跳转到主内容
2007 Toyota Highlander Key Case Replacement
你所需要的
  1. 2007 Toyota Highlander Key Case Replacement, Key Case: 步骤 1 中的图像 1,1
    • Locate the seam of the casing.
    • The seam might be only available on one side of the key fob. Make sure to look on all sides for the seam.
  2. 2007 Toyota Highlander Key Case Replacement: 步骤 2 中的图像 1,3 2007 Toyota Highlander Key Case Replacement: 步骤 2 中的图像 2,3 2007 Toyota Highlander Key Case Replacement: 步骤 2 中的图像 3,3
    • Use a prying tool to pry open the key fob casing.
    • Tools other than a screwdriver can be used, but for safety purposes it is important to use a tool that is small enough to open the seam but not sharp enough to hurt yourself.
    • While it does take a somewhat large amount of force to open the case, it should not take more than you should be able to provide with just a tool. Too much force may damage the components, so be sure to be careful when prying.
  3. 2007 Toyota Highlander Key Case Replacement: 步骤 3 中的图像 1,2 2007 Toyota Highlander Key Case Replacement: 步骤 3 中的图像 2,2
    • Remove the electronics from the damaged casing.
    • Be sure to handle the electronics with care, as damaged electronics might lead to a key more damaged than before.
    • The battery may be loose or even fall out. This is ok; simply put the battery back in the slot that it might've fallen out of.
  4. 2007 Toyota Highlander Key Case Replacement: 步骤 4 中的图像 1,3 2007 Toyota Highlander Key Case Replacement: 步骤 4 中的图像 2,3 2007 Toyota Highlander Key Case Replacement: 步骤 4 中的图像 3,3
    • Put the electronics into the new case.
    • Again, handle the electronics with care.
    • The electronics need to be placed in the correct side of the key. This side should be the one you took it out of, or commonly the opposite side of the buttons.
  5. 2007 Toyota Highlander Key Case Replacement: 步骤 5 中的图像 1,3 2007 Toyota Highlander Key Case Replacement: 步骤 5 中的图像 2,3 2007 Toyota Highlander Key Case Replacement: 步骤 5 中的图像 3,3
    • Make sure the buttons and two sides of the casing are lined up.
    • The casings must line up properly for the next step; otherwise the key or its components may be damaged.
  6. 2007 Toyota Highlander Key Case Replacement: 步骤 6 中的图像 1,3 2007 Toyota Highlander Key Case Replacement: 步骤 6 中的图像 2,3 2007 Toyota Highlander Key Case Replacement: 步骤 6 中的图像 3,3
    • Carefully close the new casing and ensure that there is not too much force required to close the case. The two sides should lock with a clicking sound. Make sure to check that the case does not open easily to ensure a successful repair.
    • If the two sides do not properly connect, the key may not be successfully reassembled. Make sure that the key does not reopen and it's reconstructed properly.
终点
另外一个人完成了本指南。
Katelyn Rohlwing
于02/20/24注册
145 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 62
