跳转到主内容
2006 Toyota Tacoma Signal Lights Replacement
你所需要的
  1. 2006 Toyota Tacoma Signal Lights Replacement, Signal Lights: 步骤 1 中的图像 1,2 2006 Toyota Tacoma Signal Lights Replacement, Signal Lights: 步骤 1 中的图像 2,2
    • Turn on the car, and switch the signal light ignition, so that both lights turn on.
  2. 2006 Toyota Tacoma Signal Lights Replacement: 步骤 2 中的图像 1,3 2006 Toyota Tacoma Signal Lights Replacement: 步骤 2 中的图像 2,3 2006 Toyota Tacoma Signal Lights Replacement: 步骤 2 中的图像 3,3
    • Turn on your car, and check the signal lights on the rear end of the car.
    • Identify which side stopped blinking and/or burnt out (left side or right side).
  3. 2006 Toyota Tacoma Signal Lights Replacement: 步骤 3 中的图像 1,2 2006 Toyota Tacoma Signal Lights Replacement: 步骤 3 中的图像 2,2
    • Find a new replacement signal bulb according to the side where the light needs to be replaced.
    • Use the car model, make and year to find the light that best suits the car.
  4. 2006 Toyota Tacoma Signal Lights Replacement: 步骤 4 中的图像 1,1
    • Prepare to remove the old turn signal.
    • Open the hood of the lens.
  5. 2006 Toyota Tacoma Signal Lights Replacement: 步骤 5 中的图像 1,2 2006 Toyota Tacoma Signal Lights Replacement: 步骤 5 中的图像 2,2
    • If needed, use a screwdriver to remove hood.
  6. 2006 Toyota Tacoma Signal Lights Replacement: 步骤 6 中的图像 1,3 2006 Toyota Tacoma Signal Lights Replacement: 步骤 6 中的图像 2,3 2006 Toyota Tacoma Signal Lights Replacement: 步骤 6 中的图像 3,3
    • Remove the light bulb casing.
  7. 2006 Toyota Tacoma Signal Lights Replacement: 步骤 7 中的图像 1,3 2006 Toyota Tacoma Signal Lights Replacement: 步骤 7 中的图像 2,3 2006 Toyota Tacoma Signal Lights Replacement: 步骤 7 中的图像 3,3
    • If needed, replace the electric connector with a new one, aligning and screwing the replacement in the same place.
    • Push the locking and turn it counterclockwise to unscrew the bulb.
  8. 2006 Toyota Tacoma Signal Lights Replacement: 步骤 8 中的图像 1,2 2006 Toyota Tacoma Signal Lights Replacement: 步骤 8 中的图像 2,2
    • Replace the bulb with the new one.
    • Insert the new bulb. Align the pins on the bulb with the ones inside of the car.
  9. 2006 Toyota Tacoma Signal Lights Replacement: 步骤 9 中的图像 1,3 2006 Toyota Tacoma Signal Lights Replacement: 步骤 9 中的图像 2,3 2006 Toyota Tacoma Signal Lights Replacement: 步骤 9 中的图像 3,3
    • Place the new bulb back on the designated place.
    • Replace the hood/lens back on the car.
    • Turn the ignition switch on and engage the blinker lever (first step) to ensure proper instalment.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 593
