跳转到主内容
2009年中 15寸 MacBook Pro 一体化机RAM 更换
你所需要的
  1. 2009年中 15寸 MacBook Pro 一体化机RAM 更换, 底壳: 步骤 1 中的图像 1,1
    • 卸下以下十颗将下盖固定到上盖的螺丝:
    • 七颗 3 mm 菲利普斯十字螺丝。
    • 三颗 13.5 mm 菲利普斯十字螺丝。
  2. 2009年中 15寸 MacBook Pro 一体化机RAM 更换: 步骤 2 中的图像 1,2 2009年中 15寸 MacBook Pro 一体化机RAM 更换: 步骤 2 中的图像 2,2
    • 双手抬起下壳,使其靠近通风孔,以将其从固定到上壳的两个夹扣中弹出。
    • 拆下下壳并将其放在一旁。
  3. 2009年中 15寸 MacBook Pro 一体化机RAM 更换, RAM: 步骤 3 中的图像 1,2 2009年中 15寸 MacBook Pro 一体化机RAM 更换, RAM: 步骤 3 中的图像 2,2
    • 通过同时将每个卡扣推离RAM来释放芯片两侧的卡扣。
    • 这些卡扣将芯片锁定在适当的位置,打开它们会导致芯片“弹出”。
    • 弹出RAM芯片后,将其从插槽中直接拉出。
    • 如果安装了第二个 RAM 芯片,请重复此过程。
结论
请按逆序重组你的设备。
160等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
5指南评论
I bought and installed 4GB x2 RAM for my Mid 2009 15 inch MacBook Pro and it was easy and is working great. Before this I had 4GB and it was being maxed out. It was very easy. I did purchase the required tools which made it simple. I also swapped the battery at the same time. I am writing this from the same computer and it is working well. Good luck!
1tom2go - 回复
I had no trouble installing the 4 GB RAM I bought for my Mid 2009 15 Inch MacBook Pro. The mistake I made though was not realising that my machine has two RAM slots. I only bought one chip! So now I have to buy another one.
If you read this before you buy some RAM, make sure you check how many slots your computer has!
Also, I must say the customer support from ifixit is great. I messaged them about this and some other issues I was having and I got a detailed response from them within a couple of days. Thanks guys!
oliverbarrand - 回复
Thanks! You saved my life.
saltyhf - 回复
I replaced my original 2x 2gb ram with 2x 4gb RAM following your instructions. However, upon boot up, it’s only showing 1 of the 2 4gb chips. Any tips on how to get both seated correctly?
Matthew Longo - 回复
Never mind. I was able to pop the second chip back out and get it seated properly.
Matthew Longo -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 47
总计 62,457
