跳转到主内容
2008-2012 Honda Accord Headlight Bulb Replacement
你所需要的
  1. 2008-2012 Honda Accord Headlight Bulb Replacement, Headlight Bulb: 步骤 1 中的图像 1,1
    • (Right Side Headlight)
    • Turn the wheel all the way inward to have enough clearance.
    • Turn the vehicle fully off before proceeding to the next step.
  2. 2008-2012 Honda Accord Headlight Bulb Replacement: 步骤 2 中的图像 1,3 2008-2012 Honda Accord Headlight Bulb Replacement: 步骤 2 中的图像 2,3 2008-2012 Honda Accord Headlight Bulb Replacement: 步骤 2 中的图像 3,3
    • Locate the inner fender's retainer clips.
    • Using a flat-head screwdriver, pry out the retainer clips.
  3. 2008-2012 Honda Accord Headlight Bulb Replacement: 步骤 3 中的图像 1,1
    • Pry back the inner fender liner to gain access to the headlight bulb.
    • An object may be needed to keep the fender liner pulled back
  4. 2008-2012 Honda Accord Headlight Bulb Replacement: 步骤 4 中的图像 1,3 2008-2012 Honda Accord Headlight Bulb Replacement: 步骤 4 中的图像 2,3 2008-2012 Honda Accord Headlight Bulb Replacement: 步骤 4 中的图像 3,3
    • Locate the headlight bulb, and turn the item clockwise so that it points towards the engine.
    • For the left bulb, turn the item counter clock-wise
  5. 2008-2012 Honda Accord Headlight Bulb Replacement: 步骤 5 中的图像 1,2 2008-2012 Honda Accord Headlight Bulb Replacement: 步骤 5 中的图像 2,2
    • Pull out the headlight bulb from its socket.
    • Be careful while pulling the bulb out, you might damage the bulb or its connected cable.
  6. 2008-2012 Honda Accord Headlight Bulb Replacement: 步骤 6 中的图像 1,3 2008-2012 Honda Accord Headlight Bulb Replacement: 步骤 6 中的图像 2,3 2008-2012 Honda Accord Headlight Bulb Replacement: 步骤 6 中的图像 3,3
    • For a more visible view of this step since the space is small and cluttered. -Credit for these 3 pictures: @PrecisionLED
    • To disconnect the bulb, pinch the top of the white block to release it from the bulb
    • When installing a new bulb, be careful while handling the bulb to not smudge or damage the bulb.
结论
Carson Nguyen
于10/23/23注册
133 声望
撰写一个指南
团队
CSU Los Angeles, Team 5-16, Kershman Fall 2023 CSU Los Angeles, Team 5-16, Kershman Fall 2023 的会员
CSULA-KERSHMAN-F23S5G16
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 118
过去 30 天: 445
总计 2,832
