简介
Use this guide to help you replace a cracked, chipped, or worn-out seal for the windshield. This replacement is for the following vehicles: 2005 - 2013 BMW 335i or E92 series. Replacing this requires some tools, but it is relatively simple.
你所需要的
Please begin using a 90-degree pick and lift the seal from the top corner (either side is fine).
Use both your hands and the tool to slowly lift up the seal.
Grab your favorite all-purpose cleaner or any degreaser, and make sure to spray directly into all the crevices.
You will also need a microfiber towel to clean the crevices; if they are too tight, please use the 90-degree pick to get in between all the cracks.
I want to mention that the rear glass seal takes the same steps as the windshield seal. Please follow the steps carefully.
