跳转到主内容
2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement
你所需要的
  1. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement, Back-Up Light and Brake Light: 步骤 1 中的图像 1,3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement, Back-Up Light and Brake Light: 步骤 1 中的图像 2,3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement, Back-Up Light and Brake Light: 步骤 1 中的图像 3,3
    • Make sure the car is off before you start your replacement. However, You don't have to disconnect the car battery.
    • Open the trunk first.
    • Using Phillips #2 screwdriver, remove the two 10 mm screws from the back & tail light.
  2. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: 步骤 2 中的图像 1,3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: 步骤 2 中的图像 2,3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: 步骤 2 中的图像 3,3
    • Using both hands, carefully pull the brake & tail light off.
  3. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: 步骤 3 中的图像 1,1
    • Here is the tail light assembly.
    • The left one is for the brake light.
    • The right one is for the back-up light.
  4. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: 步骤 4 中的图像 1,3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: 步骤 4 中的图像 2,3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: 步骤 4 中的图像 3,3
    • Twist and turn the backup light to the right. And then pull it out.
    • Make sure not to touch the surface of the light bulb because it will break the light bulb easily.
  5. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: 步骤 5 中的图像 1,3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: 步骤 5 中的图像 2,3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: 步骤 5 中的图像 3,3
    • Twist and turn the brake light to the right and pull it out.
    • Make sure not to touch the surface of the light bulb because it will break the bulb easily.
  6. 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: 步骤 6 中的图像 1,3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: 步骤 6 中的图像 2,3 2011-2017 Hyundai Veloster Back-Up Light and Brake Light Replacement: 步骤 6 中的图像 3,3
    • Replace the light bulbs.
    • Check that the light bulbs work first before replacing 10 mm screws.
结论
2等其他人完成本指南。
Adrian Ng
于09/18/21注册
196 声望
撰写一个指南
团队
York University, Team E-20, Melo-Thaiss Fall 2021 York University, Team E-20, Melo-Thaiss Fall 2021 的会员
YORK-MELO-THAISS-F21SEG20
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 32
过去 30 天: 123
总计 4,428
