跳转到主内容
2010 Jeep Liberty Headlight Bulb Replacement
你所需要的
  1. 2010 Jeep Liberty Headlight Bulb Replacement, Headlight Bulb: 步骤 1 中的图像 1,1
    • Pop the hood of your vehicle by pulling the lever near the bottom of the driver's side door.
    • Slide your hands under the unlatched hood to find the second lever. Push this lever to the right and lift the hood.
    • Be sure to use the hood prop to keep the hood from falling while you're underneath it.
  2. 2010 Jeep Liberty Headlight Bulb Replacement: 步骤 2 中的图像 1,3 2010 Jeep Liberty Headlight Bulb Replacement: 步骤 2 中的图像 2,3 2010 Jeep Liberty Headlight Bulb Replacement: 步骤 2 中的图像 3,3
    • Identify the bulb socket, located behind the headlight.
    • Rotate the base of the bulb counter-clockwise to remove it from the socket.
    • Remove the bulb from the green base by pulling the two apart.
  3. 2010 Jeep Liberty Headlight Bulb Replacement: 步骤 3 中的图像 1,3 2010 Jeep Liberty Headlight Bulb Replacement: 步骤 3 中的图像 2,3 2010 Jeep Liberty Headlight Bulb Replacement: 步骤 3 中的图像 3,3
    • Insert the new bulb into the green base.
    • Be sure not to touch the glass with your fingers. If you do, wipe the bulb down with a soft cloth and some rubbing alcohol. Oils left behind from your fingers can shorten the life of the bulb.
    • Rotate clockwise to lock the bulb assembly into the socket.
  4. 2010 Jeep Liberty Headlight Bulb Replacement: 步骤 4 中的图像 1,1
    • Turn on headlights to ensure the new bulb is working properly.
    • You will want to check that your headlights are aligned on both sides. Adjust as needed.
结论
Congratulations! You have a shiny new headlight.
8等其他人完成本指南。
Ryan Griffin
于01/19/16注册
245 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 45
总计 8,965
