跳转到主内容
2009 Subaru Impreza WRX Rear Door Panel Replacement
你所需要的
  1. 2009 Subaru Impreza WRX Rear Door Panel Replacement, Rear Door Panel: 步骤 1 中的图像 1,1
    • Pry off the plastic tab inside the rear door handle.
  2. 2009 Subaru Impreza WRX Rear Door Panel Replacement: 步骤 2 中的图像 1,1
    • Use the Phillips screwdriver to unscrew the 8x3/4" Phillips screw inside the door handle.
  3. 2009 Subaru Impreza WRX Rear Door Panel Replacement: 步骤 3 中的图像 1,1
    • Use a flathead screwdriver to pry up the plastic tab inside the rear door armrest.
  4. 2009 Subaru Impreza WRX Rear Door Panel Replacement: 步骤 4 中的图像 1,1
    • Use the Phillips screwdriver to unscrew the 8x3/4" Phillips screw inside the armrest.
  5. 2009 Subaru Impreza WRX Rear Door Panel Replacement: 步骤 5 中的图像 1,2 2009 Subaru Impreza WRX Rear Door Panel Replacement: 步骤 5 中的图像 2,2
    • Use flathead to pry off the upper panel located at the top of the rear door panel.
  6. 2009 Subaru Impreza WRX Rear Door Panel Replacement: 步骤 6 中的图像 1,2 2009 Subaru Impreza WRX Rear Door Panel Replacement: 步骤 6 中的图像 2,2
    • Use the flathead screwdriver to pry off and remove the panel over the door handle.
  7. 2009 Subaru Impreza WRX Rear Door Panel Replacement: 步骤 7 中的图像 1,1
    • Remove the bundle of wires from the panel by pressing the tabs on the sides of the large white plastic connector.
  8. 2009 Subaru Impreza WRX Rear Door Panel Replacement: 步骤 8 中的图像 1,1
    • Use the Phillips screwdriver to unscrew the 8x3/4" screws behind the door handle panel that was just removed.
  9. 2009 Subaru Impreza WRX Rear Door Panel Replacement: 步骤 9 中的图像 1,1
    • Use the flathead screwdriver to pry off the door panel, starting from the outside edge of the door.
  10. 2009 Subaru Impreza WRX Rear Door Panel Replacement: 步骤 10 中的图像 1,1
    • Use your hands to pull off and remove the door panel from the frame.
  11. 2009 Subaru Impreza WRX Rear Door Panel Replacement: 步骤 11 中的图像 1,1
    • Using your hands, remove the two remaining wires connecting the door panel to the frame.
    • The door panel is now completely removed from the frame.
结论
Joseph Coplon
于04/20/15注册
101 声望
撰写一个指南
团队
Cal Poly, Team 8-3, Regan Spring 2015 Cal Poly, Team 8-3, Regan Spring 2015 的会员
CPSU-REGAN-S15S8G3
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 15
总计 2,440
