跳转到主内容
2009 Toyota Corolla Headlight Bulb Replacement
你所需要的
  1. 2009 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: 步骤 1 中的图像 1,3 2009 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: 步骤 1 中的图像 2,3 2009 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: 步骤 1 中的图像 3,3
    • Wear gloves to avoid getting hands covered in engine grease.
    • Unlock the hood of the car by pulling the release located at the bottom-left side of the steering wheel.
    • Make sure to watch your hands for certain hazards, parts of the car may be sharp or hazardous.
  2. 2009 Toyota Corolla Headlight Bulb Replacement: 步骤 2 中的图像 1,3 2009 Toyota Corolla Headlight Bulb Replacement: 步骤 2 中的图像 2,3 2009 Toyota Corolla Headlight Bulb Replacement: 步骤 2 中的图像 3,3
    • Open the hood and lock it in place.
    • Find the bulb near the inside of where the headlight is on the car (it should be located somewhere within the red circle). It will be attached to a wire.
    • Rotate the bulb until it becomes free and pull it out of the headlight casing.
  3. 2009 Toyota Corolla Headlight Bulb Replacement: 步骤 3 中的图像 1,2 2009 Toyota Corolla Headlight Bulb Replacement: 步骤 3 中的图像 2,2
    • Press and hold the button illustrated in the photo and pull the bulb apart from the wire. If the button is jammed, a screw driver may be necessary to press the button down with more force.
    • Be careful not to snap the bulb part from the connector when working to pull it out of the cable.
    • By now, the bulb should be separate from its container.
  4. 2009 Toyota Corolla Headlight Bulb Replacement: 步骤 4 中的图像 1,1
    • Replace old bulb with new one by simply sliding it back onto the cable.
  5. 2009 Toyota Corolla Headlight Bulb Replacement: 步骤 5 中的图像 1,1
    • Install the new bulb back into the headlight casing by turning clockwise until it is firmly connected as shown in the picture. Close the hood of the car.
    • Remember to realign the grooves on the bulb to match the connection with the headlight casing.
  6. 2009 Toyota Corolla Headlight Bulb Replacement: 步骤 6 中的图像 1,1
    • Turn the car on and test your new headlight!
    • If the headlight doesn't work, turn car off and ensure the connection is correct with the headlight cable.
结论
Talha
于04/16/24注册
133 声望
撰写一个指南
团队
York University, Team 1-2, Morris Winter 2024 York University, Team 1-2, Morris Winter 2024 的会员
YORK-MORRIS-W24S1G2
5 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 14
过去 30 天: 71
总计 165
