跳转到主内容
2010-2014 Ford Mustang Windshield Wiper Motor Replacement
你所需要的
  1. 2010-2014 Ford Mustang Windshield Wiper Motor Replacement, Windshield Wiper Motor: 步骤 1 中的图像 1,2 2010-2014 Ford Mustang Windshield Wiper Motor Replacement, Windshield Wiper Motor: 步骤 1 中的图像 2,2
    • Before beginning this repair, take a reference picture of the position of your wipers. It will help when you are reassembling to know how they were placed.
    • If you have anything you need in the trunk of the car, get it out before you begin the repair. Once the battery is disconnected you won't be able to unlock the trunk.
  2. 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 2 中的图像 1,2 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 2 中的图像 2,2
    • Pull the hood release located on the driver's side of the car.
    • Undo the hood latch.
    • It is hard to see but you can feel it directly above the Mustang emblem.
  3. 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 3 中的图像 1,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 3 中的图像 2,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 3 中的图像 3,3
    • If you have anything you need in the trunk of the car, get it out before you disconnect the battery. Once the battery is disconnected you won't be able to unlock the trunk.
    • Use an 8 mm socket to loosen the bolt on the battery terminal.
    • Pull off the negative(black) terminal first.
    • Repeat the process for the positive(red) terminal.
  4. 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 4 中的图像 1,2 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 4 中的图像 2,2
    • There is a small rubber cap on top of the wiper arm where it connects to the car. Pulling up on it will pull it off.
    • Pull both caps off using your hand and set them aside.
  5. 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 5 中的图像 1,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 5 中的图像 2,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 5 中的图像 3,3
    • Using a 13 mm socket, remove the bolt that is under the black rubber cap on both wiper arms.
    • These bolts connect the wiper arms to the car.
    • The hood needs to be in the down position for removal.
    • It is easier if you have an extension for the socket, or a deep socket but it isn't necessary.
  6. 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 6 中的图像 1,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 6 中的图像 2,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 6 中的图像 3,3
    • Put the hood back down.
    • It doesn't need to be completely closed but needs to be down to remove the wiper arms.
    • With both hands, wiggle the wiper arm and pull up in the direction of the bolt thread to remove it from the car. Repeat the process on the other side.
    • You might have to use a bit of force.
    • Keep track of which arm goes where. The driver-side and passenger-side arms are different.
  7. 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 7 中的图像 1,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 7 中的图像 2,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 7 中的图像 3,3
    • There are four clips that connect the cowl to the car. Use a flathead screwdriver to push the bottom of the pin in the middle of the clip up.
    • Grab it with your fingers once it starts to come up and pull it out.
    • Pinch the sides of the clip and push it up out of its hole.
    • Remove all four of the clips and set them aside.
  8. 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 8 中的图像 1,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 8 中的图像 2,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 8 中的图像 3,3
    • Begin to pull up on the side of the cowl that is closest to the engine.
    • Release the plastic hooks by pulling up on the cowl.
    • Be careful about pulling too hard on the plastic hooks, as they may be brittle from sun damage.
  9. 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 9 中的图像 1,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 9 中的图像 2,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 9 中的图像 3,3
    • To remove the cowl completely, start on the passenger side and lift it up towards the hood of the car. The side that lifts from the middle seam of the cowl is the part to lift up.
    • With the cowl up near the hood, begin to turn it in a clock wise motion. This will allow the end of the cowl that is by the fender to slip out from under the edge of the hood.
    • Repeat the same process for the driver side. This time when the edge is lifted up towards the hood turn it counterclockwise to slip it out from under the edge of the hood.
  10. 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 10 中的图像 1,1
    • Take a reference photo of what the assembly looks like right before you take it apart. It will be helpful for reassembly to know the way the arms are pointed.
  11. 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 11 中的图像 1,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 11 中的图像 2,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 11 中的图像 3,3
    • With a 13 mm wrench take the bolt off that is on top of the windshield wiper motor.
    • Use both hands and a bit of force to get the arm that was under the bolt to move from the bolt thread.
    • Move the joints of the assembly out of the way to reveal all three bolts that mount the wiper motor.
  12. 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 12 中的图像 1,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 12 中的图像 2,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 12 中的图像 3,3
    • Use an 8 mm socket to release the three bolts that connect the assembly to the car.
    • Use a socket arm extension for easier access when removing the bolts.
  13. 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 13 中的图像 1,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 13 中的图像 2,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 13 中的图像 3,3
    • The assembly that holds the wiper motor should lift out now. Turn it over and you will see the wiper motor.
    • Push the tab on the electrical connector towards the exposed wires and you should be able to pull the connector off the wiper motor.
    • Pull the assembly out of the car. Set it to the side for now.
  14. 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 14 中的图像 1,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 14 中的图像 2,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 14 中的图像 3,3
    • There is a drain plug underneath where the wiper motor was. It allows water to drain out of the area and can become clogged causing the wiper motor to be flooded. This can lead to the motor shorting out and eventually it will stop working.
    • Take this chance to pull it out and clean out any debris.
    • Push it back into place.
  15. 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 15 中的图像 1,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 15 中的图像 2,3 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 15 中的图像 3,3
    • Set the wiper assembly down on something sturdy and flat. Use a 10 mm socket, and remove each of the three bolts.
    • Once the bolt is loose enough you can back it all the way out with your hand.
    • Removing all these bolts will release the wiper motor from the frame. Set the assembly down on something so it doesn't fall to the ground.
  16. 2010-2014 Ford Mustang Windshield Wiper Motor Replacement: 步骤 16 中的图像 1,1
    • The wiper motor is now off the assembly.
    • Take the new wiper motor and follow the guide in reverse to put on the new motor. Reassemble everything back together.
结论
Madison Montalbo
于06/30/23注册
253 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 23
过去 30 天: 123
总计 915
