跳转到主内容
2010-2017 Suzuki Swift Engine Air Filter Replacement
你所需要的
  1. 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: 步骤 1 中的图像 1,3 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: 步骤 1 中的图像 2,3 2010-2017 Suzuki Swift Engine Air Filter Replacement, locate the filter: 步骤 1 中的图像 3,3
    • The filter housing is located behind the air intake.
    • Pull both clasps holding the filter housing to the air intake.
    • Push the housing back to see the filter.
  2. 2010-2017 Suzuki Swift Engine Air Filter Replacement, remove old filter: 步骤 2 中的图像 1,2 2010-2017 Suzuki Swift Engine Air Filter Replacement, remove old filter: 步骤 2 中的图像 2,2
    • Slide the old filter up and out.
    • Remember the only square corner of the filter is in the left bottom side.
    • Clean the immediate area of the filter housing, to make sure no dirt ends up in the engine.
  3. 2010-2017 Suzuki Swift Engine Air Filter Replacement, add new filter: 步骤 3 中的图像 1,1
    • With the square corner at the correct position, slide the new filter in.
    • Make sure the filter fits up with the backside of the air intake on all sides.
  4. 2010-2017 Suzuki Swift Engine Air Filter Replacement, close the filter housing: 步骤 4 中的图像 1,2 2010-2017 Suzuki Swift Engine Air Filter Replacement, close the filter housing: 步骤 4 中的图像 2,2
    • Underneath the air filter, 2 holes have to line up with plugs on the filter housing.
    • Once the underside is connected correctly, a small plastic protrustion has to line up with a corresponding guide on the air intake.
    • Clip back the 2 clips, and you are done.
终点
另外一个人完成了本指南。
knipwim
于09/01/18注册
8,527 声望
创作了30篇指南
一条评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 37
过去 30 天: 146
总计 6,416
