跳转到主内容
2008 Volkswagen Jetta Radio Replacement
你所需要的
  1. 2008 Volkswagen Jetta Radio Replacement, Radio: 步骤 1 中的图像 1,1
    • Starting from the back of the top panel, pry open the top panel with a panel tool.
    • Remove the top panel exposing the under.
    • Be careful when removing the layers as they have very delicate clips holding them together.
  2. 2008 Volkswagen Jetta Radio Replacement: 步骤 2 中的图像 1,3 2008 Volkswagen Jetta Radio Replacement: 步骤 2 中的图像 2,3 2008 Volkswagen Jetta Radio Replacement: 步骤 2 中的图像 3,3
    • Use the T20 Torx screwdriver to remove the single screw.
    • After screw is removed, pull out the cover.
  3. 2008 Volkswagen Jetta Radio Replacement: 步骤 3 中的图像 1,1
    • Within the third layer, remove two more screws using the T20 Torx Screwdriver.
    • Use the panel tool to unclip the three clips on the back then remove the 3rd panel.
  4. 2008 Volkswagen Jetta Radio Replacement: 步骤 4 中的图像 1,3 2008 Volkswagen Jetta Radio Replacement: 步骤 4 中的图像 2,3 2008 Volkswagen Jetta Radio Replacement: 步骤 4 中的图像 3,3
    • Use the panel tool and slowly loosen up the outer shell by following the crevice outline.
    • Once loosened up remove the upper face layer.
    • When removing this layer there will be a wire connecting the passenger air bag light. Leave that wire alone and carefully place the layer on the dashboard.
  5. 2008 Volkswagen Jetta Radio Replacement: 步骤 5 中的图像 1,2 2008 Volkswagen Jetta Radio Replacement: 步骤 5 中的图像 2,2
    • Remove the two screws using the T20 Torx Screwdriver.
    • Use the panel tool once again to carefully open up the crevices on the bottom cover. Remove the layer.
  6. 2008 Volkswagen Jetta Radio Replacement: 步骤 6 中的图像 1,1
    • Use the T20 Torx remove the four screws placing the radio in place.
    • Once the screws are removed carefully pull out the radio to reveal the wires connected on the back.
  7. 2008 Volkswagen Jetta Radio Replacement: 步骤 7 中的图像 1,3 2008 Volkswagen Jetta Radio Replacement: 步骤 7 中的图像 2,3 2008 Volkswagen Jetta Radio Replacement: 步骤 7 中的图像 3,3
    • There will be two clipped wires on the back of he radio.
    • Push the clips in on the black wires connected to loosen them up and carefully pull out the wire.
    • The second bunch of wires will only require a flip of the lever down on the bottom of the black outer box. Once flipped up remove the whole box to free the radio.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 35
过去 30 天: 115
总计 3,361
