跳转到主内容
2010-2014 BMW X6 Tail Light Bulb Replacement
  1. 2010-2014 BMW X6 Tail Light Bulb Replacement, Tail Light Bulb: 步骤 1 中的图像 1,1
    • Turn off the car and let the car cool down for 5 minutes.
  2. 2010-2014 BMW X6 Tail Light Bulb Replacement: 步骤 2 中的图像 1,2 2010-2014 BMW X6 Tail Light Bulb Replacement: 步骤 2 中的图像 2,2
    • Open the trunk using your key in the trunk key slot or by using the button under the CD player.
  3. 2010-2014 BMW X6 Tail Light Bulb Replacement: 步骤 3 中的图像 1,3 2010-2014 BMW X6 Tail Light Bulb Replacement: 步骤 3 中的图像 2,3 2010-2014 BMW X6 Tail Light Bulb Replacement: 步骤 3 中的图像 3,3
    • Remove the small plastic cover along the vertical edge of the trunk entrance by pulling outwards using the handle.
    • Pull outwards till pannel comes off and place down giving access to the inside of the quarter panel.
  4. 2010-2014 BMW X6 Tail Light Bulb Replacement: 步骤 4 中的图像 1,3 2010-2014 BMW X6 Tail Light Bulb Replacement: 步骤 4 中的图像 2,3 2010-2014 BMW X6 Tail Light Bulb Replacement: 步骤 4 中的图像 3,3
    • Grab the light bulb socket and turn it counterclockwise until it can be removed from its hole.
    • Repeat this process for the other light bulb socket.
  5. 2010-2014 BMW X6 Tail Light Bulb Replacement: 步骤 5 中的图像 1,1
    • Remove the light bulbs from their sockets by gently pulling them away from the connectors.
  6. 2010-2014 BMW X6 Tail Light Bulb Replacement: 步骤 6 中的图像 1,3 2010-2014 BMW X6 Tail Light Bulb Replacement: 步骤 6 中的图像 2,3 2010-2014 BMW X6 Tail Light Bulb Replacement: 步骤 6 中的图像 3,3
    • Place the new bulb in the original hole.
    • Turn clockwise to secure the bulb in place.
  7. 2010-2014 BMW X6 Tail Light Bulb Replacement: 步骤 7 中的图像 1,2 2010-2014 BMW X6 Tail Light Bulb Replacement: 步骤 7 中的图像 2,2
    • Place Plastic cover along the bottom of the trunk next to the corresponding hole.
    • Push cover in till it is flush with a vertical wall of the trunk.
  8. 2010-2014 BMW X6 Tail Light Bulb Replacement: 步骤 8 中的图像 1,2 2010-2014 BMW X6 Tail Light Bulb Replacement: 步骤 8 中的图像 2,2
    • Close trunk and admire your hard work!
结论
另外一个人完成了本指南。
Juan M Perez
于10/05/21注册
190 声望
撰写一个指南
团队
CSU Los Angeles, Team 11-99, Grodsky Fall 2021 CSU Los Angeles, Team 11-99, Grodsky Fall 2021 的会员
CSULA-GRODSKY-F21S11G99
1 名成员
创作了1篇指南
一条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 89
总计 2,235
