跳转到主内容
2011-2013 Scion tC Car Battery Replacement
你所需要的
  1. 2011-2013 Scion tC Car Battery Replacement, Car Battery: 步骤 1 中的图像 1,1
    • Begin by opening the hood of the car and locating the battery on the front of the driver side in the engine compartment
  2. 2011-2013 Scion tC Car Battery Replacement: 步骤 2 中的图像 1,1
    • Using a socket wrench, loosen the 2 (5/16 inch) nuts on the top of the battery support bracket
    • Remove the bracket by lifting up
  3. 2011-2013 Scion tC Car Battery Replacement: 步骤 3 中的图像 1,1
    • After removing the bracket, locate the supporting rod behind the battery
    • The rod is hooked on a hole in the metal behind the battery. Unhook the rod and remove it
  4. 2011-2013 Scion tC Car Battery Replacement: 步骤 4 中的图像 1,2 2011-2013 Scion tC Car Battery Replacement: 步骤 4 中的图像 2,2
    • Start with the negative terminal of the battery
    • Loosen the nut on the negative terminal with a 10mm socket wrench
    • Remove the wire by slightly twisting and pulling up
  5. 2011-2013 Scion tC Car Battery Replacement: 步骤 5 中的图像 1,2 2011-2013 Scion tC Car Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the cap from the positive terminal of the battery
    • Using a 10mm socket wrench, loosen the nut on the positive terminal
    • Remove the wire from the positive terminal by slightly twisting and pulling up
    • Remove the battery by lifting it out of the engine compartment
结论
另外一个人完成了本指南。
Travis Michael
于05/08/15注册
140 声望
撰写一个指南
团队
Cal Poly, Team 8-2, Regan Spring 2015 Cal Poly, Team 8-2, Regan Spring 2015 的会员
CPSU-REGAN-S15S8G2
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 27
总计 10,816
