跳转到主内容
2009-2019 Dodge Ram Fog Lights Replacement
你所需要的
  1. 2009-2019 Dodge Ram Fog Lights Replacement, Fog Lights: 步骤 1 中的图像 1,1
    • Pull the hood latch that is located beneath the steering column.
  2. 2009-2019 Dodge Ram Fog Lights Replacement: 步骤 2 中的图像 1,1
    • Push the lever to the left to unlatch the hood of the truck.
  3. 2009-2019 Dodge Ram Fog Lights Replacement: 步骤 3 中的图像 1,1
    • Using the ratchet and 10mm socket, disconnect the negative battery terminal by turning counterclockwise.
    • This is done to make sure you do not get shortages.
  4. 2009-2019 Dodge Ram Fog Lights Replacement: 步骤 4 中的图像 1,1
    • Disconnect the lighting harness.
    • Do not remove the bulb since the new fog lamp comes with integrated LED bulbs.
  5. 2009-2019 Dodge Ram Fog Lights Replacement: 步骤 5 中的图像 1,1
    • Using the ratchet, extension, and the 10 mm socket unscrew the three 10 mm bolts to let the mounting plate free.
  6. 2009-2019 Dodge Ram Fog Lights Replacement: 步骤 6 中的图像 1,2 2009-2019 Dodge Ram Fog Lights Replacement: 步骤 6 中的图像 2,2
    • Push the tabs inward and pull the mounting bracket towards you to separate the bracket from the fog lamp.
  7. 2009-2019 Dodge Ram Fog Lights Replacement: 步骤 7 中的图像 1,1
    • Grab the new fog lamp and insert the three clips into the three holes of the mounting bracket.
  8. 2009-2019 Dodge Ram Fog Lights Replacement: 步骤 8 中的图像 1,2 2009-2019 Dodge Ram Fog Lights Replacement: 步骤 8 中的图像 2,2
    • Align the three screw holes on the mounting bracket with the holes on the bumper.
  9. 2009-2019 Dodge Ram Fog Lights Replacement: 步骤 9 中的图像 1,2 2009-2019 Dodge Ram Fog Lights Replacement: 步骤 9 中的图像 2,2
    • Screw on the three 10 mm bolts in the holes.
    • Tighten the bolts by hand first.
    • Tighten the bolts using the 10 mm socket and ratchet.
  10. 2009-2019 Dodge Ram Fog Lights Replacement: 步骤 10 中的图像 1,2 2009-2019 Dodge Ram Fog Lights Replacement: 步骤 10 中的图像 2,2
    • Reconnect the lighting harness back up to get a power source.
  11. 2009-2019 Dodge Ram Fog Lights Replacement: 步骤 11 中的图像 1,2 2009-2019 Dodge Ram Fog Lights Replacement: 步骤 11 中的图像 2,2
    • Make sure the fog lamp is where it is desired and in place.
  12. 2009-2019 Dodge Ram Fog Lights Replacement: 步骤 12 中的图像 1,1
    • Reconnect the negative battery terminal.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 74
总计 1,996
