跳转到主内容
加入维修社区 - 创建账户
2010-2017 Suzuki Swift Dome Light Replacement
你所需要的
    1. 2010-2017 Suzuki Swift Dome Light Replacement, remove the dome light fixture: 步骤 1 中的图像 1,2 2010-2017 Suzuki Swift Dome Light Replacement, remove the dome light fixture: 步骤 1 中的图像 2,2
      • The light fixture is removed entirely in order to replace the bulb more easily. Also, by disconnecting the fixture, the battery does not need to be disconnected.
      • Grab the light fixture at the switch side and pull it loose.
      • Pull the power connector out by pushing on the retaining clip and pushing from below simultaneously.
      询问修复机器人
      添加评论
    2. 2010-2017 Suzuki Swift Dome Light Replacement, replace the light bulb: 步骤 2 中的图像 1,3 2010-2017 Suzuki Swift Dome Light Replacement, replace the light bulb: 步骤 2 中的图像 2,3 2010-2017 Suzuki Swift Dome Light Replacement, replace the light bulb: 步骤 2 中的图像 3,3
      • Grab the bulb and push it out of the fitting.
      • Insert the new bulb by slotting it in on the flexible end and pushing it in. Make sure the other end is slotted into the fitting.
      • If you are using a LED light, make sure you turn the lights towards the lens after installation.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
knipwim
于09/01/18注册
16,230 声望
创作了45篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 71
过去 30 天: 271
总计 2,394
