跳转到主内容
2011 Toyota Sienna Headlight Bulb Replacement
你所需要的
  1. 2011 Toyota Sienna Headlight Bulb Replacement, Headlight Bulb: 步骤 1 中的图像 1,3 2011 Toyota Sienna Headlight Bulb Replacement, Headlight Bulb: 步骤 1 中的图像 2,3 2011 Toyota Sienna Headlight Bulb Replacement, Headlight Bulb: 步骤 1 中的图像 3,3
    • Pull out the hood release latch located towards the lower left of the steering wheel.
  2. 2011 Toyota Sienna Headlight Bulb Replacement: 步骤 2 中的图像 1,3 2011 Toyota Sienna Headlight Bulb Replacement: 步骤 2 中的图像 2,3 2011 Toyota Sienna Headlight Bulb Replacement: 步骤 2 中的图像 3,3
    • Hold up the hood safety latch with one hand and lift the hood of the car with the other hand.
    • Pull the hood all the way up to ensure it engages and stays up.
  3. 2011 Toyota Sienna Headlight Bulb Replacement: 步骤 3 中的图像 1,2 2011 Toyota Sienna Headlight Bulb Replacement: 步骤 3 中的图像 2,2
    • Locate the headlight bulb housings on each side if the hood.
    • It's advisable to replace both headlights even if only one is burned out. The other light is likely to go out soon, and replacing both now can help avoid additional repairs.
  4. 2011 Toyota Sienna Headlight Bulb Replacement: 步骤 4 中的图像 1,3 2011 Toyota Sienna Headlight Bulb Replacement: 步骤 4 中的图像 2,3 2011 Toyota Sienna Headlight Bulb Replacement: 步骤 4 中的图像 3,3
    • Push the button on the electrical connector until you hear a click.
    • Pull down to remove the electrical connector.
  5. 2011 Toyota Sienna Headlight Bulb Replacement: 步骤 5 中的图像 1,2 2011 Toyota Sienna Headlight Bulb Replacement: 步骤 5 中的图像 2,2
    • Twist the bulb counter clockwise.
  6. 2011 Toyota Sienna Headlight Bulb Replacement: 步骤 6 中的图像 1,1
    • Pull out the bulb.
    • Insert your new light bulb.
    • If you are not wearing gloves, avoid touching the glass part of the bulb since the oils from your skin will damage the bulb.
结论
Madeleine Falcon
于09/07/23注册
183 声望
撰写一个指南
团队
York University, Team 1-11, O'Regan Fall 2023 York University, Team 1-11, O'Regan Fall 2023 的会员
YORK-O'REGAN-F23S1G11
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 28
总计 217
