跳转到主内容
2008 - 2020 Dodge Caravan Headlight Bulb Replacement
你所需要的
  1. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement, Headlight bulb: 步骤 1 中的图像 1,1
    • Park the car on a level surface.
    • Turn off the car and put on the emergency break for extra safety.
  2. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: 步骤 2 中的图像 1,2 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: 步骤 2 中的图像 2,2
    • Lift the hood release on the drivers side seat, near the foot pedals.
    • Open the hood latch and lift the hood up until it stays open on its own.
    • The headlight socket is located along inside edge of the hood.
  3. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: 步骤 3 中的图像 1,3 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: 步骤 3 中的图像 2,3 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: 步骤 3 中的图像 3,3
    • At the rear of the headlight assembly, rotate the bulb in a counterclockwise direction to detach it from the socket.
    • Release the clips on both sides and take it out from the wiring harness.
    • Insert the new bulb into the harness. You will know it is complete when you feel the clips attaching.
    • Don't touch the bulb with your bare hands. The oils and salt from your hands will reduce the life of the bulb and possibly damage it.
  4. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: 步骤 4 中的图像 1,1
    • Align the tabs on the socket with the opening on the back to reinstall it.
    • Turn the socket clockwise to secure it.
  5. 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: 步骤 5 中的图像 1,2 2008 - 2020 Dodge Caravan Headlight Bulb Replacement: 步骤 5 中的图像 2,2
    • Close the hood.
    • Test out your new lights.
    • To view the lights better, test them out at night.
结论
To replace other lights, follow the same guide.
2等其他人完成本指南。
团队
York University, Team 1-2, O'Regan Fall 2023 York University, Team 1-2, O'Regan Fall 2023 的会员
YORK-O'REGAN-F23S1G2
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 84
总计 639
