跳转到主内容
2007-2011 Honda CRV Stereo Replacement
你所需要的
  1. 2007-2011 Honda CRV Stereo Replacement, 2011 Honda CRV Radio: 步骤 1 中的图像 1,1
    • Use caution, make sure your car is completely powered off and in park before you begin the repair. Do not have the key in the ignition.
    • Find the radio panel, also known as the automotive head unit, positioned centrally on the dashboard.
  2. 2007-2011 Honda CRV Stereo Replacement: 步骤 2 中的图像 1,3 2007-2011 Honda CRV Stereo Replacement: 步骤 2 中的图像 2,3 2007-2011 Honda CRV Stereo Replacement: 步骤 2 中的图像 3,3
    • Use a trim removal tool to loosen and pry the AC control until it detaches from the dashboard.
  3. 2007-2011 Honda CRV Stereo Replacement: 步骤 3 中的图像 1,3 2007-2011 Honda CRV Stereo Replacement: 步骤 3 中的图像 2,3 2007-2011 Honda CRV Stereo Replacement: 步骤 3 中的图像 3,3
    • Use your hands to pull the AC control forward and pop it out.
    • Even when loosened, the AC control may be difficult to pull out and remove. Do not be afraid to use force to remove it from the dashboard.
  4. 2007-2011 Honda CRV Stereo Replacement: 步骤 4 中的图像 1,3 2007-2011 Honda CRV Stereo Replacement: 步骤 4 中的图像 2,3 2007-2011 Honda CRV Stereo Replacement: 步骤 4 中的图像 3,3
    • With the AC control out, push down on the connector tab to release the AC cable at the back of the unit.
    • Don't pull on the cable itself and don't yank the cable as excessive force may cause damage.
  5. 2007-2011 Honda CRV Stereo Replacement: 步骤 5 中的图像 1,3 2007-2011 Honda CRV Stereo Replacement: 步骤 5 中的图像 2,3 2007-2011 Honda CRV Stereo Replacement: 步骤 5 中的图像 3,3
    • Use a trim removal tool to pop out the top panel above the AC vents.
    • Start in the top middle section to loosen it.
    • There is a small opening where you can place the trim tool to get started.
  6. 2007-2011 Honda CRV Stereo Replacement: 步骤 6 中的图像 1,3 2007-2011 Honda CRV Stereo Replacement: 步骤 6 中的图像 2,3 2007-2011 Honda CRV Stereo Replacement: 步骤 6 中的图像 3,3
    • Use a trim removal tool to pry open the AC vent.
    • Insert the tool along the bottom and sides of the vents, gently prying until it becomes loose.
  7. 2007-2011 Honda CRV Stereo Replacement: 步骤 7 中的图像 1,3 2007-2011 Honda CRV Stereo Replacement: 步骤 7 中的图像 2,3 2007-2011 Honda CRV Stereo Replacement: 步骤 7 中的图像 3,3
    • Pull the vents towards you from the sides.
    • The vent unit should pop out easily once it is loosened. Put it up on the dash board and out of the way.
  8. 2007-2011 Honda CRV Stereo Replacement: 步骤 8 中的图像 1,3 2007-2011 Honda CRV Stereo Replacement: 步骤 8 中的图像 2,3 2007-2011 Honda CRV Stereo Replacement: 步骤 8 中的图像 3,3
    • Use Phillips #2 screwdriver to remove the top two 12 mm screws.
  9. 2007-2011 Honda CRV Stereo Replacement: 步骤 9 中的图像 1,3 2007-2011 Honda CRV Stereo Replacement: 步骤 9 中的图像 2,3 2007-2011 Honda CRV Stereo Replacement: 步骤 9 中的图像 3,3
    • Use Phillips #2 screwdriver to remove the two 12 mm screws below the radio unit.
  10. 2007-2011 Honda CRV Stereo Replacement: 步骤 10 中的图像 1,3 2007-2011 Honda CRV Stereo Replacement: 步骤 10 中的图像 2,3 2007-2011 Honda CRV Stereo Replacement: 步骤 10 中的图像 3,3
    • Wiggle and pull the radio unit forward until it is freed from the dashboard.
  11. 2007-2011 Honda CRV Stereo Replacement: 步骤 11 中的图像 1,3 2007-2011 Honda CRV Stereo Replacement: 步骤 11 中的图像 2,3 2007-2011 Honda CRV Stereo Replacement: 步骤 11 中的图像 3,3
    • Press on the three cable connector tabs to release them from their sockets and remove the three gray cables from the back of the radio unit.
    • Use caution to avoid excessively stressing exposed cables during removal, making sure to exert force only on the plastic removal tabs.
  12. 2007-2011 Honda CRV Stereo Replacement: 步骤 12 中的图像 1,2 2007-2011 Honda CRV Stereo Replacement: 步骤 12 中的图像 2,2
    • Remove the car stereo from the dashboard.
结论
Christa Day
于02/26/24注册
205 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 86
总计 170
