跳转到主内容
2008-2013 Subaru Forester Engine Air Intake Filter Replacement
你所需要的
  1. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement, Engine Air Intake Filter: 步骤 1 中的图像 1,2 2008-2013 Subaru Forester Engine Air Intake Filter Replacement, Engine Air Intake Filter: 步骤 1 中的图像 2,2
    • Make sure that the vehicle is turned off before you start.
    • Pull the hood release latch under the driver's dashboard to unlock the hood.
    • Press on the latch under the hood to expose the engine.
  2. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: 步骤 2 中的图像 1,2 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: 步骤 2 中的图像 2,2
    • Locate the engine air intake holding and hose.
  3. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: 步骤 3 中的图像 1,2 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: 步骤 3 中的图像 2,2
    • Unclip and separate the sensor and sensor cable on top of the holding.
    • Move the sensor cable to the side to prevent it from getting in the way.
  4. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: 步骤 4 中的图像 1,2 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: 步骤 4 中的图像 2,2
    • Unlatch the metal clips keeping the holding together.
  5. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: 步骤 5 中的图像 1,2 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: 步骤 5 中的图像 2,2
    • Use a 1/4" flat screwdriver to loosen the metal hose fastener on the engine air intake hose.
    • Do not remove the metal hose fastener. Keep the fastener on the hose for easy reassembly.
    • Remove the engine air intake hose from the holding.
    • Move the engine air intake hose to the side to prevent it from getting in the way.
  6. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: 步骤 6 中的图像 1,2 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: 步骤 6 中的图像 2,2
    • Separate the two sides of the holding from each other.
    • Remove the back panel of the holding to add space to remove the engine air filter.
  7. 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: 步骤 7 中的图像 1,2 2008-2013 Subaru Forester Engine Air Intake Filter Replacement: 步骤 7 中的图像 2,2
    • Remove the old engine air intake filter from the holding.
    • Insert the new engine air intake filter into the holding in the same position as the old filter.
结论
Julianna Sober
于09/29/21注册
145 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 85
总计 2,705
