跳转到主内容
2011 Mazda 3 Car Speaker Replacement
你所需要的
  1. 2011 Mazda 3 Car Speaker Replacement, 2011 Mazda 3 Car Speaker: 步骤 1 中的图像 1,3 2011 Mazda 3 Car Speaker Replacement, 2011 Mazda 3 Car Speaker: 步骤 1 中的图像 2,3 2011 Mazda 3 Car Speaker Replacement, 2011 Mazda 3 Car Speaker: 步骤 1 中的图像 3,3
    • Pry the door handle cover upwards using a flathead screwdriver.
    • Remove the cover to expose the screw.
  2. 2011 Mazda 3 Car Speaker Replacement: 步骤 2 中的图像 1,2 2011 Mazda 3 Car Speaker Replacement: 步骤 2 中的图像 2,2
    • Pull the door handle towards you.
    • Insert a small flathead screwdriver between the lock and the plate.
    • Pry the plate off by applying leverage away from the lock, exposing the second screw.
  3. 2011 Mazda 3 Car Speaker Replacement: 步骤 3 中的图像 1,2 2011 Mazda 3 Car Speaker Replacement: 步骤 3 中的图像 2,2
    • Remove both screws with a Phillips #1 screwdriver.
    • The screws are 12mm Phillip's head. Part number (9986-50-516S).
  4. 2011 Mazda 3 Car Speaker Replacement: 步骤 4 中的图像 1,1
    • Pry the door cover away from the frame using a heavy-duty spudger.
    • The door cover will not be removed entirely in this step.
    • Prying the door off takes substantial force; moving around the door's perimeter will help unhook the clips that line the panel.
  5. 2011 Mazda 3 Car Speaker Replacement: 步骤 5 中的图像 1,2 2011 Mazda 3 Car Speaker Replacement: 步骤 5 中的图像 2,2
    • Push the switch panel out from the inside of the door cover.
    • Ensure the car is off before proceeding.
    • Remove the wires connected to the panel by pressing the clips and pulling them outward.
    • Remove the door cover.
  6. 2011 Mazda 3 Car Speaker Replacement: 步骤 6 中的图像 1,1
    • Use a Phillips #1 screwdriver to remove the four screws that secure the door speaker.
    • The screws are 10mm Phillip's head. Part number (9984-50-616).
  7. 2011 Mazda 3 Car Speaker Replacement: 步骤 7 中的图像 1,1
    • Remove the wires connecting the speaker by pressing the clip and pulling it outward.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 89
总计 2,431
