serafim - 回复
    Any Best Buy or Batteries + Bulbs accepts batteries for recycling in their stores. Many other stores such as Home Depot do as well.
    xtophr -
    Office Depot will take any batteries and dispose of them for free
    silas -
    My battery connector pulled off parallel to the board surface
    Mazo - 回复
    I tried spudging the corner closer to the wires which was probably a bad idea. The corner broke off! I can't believe it was that brittle. So be careful. If it did it again, I'd aim for the corners AWAY from the wires or the sides themselves, though I seem to recall there not being much of a lip.
    Dave Kitabjian - 回复
    I used the spudger to gently ease the battery connector out. I then placed a q-tip between the connector and it’s socket to avoid making an accidental connection. A toothpick or some other soft stick might also work.
    My battery connector had a shiny metal cover over it like a male USB plug. I had to take the 3 peace symbol screws oit and remove the battery before I could access thr plug properly. My battery plug also came off parallel to the board by walking the black plastic part off the metal part towards the battery. It required quite a bit of force to walk it off the connector. I broke a spudger trying. Something nonconductive but strong like a wittled down bamboo chopstick could work well.
    Pii - 回复
    Translate to Spanish:
    Para ciertas reparaciones (por ejemplo, el disco duro), no es necesario desconectar el conector de la batería, pero evita cualquier cortocircuito accidental de la electrónica en la placa base. Si no desconecta el conector de la batería, tenga cuidado ya que partes de la placa base pueden estar electrificadas.
    Use el borde de un spudger para levantar el conector de la batería hacia arriba desde su zócalo en la placa lógica.
    Es útil hacer palanca hacia arriba en ambos lados cortos del conector para "sacarlo" de su zócalo.
    Pakito Villaseñor - 回复
    The BATTERY MUST BE DISCONNECTED - it is NOT OPTIONAL if you are going to remove the logic board.
    These instructions are for Removing The Logic Board, so if that is what you are going to do the battery MUST be disconnected.
    The informational item beginning with the words “For certain repairs (e.g. hard drive), disconnecting the battery connector is not necessary … “ is NOT applicable to a set of instructions on removing a logic board and it should be deleted from this otherwise excellent set of instructions.
    Michael Walsh - 回复
    In my opinion the RAM should be removed first - i.e., before the battery is removed.
    The RAM DIMMS are just in the way if they are left in their sockets on the logic board until step 33.
    I cannot see any useful reason to not remove them very early in the sequence.
    Michael Walsh - 回复
    I disconnected the battery because it is an opportunity to reset the SMC (which is how the SMC has to be reset in some older Macs.)
    Barb - 回复
  4. 2012年中 15寸 MacBook  Pro 一体化机 RAM 更换: 步骤 4 中的图像 1,1
    • 将电池电缆稍微掰离主板上的插座,以免在进行其他工作时插头与插座意外连接。
    My battery connect was like mid 2010 model
    Iain Friend - 回复
    Why not go ahead and remove the battery at this point instead of bending the battery connector back (see steps 23 -25 below)?
    BilMcKelvy - 回复
    Translate to Sanish: Doble el cable de la batería ligeramente lejos de su zócalo en la placa lógica para que no se conecte accidentalmente mientras trabaja.
  5. 2012年中 15寸 MacBook  Pro 一体化机 RAM 更换, RAM: 步骤 5 中的图像 1,3 2012年中 15寸 MacBook  Pro 一体化机 RAM 更换, RAM: 步骤 5 中的图像 2,3 2012年中 15寸 MacBook  Pro 一体化机 RAM 更换, RAM: 步骤 5 中的图像 3,3
    • 通过同时将每个卡扣推离 RAM 模块,打开 RAM 芯片两侧的卡扣。
    • 这些卡扣将芯片锁定在适当的位置,打开它们会导致芯片“弹出”。
    • 弹出 RAM 芯片后,将其从插槽中直接拉出。
    • 如果安装了第二个RAM芯片,请重复此过程。
    I am a fool! I forgot to switch off the computer and also I didn't disconnet the battery connector :))
    But all ok, the Mac did reboot very well and is working like a charm.
    plamar - 回复
    Thanks, finding the correct RAM modules on the internet is virtually impossible.
