跳转到主内容
2010-Present Subaru Legacy Rear Door Reassembly
  1. 2010-Present Subaru Legacy Rear Door Reassembly, 2010-Present Subaru Legacy Rear Door Reassembly: 步骤 1 中的图像 1,3 2010-Present Subaru Legacy Rear Door Reassembly, 2010-Present Subaru Legacy Rear Door Reassembly: 步骤 1 中的图像 2,3 2010-Present Subaru Legacy Rear Door Reassembly, 2010-Present Subaru Legacy Rear Door Reassembly: 步骤 1 中的图像 3,3
    • Insert the metal ball into the plastic door pull handle assembly.
    • With the ball inserted, route the steel cable through the assembly and align the black plastic notch on the cable with the plastic notch on the door pull handle assembly.
    • Press the cable notch into the door pull handle notch and snap it into place.
  2. 2010-Present Subaru Legacy Rear Door Reassembly: 步骤 2 中的图像 1,1
    • Hold the door lock in the "unlocked" position with your thumb. This will make it easier to insert the metal ball into the door lock assembly.
  3. 2010-Present Subaru Legacy Rear Door Reassembly: 步骤 3 中的图像 1,2 2010-Present Subaru Legacy Rear Door Reassembly: 步骤 3 中的图像 2,2
    • Insert the metal ball into the plastic door lock assembly.
    • With the ball inserted, route the steel cable through the assembly and align the blue plastic notch on the cable with the plastic notch on the door lock assembly.
    • Press the cable notch into the door lock notch and snap it into place.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 702
