跳转到主内容
加入维修社区 - 创建账户
2010-2017 Suzuki Swift Dome Light Replacement
你所需要的
  1. 2010-2017 Suzuki Swift Dome Light Replacement, remove the dome light fixture: 步骤 1 中的图像 1,2 2010-2017 Suzuki Swift Dome Light Replacement, remove the dome light fixture: 步骤 1 中的图像 2,2
    • The light fixture is removed entirely in order to replace the bulb more easily. Also, by disconnecting the fixture, the battery does not need to be disconnected.
    • Grab the light fixture at the switch side and pull it loose.
    • Pull the power connector out by pushing on the retaining clip and pushing from below simultaneously.
  2. 2010-2017 Suzuki Swift Dome Light Replacement, replace the light bulb: 步骤 2 中的图像 1,3 2010-2017 Suzuki Swift Dome Light Replacement, replace the light bulb: 步骤 2 中的图像 2,3 2010-2017 Suzuki Swift Dome Light Replacement, replace the light bulb: 步骤 2 中的图像 3,3
    • Grab the bulb and push it out of the fitting.
    • Insert the new bulb by slotting it in on the flexible end and pushing it in. Make sure the other end is slotted into the fitting.
    • If you are using a LED light, make sure you turn the lights towards the lens after installation.
结论
knipwim
于09/01/18注册
15,067 声望
创作了43篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 57
过去 30 天: 232
总计 1,310
