跳转到主内容
2008-2013 Subaru Forester Oil & Filter Replacement
你所需要的
视频概述
  1. 2008-2013 Subaru Forester Oil & Filter Replacement, Draining the old oil out: 步骤 1 中的图像 1,1
    • Engine oil can be scalding hot! If your engine is warmed up, wait a few minutes to allow the oil to cool before beginning.
    • Drive your Subaru's front wheels up onto ramps. Shut off engine. Then crawl under and find the oil drain plug/bolt. Make sure to have your oil catching device under the drain bolt. Then unscrew!
  2. 2008-2013 Subaru Forester Oil & Filter Replacement, Changing the oil filter: 步骤 2 中的图像 1,1
    • As the oil drains, get out from under your car and take off oil filter. Make sure the old gasket comes off with old oil filter. If not, remove from engine. Then add some oil to the gasket of the new filter via your finger. Then scew onto engine but do not over tighten.
  3. 2008-2013 Subaru Forester Oil & Filter Replacement, Tighten the drain plug: 步骤 3 中的图像 1,1
    • Before refiling the engine with 0W-20 oil, reinstall and tighten the drain plug. Don't over tighten!
  4. 2008-2013 Subaru Forester Oil & Filter Replacement, Refilling the engine with new oil: 步骤 4 中的图像 1,1
    • Refill the engine with oil. Do not over-fill. Add the amount that is suggested in the owners manual.
  5. 2008-2013 Subaru Forester Oil & Filter Replacement, Checking the oil: 步骤 5 中的图像 1,1
    • Start the engine. Verify there are no leaks. Then drive your Subaru to a flat place. Shut off engine. Open the hood and take out the engine oil dipstick. Wipe with a paper towel. Reinsert all the way. Then take out again. Make sure the oil is full. Add more if necessary!
  6. 2008-2013 Subaru Forester Oil & Filter Replacement, Writing the information down: 步骤 6 中的图像 1,1
    • Write down the date and total mileage so you know when to change the oil next.
终点
另外一个人完成了本指南。
Nick
于07/31/13注册
210 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 10
过去 7 天: 60
过去 30 天: 302
总计 10,882
