跳转到主内容
2010-2014 Ford Mustang Air Filter Replacement
  1. 2010-2014 Ford Mustang Air Filter Replacement, Air Filter: 步骤 1 中的图像 1,2 2010-2014 Ford Mustang Air Filter Replacement, Air Filter: 步骤 1 中的图像 2,2
    • Make sure the vehicle is off before proceeding. Working under the cars hood can lead to burns if the car is still hot. Be careful!
    • Open the hood by pulling on the lever by the driver's feet.
    • Push upward on the latch under the center of the hood to unlock it.
  2. 2010-2014 Ford Mustang Air Filter Replacement: 步骤 2 中的图像 1,1
    • Locate the Air Box
  3. 2010-2014 Ford Mustang Air Filter Replacement: 步骤 3 中的图像 1,3 2010-2014 Ford Mustang Air Filter Replacement: 步骤 3 中的图像 2,3 2010-2014 Ford Mustang Air Filter Replacement: 步骤 3 中的图像 3,3
    • Locate the two latches that keep the air box closed.
    • Push on the latch to open the air box as shown in the picture, and repeat on the second latch.
    • Pull up on the top part of the air box and push it to the front of the car to open.
  4. 2010-2014 Ford Mustang Air Filter Replacement: 步骤 4 中的图像 1,2 2010-2014 Ford Mustang Air Filter Replacement: 步骤 4 中的图像 2,2
    • Make note of the orientation of the air filter before removing it.
    • Lift the filter straight up from the triangle corner and remove it.
  5. 2010-2014 Ford Mustang Air Filter Replacement: 步骤 5 中的图像 1,2 2010-2014 Ford Mustang Air Filter Replacement: 步骤 5 中的图像 2,2
    • Inspect for debris and dirt.
    • The first filter is dirty but does not need to be cleaned or replaced yet.
    • The second filter is dirty and does need to be cleaned or replaced
    • Do not discard the filter because it may be covered under a warranty.
结论
4等其他人完成本指南。
团队
Cal Poly, Team 15-45, Forte Fall 2012 Cal Poly, Team 15-45, Forte Fall 2012 的会员
CPSU-FORTE-F12S15G45
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 30
总计 4,690
