跳转到主内容
2007-2012 Jeep Wrangler Air Filter Replacement
  1. 2007-2012 Jeep Wrangler Air Filter Replacement, How to open the 2007-2012 Jeep Wrangler hood: 步骤 1 中的图像 1,2 2007-2012 Jeep Wrangler Air Filter Replacement, How to open the 2007-2012 Jeep Wrangler hood: 步骤 1 中的图像 2,2
    • Locate the two grey latches on each side of the hood near the headlights.
    • Pull the latches away from the hood to release the latches.
  2. 2007-2012 Jeep Wrangler Air Filter Replacement: 步骤 2 中的图像 1,2 2007-2012 Jeep Wrangler Air Filter Replacement: 步骤 2 中的图像 2,2
    • Reach underneath the hood and push up on the lever located in the front center of the hood. You can now open the hood.
    • Prop the hood open by inserting the hood support rod into the designated hole on the underside of the hood.
  3. 2007-2012 Jeep Wrangler Air Filter Replacement, Air Filter: 步骤 3 中的图像 1,2 2007-2012 Jeep Wrangler Air Filter Replacement, Air Filter: 步骤 3 中的图像 2,2
    • Locate the air filter box in front of the car battery. It will have a 4-inch diameter hose coming out of one side (towards the center of the vehicle) and an air release coming out of the other side. It should have four clamps keeping it sealed.
  4. 2007-2012 Jeep Wrangler Air Filter Replacement: 步骤 4 中的图像 1,3 2007-2012 Jeep Wrangler Air Filter Replacement: 步骤 4 中的图像 2,3 2007-2012 Jeep Wrangler Air Filter Replacement: 步骤 4 中的图像 3,3
    • Locate the four clips keeping the air filter box sealed. Their locations are as follows:
    • Back Left Corner (near the outer edge of the hood) [picture 1]
    • Front Left Corner (near the outer edge of the hood) [picture 1]
    • Back Right Corner (underneath the four-inch diameter hose) [picture 2]
    • Bottom Right Corner (near the steering fluid container in the front) [picture 3]
  5. 2007-2012 Jeep Wrangler Air Filter Replacement: 步骤 5 中的图像 1,1
    • To unlock the air filter box, grasp each clip and pull the clip away from the air filter box.
  6. 2007-2012 Jeep Wrangler Air Filter Replacement: 步骤 6 中的图像 1,2 2007-2012 Jeep Wrangler Air Filter Replacement: 步骤 6 中的图像 2,2
    • After you have removed the 4 clips, carefully pull and twist the cover off. You now have access to the air filter.
  7. 2007-2012 Jeep Wrangler Air Filter Replacement: 步骤 7 中的图像 1,2 2007-2012 Jeep Wrangler Air Filter Replacement: 步骤 7 中的图像 2,2
    • Remove the dirty air filter by pulling the air filter straight up. Place the new replacement filter in the empty slot.
    • Refer to any labels on the filter about usage.
结论
2等其他人完成本指南。
Adam Donald
于09/26/12注册
299 声望
创作了4篇指南
团队
Cal Poly, Team 7-51, Forte Fall 2012 Cal Poly, Team 7-51, Forte Fall 2012 的会员
CPSU-FORTE-F12S7G51
5 名成员
创作了9篇指南
2条评论
I couldn't get the housing unit off. :(
David J - 回复
You forgot to add the step about removing the two bolts from the air intake assembly. You can't lift the housing unit off unless you remove the bolts.
lahacade - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 28
总计 10,191
