跳转到主内容
加入维修社区 - 创建账户
2010-2017 Suzuki Swift Head Unit Replacement
浏览量: 2.7万
浏览统计数据:
过去24小时
24
过去 7 天:
98
过去 30 天:
375
总计
26,734
评论: 9
2 comments on steps, 7 guide comments.
Go to guide comments
已完成: 5
5 人已将本指南标记为“已完成”。你会是下一个完成的人吗?
收藏: 0
暂时还没有人收藏(和订阅)本指南。你会是第一个收藏(和订阅)的人吗?
所需时间: 1 - 4 小时
难度: 中等
社区贡献指南
我们社区的一个非常棒的成员制作了本指南。它不是由 iFixit 工作人员创建的。
This guide will make use of a specific kit to install an aftermarket head unit (listed at required parts). Other solutions for connecting the Suzuki head unit interface to a standard aftermarket one are probably available as well.
Depending on the solution you have available, some installation steps might be slightly different.
你所需要的
配件
工具
    1. 2010-2017 Suzuki Swift Head Unit Replacement, open top cover: 步骤 1 中的图像 1,1
      • Use the door panel removal tools to pry open the top cover.
      • You can open the top hatch in order to get a better grip on the cover.
      • Place something underneath it, to prevent it falling back into place. There is no need to detach the cover cable and complete remove it.
      询问修复机器人
      添加评论
    2. 2010-2017 Suzuki Swift Head Unit Replacement, detach the OEM head unit: 步骤 2 中的图像 1,3 2010-2017 Suzuki Swift Head Unit Replacement, detach the OEM head unit: 步骤 2 中的图像 2,3 2010-2017 Suzuki Swift Head Unit Replacement, detach the OEM head unit: 步骤 2 中的图像 3,3
      • Screw open the 2 top screws located at the red arrows. Use a magnetic tip for easy retrieval.
      • Use the door panel removal tools to pry it open from its 4 brackets.
      • Disconnect the battery at this point if you haven't done so.
      • Slowly remove the head unit from its enclosure and detach the cables.
      • Power, speaker output and steering wheel control.
      • USB input
      • antenna input
      询问修复机器人
      添加评论
    3. 2010-2017 Suzuki Swift Head Unit Replacement, fit aftermarket head unit to frame: 步骤 3 中的图像 1,1
      • Fit your aftermarket head unit to the faceplate frame of the installation kit.
      • Depending on whether you have a 1DIN or 2DIN unit, this might mean some extra work.
      • The installation kit faceplate frame has some room between the sideplates and the actual device frame.
      • Also, using a 1DIN frame did not provide enough support to not fit without the sideplates. Perhaps when installing a 2DIN device with this faceplate, no sideplates are needed for support.
      询问修复机器人
      添加评论
    4. 2010-2017 Suzuki Swift Head Unit Replacement, prepare and connect the harness: 步骤 4 中的图像 1,1
      • At (1), connect the stereo supplied power cable with the installation kit supplied adaptor cable.
      • If you have a car stereo brand specific steering wheel control interface (in your install kit), you do not have to perform the steps at (2) and (3).
      • What are the appropriate cables in the universal steering wheel interface depends on your brand aftermarket unit. The installation kit includes an overview of supported brands and install choices.
      • At (2), strip the end of the steering wheel interface cable and crimp on the appropriate "key" cable from the universal interface.
      • At (3), disconnect the appropriate patch cables and prevent them from shorting.
      • At (4), connect both leads to the steering wheel input control box.
      • The harness you made (and the antenna adapter) can be connected to your aftermarket head unit and the Suzuki cable interface.
      询问修复机器人
      添加评论
      • Reconnect the battery, turn on the car and the head unit and test if everything is working as it should be.
      • If you have to undo any of the cables, don't forget to disconnect the battery again.
      询问修复机器人
      添加评论
    5. 2010-2017 Suzuki Swift Head Unit Replacement, putting everything back together: 步骤 6 中的图像 1,2 2010-2017 Suzuki Swift Head Unit Replacement, putting everything back together: 步骤 6 中的图像 2,2
      • Make sure the clips (shown in the bottom two) are removed, or fit on the replacing faceplate frame.
      • Depending if and where you put some bolts on the replacing faceplate frame, cut out some of the plastic.
      • After that, you can click back your new head unit.
      • And finally, click back the top cover.
      添加评论
终点
取消:我没有完成这个指南。
5等其他人完成本指南。
knipwim
于09/01/18注册
16,367 声望
创作了45篇指南
7指南评论
Hi, I would like to know if the steering wheel interface is necessary because the suzuki buttons send the commands via CANBUS and the head unit only can be controlled by resistive type of buttons. Thank you.
Delorean Project - 回复 分享
Hi was this resolved? I’m seeing documentation for universal adapters suggesting they are already resistive and not canbus. I’m looking at a 2016 swift
Sean - 回复 分享
Hi,
Does the antenna need power, I bought an installation kit and not he antenna adapter there is a blue wire, i assume this needs to be connected?
Aidan Mills - 回复 分享
Not sure I connected the blue antenna cable from the kit. It mentions on the product site as a "DIN Antenna Adapter With Phantom Power Supply", so my guess would be no (https://connects2.com/Product/ProductIte...).
knipwim - 回复 分享
No this is for an old fashioned retractable aerial - these days it's a useful 12v trigger for an amp.
Nick Swift Sport - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 24
过去 7 天: 98
过去 30 天: 375
总计 26,734
