跳转到主内容
2011 Ford Focus Air Conditioning Refrigerant Replacement
你所需要的
  1. 2011 Ford Focus Air Conditioning  Refrigerant Replacement, Air Conditioning Refrigerant: 步骤 1 中的图像 1,3 2011 Ford Focus Air Conditioning  Refrigerant Replacement, Air Conditioning Refrigerant: 步骤 1 中的图像 2,3 2011 Ford Focus Air Conditioning  Refrigerant Replacement, Air Conditioning Refrigerant: 步骤 1 中的图像 3,3
    • Turn the car on and the A/C to the maximum.
  2. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: 步骤 2 中的图像 1,1
    • Open your car's hood.
  3. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: 步骤 3 中的图像 1,2 2011 Ford Focus Air Conditioning  Refrigerant Replacement: 步骤 3 中的图像 2,2
    • Locate the low-pressure charging port.
  4. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: 步骤 4 中的图像 1,1
    • Remove the cap by turning it counter-clockwise.
  5. 2011 Ford Focus Air Conditioning  Refrigerant Replacement: 步骤 5 中的图像 1,2 2011 Ford Focus Air Conditioning  Refrigerant Replacement: 步骤 5 中的图像 2,2
    • Connect the nozzle and hold the canister at a 3 o'clock angle.
    • Warning: Keep an eye on the PSI level. It should stay between 30 and 50, as going beyond 50 psi could cause the car's compressor to become damaged.
    • Lock and remove the canister if it is around 40 to prevent it from going to 50 psi.
    • Finally, start up the car. If the air conditioning is cooler, you'll know that it works!
终点
另外一个人完成了本指南。
Sujan
于03/07/22注册
130 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 19
过去 7 天: 66
过去 30 天: 217
总计 4,325
