跳转到主内容
2007-2011 Toyota Yaris Drip Rail Replacement
你所需要的
  1. 2007-2011 Toyota Yaris Drip Rail Replacement, Drip Rail: 步骤 1 中的图像 1,3 2007-2011 Toyota Yaris Drip Rail Replacement, Drip Rail: 步骤 1 中的图像 2,3 2007-2011 Toyota Yaris Drip Rail Replacement, Drip Rail: 步骤 1 中的图像 3,3
    • Peel back the old molding from where it is beginning to come off until you reach the end of the rail.
  2. 2007-2011 Toyota Yaris Drip Rail Replacement: 步骤 2 中的图像 1,3 2007-2011 Toyota Yaris Drip Rail Replacement: 步骤 2 中的图像 2,3 2007-2011 Toyota Yaris Drip Rail Replacement: 步骤 2 中的图像 3,3
    在这个步骤中使用的工具:
    Heavy-Duty Spudger
    购买
    • Use a heavy duty spudger to disconnect the end of the drip rail.
    • It may be connected at the end pretty tightly so it could take some work to remove.
    • Completely remove the piece from the end.
  3. 2007-2011 Toyota Yaris Drip Rail Replacement: 步骤 3 中的图像 1,3 2007-2011 Toyota Yaris Drip Rail Replacement: 步骤 3 中的图像 2,3 2007-2011 Toyota Yaris Drip Rail Replacement: 步骤 3 中的图像 3,3
    • Take a rag and clean out any dirt and debris that built up under the old molding.
  4. 2007-2011 Toyota Yaris Drip Rail Replacement: 步骤 4 中的图像 1,3 2007-2011 Toyota Yaris Drip Rail Replacement: 步骤 4 中的图像 2,3 2007-2011 Toyota Yaris Drip Rail Replacement: 步骤 4 中的图像 3,3
    • Slide the end of the new piece into the designated spot and press firmly to ensure it's connected securely.
    • Lightly tug at it to make it is secure and won't come off.
    • Do the same to the opposite end of the drip rail.
    • The molding for the left and right drip rails are different parts.
  5. 2007-2011 Toyota Yaris Drip Rail Replacement: 步骤 5 中的图像 1,3 2007-2011 Toyota Yaris Drip Rail Replacement: 步骤 5 中的图像 2,3 2007-2011 Toyota Yaris Drip Rail Replacement: 步骤 5 中的图像 3,3
    • Firmly press the drip rail into its place starting at one end and moving down the car.
    • Check to make sure the new drip rail is thoroughly sealed to the car.
结论
Isabel Sagheb
于04/19/23注册
121 声望
撰写一个指南
团队
UC Davis, Team 2-2, Morris Spring 2023 UC Davis, Team 2-2, Morris Spring 2023 的会员
UCD-MORRIS-S23S2G2
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 70
总计 814
