跳转到主内容
2008-2010 Audi A3 Sportback Key FOB Battery Replacement
你所需要的
  1. 2008-2010 Audi A3 Sportback Key FOB Battery Replacement, Key FOB Battery: 步骤 1 中的图像 1,3 2008-2010 Audi A3 Sportback Key FOB Battery Replacement, Key FOB Battery: 步骤 1 中的图像 2,3 2008-2010 Audi A3 Sportback Key FOB Battery Replacement, Key FOB Battery: 步骤 1 中的图像 3,3
    • With the tip of a flat head screwdriver, insert it under the edge of the key fob and push against the back cover to pop it off.
    • Take caution as you apply force to open the cover as the flathead screwdriver is a sharp tool.
  2. 2008-2010 Audi A3 Sportback Key FOB Battery Replacement: 步骤 2 中的图像 1,2 2008-2010 Audi A3 Sportback Key FOB Battery Replacement: 步骤 2 中的图像 2,2
    • Remove the round CR2032 battery from the fob back cover with a plastic spudger or opening tool.
    • The battery has a "+" positive side (textured surface) and a "–" negative side (smooth surface).
  3. 2008-2010 Audi A3 Sportback Key FOB Battery Replacement: 步骤 3 中的图像 1,1
    • Insert a new battery and pop the cover back on by hand.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 36
过去 30 天: 140
总计 6,955
