跳转到主内容
2011-2015 Kia Optima Interior Map Light Replacement
你所需要的
  1. 2011-2015 Kia Optima Interior Map Light Replacement, Interior Map Light: 步骤 1 中的图像 1,1
    • Wedge the tip of the prying tool between the lens and the console.
    • Gently pry the lens off of the console.
  2. 2011-2015 Kia Optima Interior Map Light Replacement: 步骤 2 中的图像 1,1
    • Separate the lens from the clips connecting the lens and the console.
  3. 2011-2015 Kia Optima Interior Map Light Replacement: 步骤 3 中的图像 1,2 2011-2015 Kia Optima Interior Map Light Replacement: 步骤 3 中的图像 2,2
    • Gently twist or pull away the bulb from the connection.
  4. 2011-2015 Kia Optima Interior Map Light Replacement: 步骤 4 中的图像 1,2 2011-2015 Kia Optima Interior Map Light Replacement: 步骤 4 中的图像 2,2
    • Insert the new bulb into the connection.
    • Some bulbs are polarity specific, so if at first the bulb does not work, try flipping it 180 degrees and connect it again.
  5. 2011-2015 Kia Optima Interior Map Light Replacement: 步骤 5 中的图像 1,1
    • Reattach the lens back onto the console by clipping it back into place.
  6. 2011-2015 Kia Optima Interior Map Light Replacement: 步骤 6 中的图像 1,1
    • Push the lens into the console. When you hear a click, the lens has been attached properly.
终点
2等其他人完成本指南。
Ariel Miranda
于04/20/21注册
175 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 42
总计 1,529
