跳转到主内容
2007-2011 Toyota Camry Headlight Bulb Replacement
  1. 2007-2011 Toyota Camry Headlight Bulb Replacement, Headlight Bulb: 步骤 1 中的图像 1,2 2007-2011 Toyota Camry Headlight Bulb Replacement, Headlight Bulb: 步骤 1 中的图像 2,2
    • Pop up the hood of the car.
  2. 2007-2011 Toyota Camry Headlight Bulb Replacement: 步骤 2 中的图像 1,2 2007-2011 Toyota Camry Headlight Bulb Replacement: 步骤 2 中的图像 2,2
    • Locate the headlight bulb on the inside of the hood and hold onto the bulb.
    • The other headlight bulb is in the same area on the other side of the car.
  3. 2007-2011 Toyota Camry Headlight Bulb Replacement: 步骤 3 中的图像 1,2 2007-2011 Toyota Camry Headlight Bulb Replacement: 步骤 3 中的图像 2,2
    • Turn counterclockwise (1/4 of a turn) to remove the bulb and its attached plug from the socket.
    • This step is applied for both headlight bulbs.
  4. 2007-2011 Toyota Camry Headlight Bulb Replacement: 步骤 4 中的图像 1,2 2007-2011 Toyota Camry Headlight Bulb Replacement: 步骤 4 中的图像 2,2
    • Hold onto the bulb with one hand while holding down the clip at the bottom of the plug to remove the bulb.
  5. 2007-2011 Toyota Camry Headlight Bulb Replacement: 步骤 5 中的图像 1,2 2007-2011 Toyota Camry Headlight Bulb Replacement: 步骤 5 中的图像 2,2
    • Remove the new bulb from its package.
    • Make sure to not touch the glass part with your hands. This can cause a hot spot on the bulb, making it burn out faster. Wipe the bulb with a paper towel if contact was made.
  6. 2007-2011 Toyota Camry Headlight Bulb Replacement: 步骤 6 中的图像 1,2 2007-2011 Toyota Camry Headlight Bulb Replacement: 步骤 6 中的图像 2,2
    • Place the bulb back into the plug and press down until it click into place.
    • The bulb only goes in one way. Make sure the plug and the bulb are facing the same direction.
结论
3等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 48
过去 30 天: 274
总计 13,108
