简介
If you've noticed your Chevy Sonic 2012's air conditioning system isn't performing up to par—blowing warm air or lacking the cooling efficiency it once had—it might be time for an A/C gas recharge. This step-by-step guide will walk you through the process in nine steps, ensuring you can restore your car's A/C system to optimal performance.
While all of the steps are necessary to execute this guide successfully, there is an emphasis on steps 2, 6, and 7, as these let the reader know of the safety precautions one should take to avoid exposure to the R134a gas.
Despite the simplicity of this guide, it is necessary to be aware that exposure to R134a gas can lead to temporary central nervous system depression, with narcosis, lethargy and anesthetic effects, severe pain and cornea damage in the eyes, and more.
Finally, it's important to mention that if after finishing this guide, your A/C car system is still not working, there might be a bigger problem going on, so it might be necessary to consult a mechanic.
你所需要的
Obtain a R134a refrigerant can, available at most auto parts stores, and an adaptor hose designed to connect the can to the car's air conditioning system.
