跳转到主内容
2011 BMW 328i Cabin Air Filter Replacement
你所需要的
  1. 2011 BMW 328i Cabin Air Filter Replacement, Cabin Air Filter: 步骤 1 中的图像 1,3 2011 BMW 328i Cabin Air Filter Replacement, Cabin Air Filter: 步骤 1 中的图像 2,3 2011 BMW 328i Cabin Air Filter Replacement, Cabin Air Filter: 步骤 1 中的图像 3,3
    • Open driver side door.
    • Lift the car hood lever until you hear your hood release.
    • If your hood release lever has a "2x" symbol, this indicates a double-pull hood release lever. Pull the lever once, release the lever, and pull it a second time to release the hood latch.
    • Slide your hand under the hood and lift it up.
    • If your BMW does not have a double-pull release lever, find the release latch under the BMW symbol on the hood. Push or lift this latch to unlock the hood.
  2. 2011 BMW 328i Cabin Air Filter Replacement: 步骤 2 中的图像 1,3 2011 BMW 328i Cabin Air Filter Replacement: 步骤 2 中的图像 2,3 2011 BMW 328i Cabin Air Filter Replacement: 步骤 2 中的图像 3,3
    • Using the socket wrench, start unbolting all six external bolts.
    • Release the cabin air filter from the hood.
  3. 2011 BMW 328i Cabin Air Filter Replacement: 步骤 3 中的图像 1,2 2011 BMW 328i Cabin Air Filter Replacement: 步骤 3 中的图像 2,2
    • Pop out the old air filter.
    • Place the new air filter into the air filter cover.
  4. 2011 BMW 328i Cabin Air Filter Replacement: 步骤 4 中的图像 1,2 2011 BMW 328i Cabin Air Filter Replacement: 步骤 4 中的图像 2,2
    • Place the cabin air filter under the hood.
    • Screw in all six external hex screws back into place using the socket wrench.
结论
2等其他人完成本指南。
Anthony Liu
于01/26/23注册
127 声望
撰写一个指南
团队
UC Davis, Team 1-11, Morris Winter 2023 UC Davis, Team 1-11, Morris Winter 2023 的会员
UCD-MORRIS-W23S1G11
2 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 97
过去 30 天: 468
总计 3,065
