跳转到主内容
2011 Jeep Liberty Hood Replacement
你所需要的
  1. 2011 Jeep Liberty Hood Replacement, Hood: 步骤 1 中的图像 1,1
    • Open the hood of the Jeep by pulling the hood latch. This is placed right next to the driver's seat and to the left of the brake pedal.
  2. 2011 Jeep Liberty Hood Replacement: 步骤 2 中的图像 1,3 2011 Jeep Liberty Hood Replacement: 步骤 2 中的图像 2,3 2011 Jeep Liberty Hood Replacement: 步骤 2 中的图像 3,3
    • Notice a latch located above the car's grill after popping the hood. Lift the hood by releasing the latch. After lifting the hood, notice a movable latch just above the wiper fluid container. There is a specific hole on the left side of the hood where you can hook the latch.
  3. 2011 Jeep Liberty Hood Replacement: 步骤 3 中的图像 1,1
    • Disconnect the wind-shield fluid line on the left side of the hood.
  4. 2011 Jeep Liberty Hood Replacement: 步骤 4 中的图像 1,1
    • Identify the four bolts which can be seen towards the extreme left (2 bolts) and extreme right (2 bolts) underneath the hood.
  5. 2011 Jeep Liberty Hood Replacement: 步骤 5 中的图像 1,1
    • Remove the four bolts using a 13mm wrench and lift the hood out of place.
    • After replacing the old hood with the new hood, reverse the process; tighten back the four bolts and connect the wind-shield fluid line.
结论
Daniel Strode
于03/23/21注册
121 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 16
总计 1,365
