跳转到主内容
2010-2014 Ford Mustang Headlight Replacement
你所需要的
  1. 2010-2014 Ford Mustang Headlight Replacement, Headlight Bulb: 步骤 1 中的图像 1,2 2010-2014 Ford Mustang Headlight Replacement, Headlight Bulb: 步骤 1 中的图像 2,2
    • Pull the release lever firmly to release the latch securing the hood.
  2. 2010-2014 Ford Mustang Headlight Replacement: 步骤 2 中的图像 1,1
    • Raise the hood of the car and connect the car hood prop to the correct place.
  3. 2010-2014 Ford Mustang Headlight Replacement: 步骤 3 中的图像 1,2 2010-2014 Ford Mustang Headlight Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips #2 screwdriver to remove the six 19 mm plastic screws holding the protective plastic piece in place.
  4. 2010-2014 Ford Mustang Headlight Replacement: 步骤 4 中的图像 1,2 2010-2014 Ford Mustang Headlight Replacement: 步骤 4 中的图像 2,2
    • Locate the headlight casing cap in the front of the engine compartment near the headlight unit that is out.
    • Twist the cap counter-clockwise firmly and lift it up to remove it.
  5. 2010-2014 Ford Mustang Headlight Replacement: 步骤 5 中的图像 1,2 2010-2014 Ford Mustang Headlight Replacement: 步骤 5 中的图像 2,2
    • Twist and pull the bulb gently to dislodge it from the headlight casing.
  6. 2010-2014 Ford Mustang Headlight Replacement: 步骤 6 中的图像 1,2 2010-2014 Ford Mustang Headlight Replacement: 步骤 6 中的图像 2,2
    • Pinch the tabs near the base of the bulb together and pull the bulb from its socket.
  7. 2010-2014 Ford Mustang Headlight Replacement: 步骤 7 中的图像 1,2 2010-2014 Ford Mustang Headlight Replacement: 步骤 7 中的图像 2,2
    • Grab the new bulb slide it into the socket firmly to secure it between the tabs.
结论
To reassemble your device, follow these instructions in reverse order. Once reassembled, test the new bulb to ensure that is safe to drive with. Good luck and we hope you have no further problems!
Blake
于10/23/23注册
145 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 31
过去 30 天: 134
总计 774