    Being able to buy your kit, knowing that the correct RAM update was provided, was a big bonus.
    Thanks for making it so easy.
    Adrian Warren - 回复
    Yes, buying the kit and components from ifixit made the process so much less complicated. I also replaced my hard drive while I had the computer open. Both hardware replacements were so much easier than dealing with the software part of things.
    What’s the type of RAM for the 15” MacBook 2009? DDR2 / 3 / 4
    Tokologo Rapodile - 回复
结论
请按逆序重组你的设备。
177等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
13条评论
Super clear guide, super easy way to upgrade the RAM.
But the factory default RAM is supposed to be 1600MHz on this (PC3 10600S is 1333MHz) right?
Kerem Akyuz - 回复
Super easy! Great guide!
Kari Kainulainen - 回复
This was a very clear and helpful guide. Thanks, Andrew!
One point that I thought would help others trying this for the first time is about the mechanism holding the RAM. As the guide points out, the RAM chips should 'pop' up when the clips holding them down are properly extended to the side. And when installing the new chips I found that though the force applied was between light and moderate, relative there wasn't much force needed to insert them into the board as there was to push them downwards until you here a 'pop.' The force needed to be applied at any stage of the whole process was minimum to midway between minimum and moderate.
Soura - 回复
Hey I consulted this iFixit guide, the official guide on the apple website and also the crucial memory selector tool.
1) Apple said you didn't have to disconnect the power. So you don't (if you're just swapping out the ram).
2) Crucial confirms that 16 gb works. I ended up getting 16 gb of PNY at BestBuy. They didn't have any Crucial on the shelves.
3) The first two times I did this, the connections weren't perfect. So I had the triple beep motherboard error and then the "nothing happens when i try to power on" error. So if either of these happens, fret not. Just calmly open everything back up and do it again.
So happy I did this. Yosemite was a memory guzzling beast. Now I have garageband and iTunes and iPhoto all blazing and not a hitch.
Cheers.
Ruthie - 回复
Could I suggest adding a hardware test after installation.
For my MacBook Pro you hold down the D key when restarting.
dawsonchristopher - 回复
Is it the same for MacBook Pro 13inch mid2012 ?
Zafer - 回复
Yes, it is essentially the same. There will be some differences because of the 13 in model but you should be able to follow along.
Erik Phillips -
Love the guide, easy to use! Quick query; if you take out 2 ram chips do you have to put 2 back in? I didn't realise the situation when i bought the Ram and only have 1, will this be ok?
ellena_h - 回复
thank you, Team iFixit! i just did my first Mac upgrade, bumping my mid-2012 A1286 to 16GB. it was a 10-12 minute job, including a few minutes gently getting rid of dust bunnies that had taken up residence. omg. that was scary. a few of the contacts on the lower RAM PCB looked oxidized/discolored/worn, so iʻm glad i finally got up the guts to open my computer and start with some simple stuff. i have a couple of other computers in the household that iʻm going to tackle next, and this was a great confidence booster. thanks, everyone!!!
Kahana - 回复
Is it essential to have anti static grounded wrist guard on if disconnecting battery? Or an anti static mat? When swapping out ram in MacBook
Cami Sync - 回复
There seems to be a possibility to upgrade the mid-2012 MBP to 32GB Ram, there’s a thread on this on macrumours, but still nobody has confirmed it works and which modules to use.
Crucial SO-DIMM Kit 32GB, DDR3L-1600, CL11 (CT2KIT204864BF160B) might work - did anybody try this yet and can confirm any 32GB MBP9,1 is possible?
huedrant - 回复
Apple says that this computer takes a max of 8 gb. So far the computer is only recognizing one of the 8 gb slots and says the other is vacant.
I'll open it up and try again to see if 16 gb will work.
allenwstephenson - 回复
Black screen & 3 beeps on the ram GONE!! This is Super easy to change, 10 minutes and that was cleaning the dust out as well, 1st fire up was real slow, log in was slow, (checked about this Mac "16gb of Ram" SWEET!!) Now I can get back to backing this baby up so I can finish the rebuild. New 2Tb Hard drive, new battery, new track pad, new speakers, new hinge cover and new feet.
Thanks to everyone fixit.
bikeman5 - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 30
过去 30 天: 155
总计 103,174
