跳转到主内容
2011-2013 Scion tC Radio Head Unit Replacement
你所需要的
  1. 2011-2013 Scion tC Radio Head Unit Replacement, Radio Head Unit: 步骤 1 中的图像 1,2 2011-2013 Scion tC Radio Head Unit Replacement, Radio Head Unit: 步骤 1 中的图像 2,2
    • Remove the dashboard panel around the radio head by pulling on the bottom of the unit.
  2. 2011-2013 Scion tC Radio Head Unit Replacement: 步骤 2 中的图像 1,2 2011-2013 Scion tC Radio Head Unit Replacement: 步骤 2 中的图像 2,2
    • Remove the wire header connected to the panel by pressing inward on the tabs.
  3. 2011-2013 Scion tC Radio Head Unit Replacement: 步骤 3 中的图像 1,1
    • Remove the four #2 12mm screws securing the head unit in the housing
  4. 2011-2013 Scion tC Radio Head Unit Replacement: 步骤 4 中的图像 1,2 2011-2013 Scion tC Radio Head Unit Replacement: 步骤 4 中的图像 2,2
    • Remove each bundle of wires that is connected to the back of the head unit.
  5. 2011-2013 Scion tC Radio Head Unit Replacement: 步骤 5 中的图像 1,2 2011-2013 Scion tC Radio Head Unit Replacement: 步骤 5 中的图像 2,2
    • Locate the metal brackets on the side of the head unit.
    • Use a Philips head screwdriver, remove the three #2 25mm screws from both support brackets on the side of the head unit
  6. 2011-2013 Scion tC Radio Head Unit Replacement: 步骤 6 中的图像 1,1
    • Screw the support brackets to the new radio head unit
    • Note that the brackets are unique to the car. They will not come with your new head unit.
结论
2等其他人完成本指南。
Dylan Smith
于05/01/15注册
143 声望
撰写一个指南
团队
Cal Poly, Team 8-2, Regan Spring 2015 Cal Poly, Team 8-2, Regan Spring 2015 的会员
CPSU-REGAN-S15S8G2
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 29
总计 7,430
