简介
Replacing the door handle of your 2010 Chevrolet Camaro is necessary when the door handle becomes damaged, cannot function correctly, or wears out over time. The handle can be expensive to replace if taken to professionals to fix at a dealership.
Additionally, replacing your malfunctioning interior door handle successfully can prevent being locked out of your vehicle. Replacing it yourself saves both money and time. The kits sold to replace the interior door handle make it very convenient to replace it with little to no time and minimal tools.
Once you’ve finished with your replacement, make sure to test out the handle to verify that it works.
你所需要的
精选文档
Remove the five bolts that connect the door panel to the door using the T30 Torx screwdriver.
Use a door panel removal tool to pry out the outer edges.
To reassemble your device, follow these instructions in reverse order. Test out the door handle and if it functions the same as the original door handle.
