跳转到主内容
2009 Subaru Impreza WRX Front Door Panel Replacement
你所需要的
  1. 2009 Subaru Impreza WRX Front Door Panel Replacement, Front Door Panel: 步骤 1 中的图像 1,2 2009 Subaru Impreza WRX Front Door Panel Replacement, Front Door Panel: 步骤 1 中的图像 2,2
    • Pry up the plastic tab from inside the handle located on the front door armrest.
  2. 2009 Subaru Impreza WRX Front Door Panel Replacement: 步骤 2 中的图像 1,1
    • Pry up the plastic tab from inside the door handle housing.
  3. 2009 Subaru Impreza WRX Front Door Panel Replacement: 步骤 3 中的图像 1,2 2009 Subaru Impreza WRX Front Door Panel Replacement: 步骤 3 中的图像 2,2
    • Use your Phillips screwdriver to unscrew the 8x3/4" Phillips screw by the upper door handle.
    • Unscrew the second 8x3/4" Phillips screw located inside the lower door handle on the door's armrest.
  4. 2009 Subaru Impreza WRX Front Door Panel Replacement: 步骤 4 中的图像 1,2 2009 Subaru Impreza WRX Front Door Panel Replacement: 步骤 4 中的图像 2,2
    • Pry off the entire door speaker and its housing located inside of the mirror.
    • Using your flathead screwdriver, pry up the latch connecting the two white cords and disconnect the speaker.
  5. 2009 Subaru Impreza WRX Front Door Panel Replacement: 步骤 5 中的图像 1,2 2009 Subaru Impreza WRX Front Door Panel Replacement: 步骤 5 中的图像 2,2
    • Using your flathead screwdriver, pry the middle plastic door piece away from the armrest.
  6. 2009 Subaru Impreza WRX Front Door Panel Replacement: 步骤 6 中的图像 1,2 2009 Subaru Impreza WRX Front Door Panel Replacement: 步骤 6 中的图像 2,2
    • Using your flathead screwdriver, press the white tab on the side of the larger cord bundle connecting the assembly.
    • The larger cord bundle now can be pulled out.
    • Press the white tab on the smaller cord bundle and disconnect the smaller cord bundle from the assembly.
    • Take note of the two screws that are now visible in the middle of the door panel.
  7. 2009 Subaru Impreza WRX Front Door Panel Replacement: 步骤 7 中的图像 1,2 2009 Subaru Impreza WRX Front Door Panel Replacement: 步骤 7 中的图像 2,2
    • Unscrew both 8x3/4" Phillips screws from the middle of the door panel using your Phillips screwdriver.
  8. 2009 Subaru Impreza WRX Front Door Panel Replacement: 步骤 8 中的图像 1,2 2009 Subaru Impreza WRX Front Door Panel Replacement: 步骤 8 中的图像 2,2
    • Pry the left side of the door panel away from the door using a flathead screwdriver.
    • It may be easiest to start by prying away where the red circle is located.
  9. 2009 Subaru Impreza WRX Front Door Panel Replacement: 步骤 9 中的图像 1,2 2009 Subaru Impreza WRX Front Door Panel Replacement: 步骤 9 中的图像 2,2
    • Using your hands now, pry the door panel away from the door.
    • You will hear a series of pops when the white tabs disconnect from the door.
  10. 2009 Subaru Impreza WRX Front Door Panel Replacement: 步骤 10 中的图像 1,2 2009 Subaru Impreza WRX Front Door Panel Replacement: 步骤 10 中的图像 2,2
    • Finish pulling the door off of the frame, now that all the clips have been disconnected.
    • Pull the door from the top, not the bottom or sides.
  11. 2009 Subaru Impreza WRX Front Door Panel Replacement: 步骤 11 中的图像 1,1
    • Disconnect the final two power window cables that connect the door panel to the door frame by pulling both out of their sockets.
    • Congratulations! You are now done.
结论
2等其他人完成本指南。
Alex Spady
于05/01/15注册
180 声望
撰写一个指南
团队
Cal Poly, Team 8-3, Regan Spring 2015 Cal Poly, Team 8-3, Regan Spring 2015 的会员
CPSU-REGAN-S15S8G3
5 名成员
创作了5篇指南
一条评论
Do you know if the elbow pad can be replaced by itself or does the whole panel need to be replaced?
J B - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 29
总计 2,691
