跳转到主内容
2008-2013 Subaru Forester Cabin Air Filter Replacement
你所需要的
  1. 2008-2013 Subaru Forester Cabin Air Filter Replacement, Cabin Air Filter: 步骤 1 中的图像 1,1
    • Ensure the vehicle is shut off with the key removed from the ignition before you begin.
    • Open the glovebox located on the passenger side.
  2. 2008-2013 Subaru Forester Cabin Air Filter Replacement: 步骤 2 中的图像 1,2 2008-2013 Subaru Forester Cabin Air Filter Replacement: 步骤 2 中的图像 2,2
    • Unhook the glovebox retention arm from the side of the glovebox by squeezing the clip together with your fingertips, and prying the arm off the lower connection point only.
    • Gently push the arm up and half way in to prevent accidental breakage.
  3. 2008-2013 Subaru Forester Cabin Air Filter Replacement: 步骤 3 中的图像 1,2 2008-2013 Subaru Forester Cabin Air Filter Replacement: 步骤 3 中的图像 2,2
    • Starting on either the left or right side, insert screwdriver blade tip into the small catch ramp until it releases.
    • Repeat inserting screwdriver blade tip on opposite side of glovebox and catch ramp until both sides are released and glovebox falls freely open.
  4. 2008-2013 Subaru Forester Cabin Air Filter Replacement: 步骤 4 中的图像 1,2 2008-2013 Subaru Forester Cabin Air Filter Replacement: 步骤 4 中的图像 2,2
    • Remove the glovebox by pulling horizontally away from its (C shaped) hinge points.
  5. 2008-2013 Subaru Forester Cabin Air Filter Replacement: 步骤 5 中的图像 1,3 2008-2013 Subaru Forester Cabin Air Filter Replacement: 步骤 5 中的图像 2,3 2008-2013 Subaru Forester Cabin Air Filter Replacement: 步骤 5 中的图像 3,3
    • Open door to filter compartment to access filter.
    • Remove filter media.
    • Note orientation of filter for reinsertion.
结论
Finally, to reinstall the clean cabin air filter, simply follow these same instructions, but in reverse order.
Purchasing and replacing your own cabin filter is simple, time-saving, and resourceful. Congratulations on a job well done!
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 38
过去 30 天: 162
总计 5,308
