简介
If your AUX port randomly disconnects or doesn’t work, you need a replacement port. You can buy a replacement port on online stores like Amazon.
Open the glove box
Pry up on the cup holders on the front of the glove box. You can do this with your fingers
Un-clip and pull up on the cup holders, freeing the parking brake in the process
Use a screwdriver or a plastic pry tool to push down on the connector's clips.
Remove the front panel
Push on the connector on the back of the auxiliary port to remove the port from the casing
Pull out the port
To reassemble your the connector and the dash, follow these instructions in reverse order.
另外一个人完成了本指南。
