跳转到主内容
2007-2014 GMC Sierra Master Power Window Switch Replacement
你所需要的
  1. 2007-2014 GMC Sierra Master Power Window Switch Replacement, Window switch panels of all 07-13' Chevy/GMC Trucks & SUV's: 步骤 1 中的图像 1,2 2007-2014 GMC Sierra Master Power Window Switch Replacement, Window switch panels of all 07-13' Chevy/GMC Trucks & SUV's: 步骤 1 中的图像 2,2
    • Using a flat-head screwdriver, wedge underneath the plastic cover to release it from the assembly.
  2. 2007-2014 GMC Sierra Master Power Window Switch Replacement: 步骤 2 中的图像 1,3 2007-2014 GMC Sierra Master Power Window Switch Replacement: 步骤 2 中的图像 2,3 2007-2014 GMC Sierra Master Power Window Switch Replacement: 步骤 2 中的图像 3,3
    • Unfasten the 10 mm bolts located at the top and bottom of the door assembly.
    • Remove the door assembly.
  3. 2007-2014 GMC Sierra Master Power Window Switch Replacement: 步骤 3 中的图像 1,3 2007-2014 GMC Sierra Master Power Window Switch Replacement: 步骤 3 中的图像 2,3 2007-2014 GMC Sierra Master Power Window Switch Replacement: 步骤 3 中的图像 3,3
    • Wedge the flat-head screwdriver underneath the plastic cover to the switch panel to release it from the door.
  4. 2007-2014 GMC Sierra Master Power Window Switch Replacement: 步骤 4 中的图像 1,1
    • Remove all wire harnesses to the window switches from the back of the panel.
  5. 2007-2014 GMC Sierra Master Power Window Switch Replacement: 步骤 5 中的图像 1,2 2007-2014 GMC Sierra Master Power Window Switch Replacement: 步骤 5 中的图像 2,2
    • With the flat-head screwdriver release the tabs to release the window switch panel from the block of switches.
  6. 2007-2014 GMC Sierra Master Power Window Switch Replacement: 步骤 6 中的图像 1,1
    • Insert new master window switch.
  7. 2007-2014 GMC Sierra Master Power Window Switch Replacement: 步骤 7 中的图像 1,2 2007-2014 GMC Sierra Master Power Window Switch Replacement: 步骤 7 中的图像 2,2
    • Re-plug wire harnesses into the new window switch panel and push panel into the cover.
  8. 2007-2014 GMC Sierra Master Power Window Switch Replacement: 步骤 8 中的图像 1,1
    • Push the re-assembled switch panel down until you hear a click, this means it is secure in the door.
  9. 2007-2014 GMC Sierra Master Power Window Switch Replacement: 步骤 9 中的图像 1,3 2007-2014 GMC Sierra Master Power Window Switch Replacement: 步骤 9 中的图像 2,3 2007-2014 GMC Sierra Master Power Window Switch Replacement: 步骤 9 中的图像 3,3
    • Re-assemble the door arm.
    • Re-fasten the 10 mm bolts to the top and bottom of the door assembly.
  10. 2007-2014 GMC Sierra Master Power Window Switch Replacement: 步骤 10 中的图像 1,2 2007-2014 GMC Sierra Master Power Window Switch Replacement: 步骤 10 中的图像 2,2
    • Re-attach the plastic cover by snapping it into place, start at the bottom for easier installation.
  11. 2007-2014 GMC Sierra Master Power Window Switch Replacement: 步骤 11 中的图像 1,1
    • You've completed the fix! Now enjoy your working Master Power Window Switch!
结论
If you continue to have problems with the windows not working properly then it is an issue with either your wiring or motors and should be looked at by a certified technician. Thank you, and I hope my guide helped solve your problem!
2等其他人完成本指南。
Kody Benedict
于01/27/20注册
263 声望
撰写一个指南
团队
2条评论
I have a 2009 Chevy Silverado. i changed the same panel and everything works except drivers window. any thoughts on how to fix it?
Rick Bonetti - 回复
I have the same issue with my 2009 GMC Acadia. Does yours click? If so I found a useful how to guide I'm going to try next on this forum
How to Fix a Loose Car Window
Heather Grew -
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 29
过去 30 天: 133
总计 5,266
