跳转到主内容
2007-2012 Acura RDX Engine Air Filter Replacement
你所需要的
  1. 2007-2012 Acura RDX Engine Air Filter Replacement, Engine Air Filter: 步骤 1 中的图像 1,1
    • On the driver-side footwell, pull the latch to open the hood.
    • Make sure you leave time between driving and performing this fix. Working around the engine while it is still hot presents a burn risk!
  2. 2007-2012 Acura RDX Engine Air Filter Replacement: 步骤 2 中的图像 1,1
    • Lift up the second latch to fully open the hood.
    • This one is located right above the Acura logo on the front of the car.
  3. 2007-2012 Acura RDX Engine Air Filter Replacement: 步骤 3 中的图像 1,1
    • The airbox is directly behind the battery. Remove the four 9 mm bolts holding the airbox down.
    • If you ever had the bolts replaced, they may have a slightly different head diameter. If a 9 mm socket doesn't fit, use the appropriate size socket.
  4. 2007-2012 Acura RDX Engine Air Filter Replacement: 步骤 4 中的图像 1,1
    • Unscrew each of the bolts. Do not remove the bolts.
    • If the bolts are stuck, use some WD-40 or similar lubricant to help loosen them.
  5. 2007-2012 Acura RDX Engine Air Filter Replacement: 步骤 5 中的图像 1,2 2007-2012 Acura RDX Engine Air Filter Replacement: 步骤 5 中的图像 2,2
    • Remove the air filter from the vehicle.
    • In many cases, air filters will have an arrow to show the direction they should go. This direction represents the airflow, for this particular car we want that facing upwards.
    • Do not fully remove the bolts.
结论
One the task is done, close the hood and you are good to drive!
另外一个人完成了本指南。
Andrew Graham
于03/23/21注册
145 声望
撰写一个指南
团队
UMass Dartmouth, Team S2-G6, Riel Spring 2021 UMass Dartmouth, Team S2-G6, Riel Spring 2021 的会员
UMASSD-RIEL-S21S2G6
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 16
过去 30 天: 79
总计 1,464
